Air Canada Pool
gonefishin'
Re: Air Canada Pool
nada.
LCC is lower... subject to annual raises as per AC
Y1 $46.94
Y2 $51.82
Y3 $59.64
Y4 $67.45
Y1 $46.94
Y2 $51.82
Y3 $59.64
Y4 $67.45
Re: Air Canada Pool
gonefishin' wrote:nada.
Y1 $46.94
Y2 $51.82
Y3 $59.64
Y4 $67.45
That is incorrect. The rates are the same for the first four years both at Mainline AND LCC. There is no difference in pay for the first four years.
Re: Air Canada Pool
90 pilots for two 777's...that many?ram wrote:
For what it's worth...
-15 EMJ = approximatelty 150 mainline jobs
+2 LCC 319 = approximately 20 pilots
+2 LCC 767 = approximately 40 pilots (no RP's)
+2 777 = approximately 90 pilots
Re: Air Canada Pool
Sorry, just re-did my math (should have said 60)...it ranges between 27-30 per a/c. Overseas aircraft, senior pilots with max vacation, relief pilots, etc...We currently have 490 pilots on the 777 for 18 aircraft; an average of about 27.2 pilots per aircraft...bcflyer wrote:90 pilots for two 777's...that many?
Re: Air Canada Pool
Not sure if you work at AC or not, but if you have access to the contract give it a read. If you start off at the LCC those rates seem to be similar to what I read they were when I read through the contract. As far as I know (without reconfirming with the contract) those rates are in fact correct. Now if you getting hired to mainline and get "forced reduced" into the LCC that changes things.bcflyer wrote:gonefishin' wrote:nada.
Y1 $46.94
Y2 $51.82
Y3 $59.64
Y4 $67.45
CatInTheHat
Re: Air Canada Pool
Hey Twotter,Twotter77 wrote:
I received an email about the Nov 12 groundschool that they might be calling this week.
Do you mean you were invited to the groundschool? Or they sent you an email telling you that you "might" get a call?
Any news since?
gonefishin'
Re: Air Canada Pool
hey BC... read LOU 74.20
pretty black and white
L74.20 Pay Rates
CA B767 CA A319 FO B767 FO A319
1 $118.47 $129.98 $46.94 $46.94
2 $125.70 $134.42 $51.82 $51.82
3 $133.02 $138.80 $59.64 $59.64
4 $140.40 $143.05 $67.45 $67.45
5 $147.70 $147.42 $94.60 $90.50
6 $154.98 $151.94 $100.70 $94.65
7 $162.35 $158.06 $105.50 $98.00
8 $169.58 $164.12 $111.95 $99.05
9 $176.91 $170.32 $116.80 $99.05
10 $182.30 $176.35 $116.80 $99.05
11 $182.30 $177.40 $116.80 $99.05
12 $182.30 $178.52 $116.80 $99.05
L74.20.01 Annual Wage Increases
L74.20.01.01
The rates in L74.20 will be increased according to the following:
Effective Date Increase
August 1, 2013 3%
August 1, 2014 2%
August 1, 2015 2%
L74.20 Pay Rates
L74.20.01.01
August 1, 2013 3%
August 1, 2014 2%
August 1, 2015 2%
Re: Air Canada Pool
Back to the topic, with the arrival of the 787's there will be a requirement for additional bodies to cover all the other positions below that type. They will have to be in place and ready to go, prior to the first delivery. The moving of 767's to LCC will take a similar uptake to be in place, prior to their arrival.
As any one knows here we are not carrying any surplus pilots, but there will be a pool of pilots created with the EMB 175's leaving the fleet. However that group alone will not be adequate for the requirement next year. IMHO
Re: Air Canada Pool
Hey Gonefishin. Have a read of 12.03.01. Pretty black and white. The published rates for a mainline F/O in their first 4 years are exactly the same as what you just posted for LCC. Not sure why you feel that an F/O in their first 4 years will make make less at LCC....gonefishin' wrote:hey BC... read LOU 74.20
L74.20 Pay Rates
L74.20.01.01
August 1, 2013 3%
August 1, 2014 2%
August 1, 2015 2%
Re: Air Canada Pool
I do work at AC and I have read the contract. The flat rate for F/O's in their first 4 years is the same at mainline as it is at LCC.. Section 12.03.01 for mainline and LOU 74 as posted above for LCC. The rates for an F/O in their first 4yrs are identical.ZBBYLW wrote:Not sure if you work at AC or not, but if you have access to the contract give it a read. If you start off at the LCC those rates seem to be similar to what I read they were when I read through the contract. As far as I know (without reconfirming with the contract) those rates are in fact correct. Now if you getting hired to mainline and get "forced reduced" into the LCC that changes things.bcflyer wrote:gonefishin' wrote:nada.
Y1 $46.94
Y2 $51.82
Y3 $59.64
Y4 $67.45
Re: Air Canada Pool
You're all (kind of) right. As per Section 12.03.01 the 4 four year fixed rate was:
Y1 $46.94
Y2 $51.82
Y3 $59.64
Y4 $67.45
Now multiple those figures by the 2% raise for 2011 and the 5% raise for 2012 and you get:
Y1 50.27
Y2 55.50
Y3 63.87
Y4 72.24
Therefore, the rate is the same for the first 4 years at the LCC and Mainline.
Hope that helps.
Y1 $46.94
Y2 $51.82
Y3 $59.64
Y4 $67.45
Y1 50.27
Y2 55.50
Y3 63.87
Y4 72.24
Hope that helps.
Re: Air Canada Pool
The 2% raise for the LCC does not come into effect until 2013.
Re: Air Canada Pool
I can confirm this, Page 38 or the Final Appendix Page of the Company Webcast, or LOU 74 I believe.ZBBYLW wrote:The 2% raise for the LCC does not come into effect until 2013.
Re: Air Canada Pool
I see that in the webcast, but not in the contract. Under Recognition in LOU 74, Sections 12.05.01 is not an excluded article.DBC wrote:I can confirm this, Page 38 or the Final Appendix Page of the Company Webcast, or LOU 74 I believe.ZBBYLW wrote:The 2% raise for the LCC does not come into effect until 2013.
Re: Air Canada Pool
L74.20.01.01 is the applicable reference, I don't think section 12 applies as LCC rates are not included there.
Re: Air Canada Pool
DBC, thanks for the reference. Once again I stand corrected.
Re: Air Canada Pool
For all of you in the pool...
Latest bid shows 59 vacancies all yyz.
My guess another gs in Jan and Feb.
Cheers guys
Cheers guys
Re: Air Canada Pool
...of which 56 are at the LCC.For all of you in the pool...
Cheers guys
3 New Mainline Jobs! Sweet!
- Beefitarian
Re: Air Canada Pool
Gah, this title is misleading.
~wraps towel around waist making a skirt like cover for the speedo~
~walks away~
~kicks a rock~
~walks away~
~kicks a rock~
Re: Air Canada Pool
Perhaps it's putting lipstick on a pig but consider those Captain positions. There aren't too many positions and I'd imagine most if not all would be A320, EMJ or perhaps really Junior 767 FOs who have a good income at home from their spouse and bid into it. With the socialized bidding I'd say most of the Junior pilots that go there (I'd bet it's only the junior pilots that go there at least at first) would gain a better lifestyle. With that I'd wager for the next few courses (before the LCC really starts to ramp up) there will be openings for EMJ and A320 FOs at mainline.snag wrote:...of which 56 are at the LCC.For all of you in the pool...
Cheers guys
3 New Mainline Jobs! Sweet!How's that compare to the previous bid?
Its mostly the reduction in 767 flying that is going to be a problem. I find it difficult to believe the company is saving money by having to retrain at least 32 767 FOs (unless they go directly to the 767 LCC).
props ahead
Re: Air Canada Pool
Is it possible that people in the NOV 12 course would be bidding straight into the LCC.....Could a new hire potentially hold a 767 FO position??
Re: Air Canada Pool
You could possibly bid on, and get a 777 Captain position also. Not likely, but possible. Remember that you are behind a whole whack of EMJ FO's that are being reduced. These guys wouldn't mind a nice raise (year 5+) to fly a widebody, or have a much better schedule on the 320 than they would at mainline. We'll just have to wait and see where the gaps are after the current bid results are out, around the 10th.Is it possible that people in the NOV 12 course would be bidding straight into the LCC.....Could a new hire potentially hold a 767 FO position??
Re: Air Canada Pool
The LCC FO positions will not be filled by pilots on the Nov 12th course. The vacant positions will be filled closer to the LCC launch next summer. To answer the second part of your question, yes, there will be new hires going to the LCC A319 and B767 FO positions moving forward as they will be entry level positions for Air Canada pilots.props ahead wrote:Is it possible that people in the NOV 12 course would be bidding straight into the LCC.....Could a new hire potentially hold a 767 FO position??
Re: Air Canada Pool
Might there be a January gs? In your best guestimate, what equipment and base will be available for new hires in early 2013?
