bob sacamano wrote:officejet wrote:I didn't mean I don't monitor the autopilot....I meant monitoring the trim....if there isn't a clacker or a wheel to indicate that there is an out of trim situation....there should be some other indicator that shows trim position....but its not part of my regular scan admittedly....
But now that i think about it...it really doesn't make much sense as it all went to hell after configuration change....i guess i should take my own advice and think before typing
That was the only theory I was rollin with Bob....I know it came across a bit sketch....
I was just referring to the other quote that reliance on automation...you're not going to stop turning off the autopilot everytime there's ice....or maybe you do....
Or maybe we just monitor more carefully what's going on with the plane when you're in the clag...it is part of the job to monitor the autopilot's performance to make sure it's actually doing what you want it to do....
that's all man
Dude, go over proper operations of auto-pilot in icing. You don't sit and monitor the trim, hand fly the fucking thing and listen to what it's telling you.
Where the hell did you learn this monitor the trim thing? and you keep on saying that you don't include that in your scan. It's not a tad sketch dude, it's more like someone smoking crack and talking about this shit.
Consider yourself lucky and review the operations NOW!
Ease up man....
I think you're missing my point...
Easy to happen here...
I'm trying to visualize the situation...you're letting the autopilot fly the approach...you remove autopilot and now it's all over the place...
So I was asking...would you be able to identify that the autopilot is working (stressing out...i used laymans terms) harder than it should be in a normal situation by the trim running...do you know what trim setting your plane is at on a normal approach? I admittedly can't spit that info out...That's what i meant by not including it in my scan...
You're saying that you have to hand fly the airplane in icing conditions...reason being so that you're are more cognizant of what's going on....right?
Because with autopilot on...it's might be working a lot harder than it should be if a situation is detiorating and you would be not aware of it...
all i was trying to ask was....
would an out of normal trim be an indicator...trying to see if i could identify a similar situation myself....how else would you identify that there's something not right? abnormal thrust settings, abnormal pitch for current speed/configuration...there's lots out there...i was just askin about one dude...
but then maybe it was stable and it was only with flap selection that it started the rollarcoaster...
time and investigation will tell.
thanks for the lecture though.
i will review my operations...you sounded seriously concerned...so i'll reassure you that i do make a habit of doing so on a regular basis.
i've obviously missed reading the section that instructs me to turn off my autopilot in icing conditions...when i find it you'll be the first to know.
i do consider myself lucky. but you know as well as i do that for every bit of luck there's been some good decisions made too.
