The "moustache gang"?Canoehead wrote:Plenty of people seem to be leaving...
Plus 2012 shows 10 pilots turning 65.
2011 Ground Schools
genetic jack hammer
Re: 2011 Ground Schools
Why if this rate of retirements continues, it will only be 15 years to a left seat block on the RJ!
That's guys turning 65- 'guaranteed retirements'. Plenty of others leaving before that age though.
Well yes and no, 2011 hasn't really seen plenty of retiring yet. So far this year Jazz has had 6 retirement's. It is true our boom is starting but it is going to be 10-20 guaranteed retirements per year for the next 5 years. Nothing like mainlines retirement boom.
Its really not that far off the mainline retirement .. Remember there are almost 4000 pilots at mainline and 1500 at Jazz. If 100 a year retire from mainline and 20 from Jazz that's roughly 1.5-2% a year from both pilot groups.
Atleast the movement is in the right direction .. for now.
Just to clarify the numbers. 3000 pilots at mainline with retirements between 120-160 per year for the next 7 years. Almost a third (33%) will be retired.... based on age 60 being the normal age.Localizer wrote:Its really not that far off the mainline retirement .. Remember there are almost 4000 pilots at mainline and 1500 at Jazz. If 100 a year retire from mainline and 20 from Jazz that's roughly 1.5-2% a year from both pilot groups.
There were 10 retirements at Jazz this year I believe. About 12 forecast for next year. I'm sure a few more will pull the plug early though.
from what I've heard calls have been going out for the continuation of interviews that were halted back in the summer.
Goodluck!
Goodluck!
I know a few guys are pulling the pin early as well as folks gone to Mainline, Westjet and the Sand box.
https://eresonatemedia.com/
https://bambaits.ca/
it would be nice if you could see in real time the number of vacancies...instead of waiting for the bid to come out.....
thats something else I was thinking...our vacation bidding is "real time". How awesome would it be if the position bid was like that. It would eliminate the wondering what you could hold and with how many below until it came out. You would actually see at the time of your bid...where you would fall on what equip at what base. Then when you submit your bid, you know RIGHT THEN what you have with how many below etc.....its clearly possible
I guess it'd be somewhat trickier as the position bid is all across Canada and vacation bid is separated in each base. No?
Word on the street is calls going out for sim evals.
We're a little short on crews now but I can't see that being the case in April when the 757 flying is done....
the only real difference is the number of participants. It would take a few days but...would work. I'm not holding my breath though as i doubt this would ever happen.gcanuel wrote:I guess it'd be somewhat trickier as the position bid is all across Canada and vacation bid is separated in each base. No?
DHC-1 Jockey
Got the call two days ago for a sim eval, to be done next week. HR says that there's two confirmed groundschools for February. I've been in the pool since I did my interview back in April, so better late than never! Good luck to all those others in the pool!
3000 TT, 2200 F/O turbine, 1100 F/O Multi-turbine >12,500, 600 PIC.
Confirmed rumor:)
Sim evals are ongoing at this time, and the word from the management is that the hiring will definitively happen early next year due to attrition in this year and for the next year, as well retirements.
This of course is all true as long as Euro survives, Greece becomes new Switzerland, housing bubble doesn't burst here in Canada and man lands a probe on the mars.
Joking aside, things look promising for new candidates! Good luck;)
DHC-1 Jockey wrote:Got the call two days ago for a sim eval, to be done next week. HR says that there's two confirmed groundschools for February. I've been in the pool since I did my interview back in April, so better late than never! Good luck to all those others in the pool!
Every war when it comes, or before it comes, is represented not as a war but as an act of self-defense against a homicidal maniac. George Orwell
Disclaimer: The above post was not meant to offend anyone.
which base and type will be available for new hires ?
genetic jack hammer
You only find out in the indoc g/s (usually day 2, but that could change). Mostly classic dash and Q400, as for bases, it's usually YYZ, YUL and YYC, but there have been a few YVR spots opening up lately. Maybe the odd CRJ spot, but those are becoming fewer and fewer.watermeth wrote:which base and type will be available for new hires ?
DHC-1 Jockey
Has anyone that did the sim in the past week heard back from HR yet regarding medicals? I forgot to ask them when we could expect a response, or when medicals might be scheduled. Thanks!
thanks Genetic that's what I knew, in fact I'll change my sentence : what is the next equipment bid showing ?
thanks
thanks
