I'm sorry, but I have NEVER NEVER NEVER seen the need to pump a throttle on any of the common and obscure engines I've flown.
It's a wan*er's habit I suppose
+2. The only time I needed to pump a throttle was on a Cherokee 140 I flew that the O-rings in the primer decided to go when I was in the middle of nowhere. It was a bitch to start and I rebuilt the primer as soon as I got home.
Most primer systems go to more than one cylinder. On a typical O-320, three of four cylinders have a primer. The O-300 has only one primer nozzle, but it is in the intake manifold and splits to three cylinders. The O-470 has primer nozzles in all cylinders. The R-1340 I worked on had three cylinder with a primer nozzle that would not only get the engine started on a -20C Calgary winter day, but keep it running after putting the mixture to ICO if the primer wasn't quite locked.
Pretty much all carburetors have an accelerator pump which does shoot extra fuel into the engine. But at cranking RPM it is very difficult for this fuel to get all the way from the carburetor to the cylinders and it will usually collect on the manifold walls and drip back down to the airbox. This pooled fuel is great for catching fire should there be a backfire.
Though I would argue against MichaelP saying the idle jets and nozzles are sufficient (they aren't usually, which is why we crack the throttle on start up) I definitely agree with not pumping the throttle.
