Agreement in Principle reached
TFTMB heavy
Re: Agreement in Principle reached
Post by TFTMB heavy »
airbussy wrote: Fri May 26, 2023 5:56 pm
TFTMB heavy wrote: Fri May 26, 2023 5:46 pm
cdnavater wrote: Fri May 26, 2023 7:52 am Without seeing the details but from what is being said, it’s seems like a really good start towards bringing Canadian pilots to a much better standard of living, if only we paid less tax.
Everyone going on about close the gap or North American standard, etc, that is how negotiations work!
Union asks for the moon, company claims the well is dry and after some brinkmanship they meet somewhere in the middle, if they had asked for 15%, they would have got 7.5%.
As mentioned the scope was huge and probably half of the gain, Sunwing and Swoop pilots will get the most gain in pay.
I look forward to seeing the actual details so I can be jealous and watch more Jazz pilots leave for Westjet, it’ll either light a fire under our management or light the fire that burns us to the ground, obviously not my desired outcome but it is what it is.
Sunning pilots are in a different bargaining unit with their own contract. Unless they are integrated they will not see these wages.
The TA states WJ must file for common employer status by 2025 (iirc). So yes, they will be integrated.
WestJet Swoop and Sunwing will all just become paint colours flown by the same group of pilots, the way it should be.
Thanks for the clarification.
Canpilot7
Post by Canpilot7 »
cdnavater wrote: Fri May 26, 2023 3:39 pm
Canpilot7 wrote: Fri May 26, 2023 9:23 am
Sunwing pilots make more than WestJet mainline and swoop, so presumably they'd have the least to gain.
Did you miss the part about WJ get increases, Swoop pilots will be under the same pay and contract and if the above scale is correct WJ pilots under all YOS will be making more than Sunwing pilots for every position and tier.
After the deal, mainline will make more.
But prior to this deal, Sunwing pilots had higher wages so the new deal assuming all three units get them, benefits Sunwing pilots the least. Not the most as you outlined. They'd get less of an increase than mainline from their old salary.
fish4life
Post by fish4life »
Canpilot7 wrote: Sat May 27, 2023 5:43 am
I don’t think Sunwing had higher wages, maybe a hint higher hourly rate but not more money with the WJ 20% factored in
Canpilot7
Post by Canpilot7 »
fish4life wrote: Sat May 27, 2023 6:27 am
You're correct, higher hourly rates. But you're right - 20% is a big chunk. So that'd make them higher total. Fair point!
MaxAuto
Post by MaxAuto »
Who is going to reconfigure their aircraft? Sunwing (189 seats) or WestJet (174 seats) on the -800s and 8s.?
Sunwing Airlines is designed to fill up resorts. I don't see them reducing their seats configuration.
The vacation division will be run by Sunwing management. Steven Hunter, Len, and Andrew Dawson.
If Sunwing can't continue to operate dry leases beyond a certain date and if WestJet can't transfer aircraft to Sunwing OC for their heavy winter season, where will Sunwing get the additional lift from? WestJet? If Sunwing can't go to Hawaii, can WestJet fly routes that fill up Sunwing branded packaged resorts. The 189 seats configuration is the most optimal for the -800s and 8s. Every tour operator uses thos configuration on the -800/8s for a reason. The company is not going to fly triple the aircraft to fill resorts down south because of Westjets lower seat configuration. That's a huge cost.
The LOU is problematic and not enforceable. Two different business models. Scheduled carrier vs high yield tour operator.
RippleRock
Post by RippleRock »
Not sure why you guys are accepting such paltry "raises" in your 4th and 5th year.
Anything approaching 2% is a bit scary with Justin Trudeau in power till 2025 at least spending like a drunken sailor. Carbon tax is driving the cost of everything through the roof. It's like a three year contract of "slight gains" followed by the next two years of nothing, maybe worse. Should have written in Bank of Canada COL index +1% into the last two years.
If inflation stays at 3+% things aren't going to be that great moving backward again. Hope you guys see it differently, but it's just math.
FurHat
Post by FurHat »
MaxAuto wrote: Sat May 27, 2023 8:01 am Who is going to reconfigure their aircraft? Sunwing (189 seats) or WestJet (174 seats) on the -800s and 8s.?
Its absolutely enforceable. Sunwing as a standalone business model is ceasing to exist. Sunwing flight operations are being integrated into WestJet under one OC. The Sunwing brand will continue on, but will not control any aircraft (not unlike WestJet vacations). If Westjet chooses to keep flying the Sunwing-branded and configured aircraft they can do that but it will be flown by WestJet pilots (including the newly joined Sunwing pilots) under the WestJet OC under the terms of the WestJet ALPA contract. Assuming they vote Yes to the TA.
fish4life
Post by fish4life »
Canpilot7 wrote: Sat May 27, 2023 6:34 am
That’s why I’m pumped they are switching to a more hourly rate based wage structure because it will be easier for our negots team to point and be like “look how much WJ makes we need to make more than that”
fish4life
Post by fish4life »
Sunwing has some higher end resorts and packages as well and I bet people booking those would like a nicer roomy seat on the way. The part you’re missing is that now someone from Fort mcmurray can buy an all inclusive vacation as well instead of needing a separate ticket to get to Calgary
rudder
Post by rudder »
I think that the days of sardine class seating at SWG will end when the integrated fleet exists on just a single AOC.
One company. One AOC. One list. One CBA. One fleet.
cdnavater
Post by cdnavater »
I apologize, I did forget Sunwing recently got WJ plus a bit for wages
dontcallmeshirley
Post by dontcallmeshirley »
rudder wrote: Sat May 27, 2023 1:14 pm
MaxAuto wrote: Sat May 27, 2023 8:01 am..
Having the flexibility of an all economy layout and a 2-class layout would allow WestJet to maximize profits depending on the destination and seats sold. I was recently on a flight where the majority of premium seats were upgraded deadheading crew. To have had the opportunity to sell 15 more economy seats instead of one or two premium fares would likely be a benefit to the company.
NimbusNavigator
Post by NimbusNavigator »
I did some math comparing WestJet's new wages to those of Air Canada and Flair, and the results are pretty surprising imo. I’ve laid out the math in the chart attached. What am I missing?
My conclusions:
- WestJet’s step 12 narrow-body captains’ total wages are 22% higher than Air Canada’s and 39% higher than Flair’s. WJ’s step 12 wide-body captains’ total wages are 10% higher than Air Canada’s.
- We all hope and expect AC will close the gap when they have their new deal. The gap to Flair though is shocking given it’s a 2023 contract. WestJet is paying $90 / hr higher for Step 12 captains! By the way, even for Step 3 captains (Flair should have plenty in that seniority bucket), WestJet pays $82 / hr higher than Flair, which means 50% higher. Wow!
- The most surprising thing to me is by the sixth year, WestJet FO comp ($168 / hr) almost closes the gap to Flair captain comp ($188 / hr). Obviously, captain to captain, the comp comparison is night and day.
I start with base wages to the left of each chart and then add other components of wages, such as WSP/New Pension and CEP, to calculate the total wages, shown on the right side.
WestJet’s base wages reflect the 15.5% bump + 9.1% WSP transfer. For Air Canada, I take the average of day and night rates and then for narrow-body, add the overseas & nav premiums 25% of the time and for wide-body, 50% of the time.
To calculate total wages, I add the following components:
- For WJ, AC, and Flair, I add each employer’s WSP / pension contribution. 10% for WJ, 6-10.5% for AC and 3-7% for Flair.
- For WJ, I also factored in the cash equivalent payment as a per hour figure since its paid in each paycheque.
WJ v AC v Flair - Wage Comparison.png (401.22 KiB) Viewed 3802 times
Return to “WestJet”
