Intersection take offs with Encore's Q400
complexintentions
Re: Intersection take offs with Encore's Q400
Post by complexintentions »
mbav8r wrote:You're correct, the frost was off base and geared more towards the unstable approach and where do you draw the line for shortcuts.
Yes I use reduced thrust, that's a company policy and in the COM/AOM and all the takeoff data is calculated using reduced thrust, full length or intersection. It is not company policy to depart from intersections, that's someone choosing to do something that is allowed but not the safest thing to do, not unsafe. My point was simply that leaving that much runway behind you is not displaying airmanship, I don't think the are reckless and irresponsible.
You didn't answer my question, why are you doing it?
Also I would like to say, I've done it in the past and honestly the only reason is on time performance, is that a good enough reason because I think we can agree, the safest thing is full length.
Actually, no. I categorically disagree, probably because your statement is totally wrong: if the performance figures will allow an intersection takeoff it is mathematically exactly as safe as using the full length. That's, um, why they publish such figures. Which are conservative. Yes, there may be other variables that make taking the full length the better choice. But I reject categorical statements like "full length is always the safest thing". Nonsense. You're just unnecessarily throwing tools out of your toolbox with such narrow thinking.
Balanced field only works if you perform at the required performance levels.
Counting on extra runway to compensate for poor technique on a reject is not my idea of "good airmanship".
My idea of good airmanship includes exercising strong risk management, balancing it with operational considerations. If an intersection takeoff will allow us to avoid a delay and can be safely accomplished with the proper performance figures, it is poor airmanship to sit there waiting for the full length.
Trying to maintain on-time performance within the bounds of safety is very much a component of airmanship. Of course safety is the priority but trying to suggest that a properly planned intersection takeoff is unsafe is a total non sequitur.
But I do always enjoy listening to pilots judging other pilots operating aircraft they themselves don't fly. :roll:
Tanker299
Post by Tanker299 »
Donald and complex you hit the nail on the head.
If your the pilot who needs full length on a day with no risk of surface or runway contamination please tell me what you are going to do with that runway in front of you after V1 or rotate? Even better what are you going to do with it after you put in the turn at 400-500 feet only half way down the runway?
goingnowherefast
Post by goingnowherefast »
Use it to slow down more gently. It's easier on the tires and brakes, plus you don't need your passengers to be hanging off their seat belts in the event of a reject. Maybe use balanced field +25%, and anything beyond that is unnecessary?
Runway behind you is useless, but so is runway ahead of you after after coasting to a stop from V1.
atphat
Post by atphat »
Rejected takeoffs are not, or meant to ever be gentle. Passenger comfort is not what you should be thinking of during a RTO.
complexintentions
I agree with what I think you're trying to say atphat, but I would add that you're referring to a reject in the high speed regime i.e. after 80 knots and before V1. And you're correct, a high-speed reject is critical, the priority is definitely not to "slow down more gently". Or you may find yourself gently taxiing off the end of the runway, depending on how close to V1 you were when you initiated the reject. :mrgreen:
Obviously if you reject at low speed you may not need to brake hard enough to hang the pax in their belts. You might just retard the thrust levers.
But neither a high or low speed reject requires some arbitrary extra distance beyond the performance figures.
brooks
Post by brooks »
This thread is so dumb...
complexintentions
Well from your comment you certainly seem qualified on the "dumb", thanks for contributing! :mrgreen:
mbav8r
Post by mbav8r »
Complexintentions, we're not talking about taking a delay, it's about turning a very long runway into a balanced field for saving a minute or two, very rarely is there a line up for departure in YWG! Like I said, it's not unsafe, it's not as safe. I also happen to know how the Q performs.
Couple things, a high speed max braking reject on a loaded RJ will have the brake temps rise to white after the reject and even red in a warmer climate, so if you know you have room you can avoid this.
Maybe a poor analogy but if you have enough money in your account to pay the bills, that's all you need, if you have some left over after the bills are paid are you more or less comfortable?
What's better, more fuel than you need or exactly the right amount?
To be clear, just today tower had us taxi to an intersection for departure, we sent for a new TLR as my default was full length, I think we established this but anyhow, numbers worked and I looked at the line up for the full length and opted for the intersection, see I was able to work outside the box.
BTW, your math is out, you're assumption is at V1 you're going flying, there are other variables that could cause a reject after V1 and I for one will be happy to have extra runway if it ever happens.
Lateralus
Post by Lateralus »
brooks wrote:This thread is so dumb...
Agreed.
Eric Janson
Post by Eric Janson »
mbav8r wrote:BTW, your math is out, you're assumption is at V1 you're going flying, there are other variables that could cause a reject after V1 and I for one will be happy to have extra runway if it ever happens.
You do not reject a take-off after V1.
V1 is the speed at which the take-off must be continued unless the stopping maneuver has already been initiated.
Yycaviator
Post by Yycaviator »
mbav8r wrote:
Maxpwr wrote:This is the dumbest conversation I've seen in a while. So we're gonna fret because they "leave half the runway behind them", when that runway is 11000' long?! If you had any idea what he Q400 can do you'd be having a laugh along with me and everyone else who flew into and out of the Island with it. I'll say it again, if the Aerodata shows it works then what's the problem? Having said that if there was any contamination in the runway then I wouldn't choose such an aggressive intersection. That's where airmanship comes in. Airmanship does NOT mean taxi your 172 to the end of a 11000' runway just in case. Ridiculous.
I've been offered S intersection 35R in YYC many times and turned it down every time, is 12,000 feet enough, sure but imagine a scenario where you have a control malfunction occur at V1 and you attempt to rotate but can't, I'll sure be happy to have that extra 2000 feet at that point. Plan for the worst, hope for the best.
Do you know why S is where it is?
S was placed to keep the runway out of the 29 arrival terp (or whatever the fancy name is for protected airspace design is). So at night/mornings/weekends when they are landing 29, and departing 35R, if you take full length, the tail of your plane is effectively shutting down arrivals on 29 because it intrudes the protected zone.
So your co-workers and friends at other airlines thank you for making a silly point and arguing over a standard YYC procedure. Perhaps you can find some time to read the FAA/NTSB reports on rejects after V1 on your extended taxi next time.
The numbers work, the numbers work. Thunder Bay was NOTAMED down to 5,000 feet all summer. Which is much shorter than a 35L intersection takeoff.. So are we saying Westjet should have suspended ops into Thunder Bay this summer?
goingnowherefast
I bet these guys appreciated having extra runway in front of them. They rejected well after V1.
http://www.rcaf-arc.forces.gc.ca/en/fli ... t/hky1dmyy
That being said, they also had 1500' in front of them when they stopped.
PositiveRate27
Post by PositiveRate27 »
I fly the Q400 and I'm very aware of what it's capable of. I'm also realistic about what the Mark-1 human is capable of. (or incapable in some instances)
Qatar departed from the T1 intersection on rwy 29 in Miami and struck runway approach lights at the far end due to crew erroneously entering takeoff data. Had they used full length they would have had adequate takeoff distance, regardless of what they had typed in. Now imagine if they had had to do an RTO at v1 that night.
If everything goes exactly as it should, intersection takeoffs work just fine. In many circumstances it would be silly to turn down an intersection departure such as 35R from S in YYC or 08R from L4 in YVR.
The unfortunate fact of life is that things don't always go as planned. Humans make errors. Perhaps a crew enters data in incorrectly. Perhaps they don't react as they should at critical moments. Perhaps the airplane has such a catastrophic failure it's incapable of flight after v1. I've personally seen ACARS print out erroneous data. I then resent for a new TLR with the exact same parameters and received completely different speeds and distance required.
At the end of the day, it's your aircraft and your decision to take an intersection. Im happy to take intersections, but I won't choose to ever leave half the runway behind me simply to save a couple minutes, especially since I'll probably have to wait 5 minutes for a marshal when we arrive anyway...
mbav8r
Post by mbav8r »
This is getting a little ridiculous at this point, my preference is full length, more runway good, less runway bad. I have said I'm not rigid in this, if offered I won't take it nor will I ask for one to save a few bucks. If I have to because of terps or some other reason I will.
Due respect, Eric, if the plane won't fly at V1 are you just going to plod along off the end of the runway, seriously. V1 is extremely important on a balanced field and I understand that I have no way of knowing exactly how much extra runway I have but I will have a cushion, call it granny runway if it helps you sleep better.
Incident: Openskies B752 at Paris on Sep 20th 2010, rejected takeoff because of wrong flap setting
The airline reported, the takeoff was rejected at high speed due to an inconsistency between what the crew expected and got to see on their instruments. The airplane slowed safely and vacated the runway, the aircraft received minor damage to tyres and wheels consistent with a rejected takeoff at high speed.
Do you think this was a reject after V1? Very likely in my opinion, I'm just saying if a mistake is made and the plane won't fly, I won't be the guy justifying why I used an intersection instead of full length.
I did find some examples of a reject past V1 due to control issues and could have turned out differently had the crew opted for a balanced field instead of full length.
You guys do what you want!
complexintentions
As Eric said, you do not reject a takeoff after V1. The RCAF crew did, and got away with it. That does not in any way justify using extra field length to reject after V1.
The whole point of V1 is to remove the need to make a decision at high speed. That's why it's also called "decision speed". The whole procedure is designed to stop the machine before V1, and take a problem airborne after V1. That's it, that's all. In a large a/c at V1 you're covering almost 300ft of runway every second. At that point the last thing you should be doing is an assessment if you can still stop. These guys were able to do what they did being in a slower C130 and had a successful outcome. But I shudder to think that it's being held up as an example of a good idea or a valid defence of taking full length. A fire is absolutely a dire situation, sure. It still doesn't justify rejecting after V1. Yycaviator is right, read the reports on rejects after V1. Far, far more often there is a terrible outcome to what could have been handled safely and routinely in the air.
I wasn't going to post again in this thread. A couple have commented that it's "dumb". Due to the laziness of such comments it's not really possible to tell what they're referring to. But I'm amazed by how many posters seem to genuinely think that full-length takeoffs are "always safer", and apparently the reasoning is, since you then have more chances of stopping if you put in wrong performance figures, mishandle the reject, or decide to initiate it after V1. With that mentality, I hope that if I'm a pax behind a crew that is already considering not following their own procedures that they DO take the full length!
Consider me "dumbstruck". :shock:
goingnowherefast
FYI, the RCAF accident I quoted was on a touch-n-go. They did not use the full runway length. They started the go while still on the roll-out from the landing.
The point I was trying to make was that they had a more runway than was the minimum required, and used most of it, still with 1500' to spare.
Lateralus
Post by Lateralus »
Eric Janson
Some links:-
216 pages of Performance info from airbus.
http://www.skybrary.aero/bookshelf/books/2263.pdf
airbus definition of V1.
http://www.airbus.com/fileadmin/media_g ... _SEQ07.pdf
airbus briefing on the "Stop or Go" decision.
http://www.airbus.com/fileadmin/media_g ... -SEQ04.pdf
mbav8r
Post by mbav8r »
Eric, thank you for the link to the Airbus briefing, I always appreciate safety briefings. Of note, it does stress the importance of a go decision at V1, however they describe situations where a stop decision would be appropriate at or above V1.
"The Captain can consider to reject a takeoff when the aircraft is above V1, only in the event that the aircraft is not able to ensure a safe flight."
Windshear, would be a scenario I envision where having the extra runway might be important and is talked about.
Pilots have been known to make mistakes and having the ability to correct that mistake with a cushion is something I hope to never need but will always appreciate I had if I need it!
An entire hockey team died and the report indicates they could've stopped after V1 on the remaining runway after the first failed attempt to get airborne.
Complex,
My AOM comes with a warning that basically reads, a decision to reject above V1 on a balanced field will result in the aircraft being unable to stop on remaining runway. It does not however prohibit us from making a decision to stop, not going against any procedure at all. Frankly, I would rather be in the back with a crew who would choose a low speed excursion as opposed to one who will die trying to get an unflyable airplane in the air because they are over the decision speed. There are examples of near catastrophies with incorrect flap settings, barely getting airborne at the end of the runway and an intersection takeoff may have been the difference of all aboard dying. As far as I know there is no warning to indicate an incorrect flap setting, if my performance has indicated flap 20 but flap 8 is selected, I'll still get a takeoff ok indication.
I have had situations where when I was offered an intersection and sent for new data, it went from reduced thrust flap 8, to rated and flap 20, why would I choose that!
It does surprise me that a pilot of a heavy would advocate for runway behind them and I truly hope you are the minority!
mbav8r
Post by mbav8r »
Incident: Jet Airways B773 at London on Aug 30th 2016, unsafe departure
By Simon Hradecky, created Thursday, Oct 6th 2016 16:00Z, last updated Thursday, Oct 6th 2016 16:00Z
A Jet Airways Boeing 777-300, registration VT-JEK performing flight 9W-117 from London Heathrow,EN (UK) to Mumbai (India), lined up Heathrow's runway 27L at taxiway S4E, about 1200 meters/4000 feet down the runway (total runway length 3660 meters/12000 feet leaving about 2400 meters/8000 feet remaining for that takeoff). The aircraft departed, climbed through 1000 feet MSL about 3200 meters/1.7nm past the runway end and continued the flight to Mumbai for a safe landing about 8:10 hours after departure.
However, local residents complained to police about a low flying aircraft, that had barely cleared the aerodrome perimeter fence. Police contacted Air Traffic Control at Heathrow Airport, who identified the aircraft and notified United Kingdom's AAIB. The AAIB opened an investigation into the occurrence and informed India's Directorate General of Civil Aviation (DGCA), who suspended both captain and first officer of the flight pending the investigation.
The airline reported there had been no injuries and no damage, the airline however investigates the occurrence as part of their active safety management, too. The aircraft performed an intersection departure, thus not using the full runway length, however, did not climb to required height in time and crossed the airport perimeter wall and traffic on the road just past the wall at very low height.
mbav8r
Post by mbav8r »
By Simon Hradecky, created Thursday, Sep 17th 2015 14:02Z, last updated Tuesday, Feb 16th 2016 23:07Z
A Qatar Airways Boeing 777-300, registration A7-BAC performing flight QR-778 from Miami,FL (USA) to Doha (Qatar) with 279 people on board, lined up runway 09 at taxiway T1 (approximately 2600 meters/8500 feet takeoff distance available, full runway length 3968 meters/13,016 feet) and departed Miami's runway 09 but struck the approach lights runway 27 during departure. Both tower, departure controllers as well as crew maintained routine communication. The aircraft continued to destination for a landing without further incident about 13.5 hours later.
On Sep 17th 2015 the FAA reported the aircraft struck approach lights on departure from Miami and continued to destination. The aircraft received substantial damage to its belly, the occurrence was rated an accident.
I think I've made my point, also Complex, please provide a definition of airmanship that includes operational performance in it. Safety and professionalism go with airmanship, protecting the bottom line of the company makes you a good employee, but I completely reject the notion that an intersection departure is "as safe" as full length and doing it to save a few bucks is not displaying good airmanship, over and out!
fish4life
Post by fish4life »
If those crews used proper take off numbers they would have departed with plenty of room and never hit anything.
mbav8r
Post by mbav8r »
fish4life wrote:If those crews used proper take off numbers they would have departed with plenty of room and never hit anything.
Ok, so you're infallible, got it!
Those were presumably experienced crews who made mistakes, maybe tired, maybe just thought they were incapable of making mistakes so they were fine with taking a few shortcuts here and there.
I don't think at this point I can say anything to convince anyone they are taking extra risks by doing this, some feel it's exactly as safe to leave perfectly good runway behind as a common practice, for me nothing will convince me I'm wrong. I just hope I'm not in the back if you realize this choice was the wrong one!
Post by ahramin »
I certainly hope I'm never in the back of an aircraft with someone up front who always uses full length in case they mess up the takeoff power/speeds. How would they know full length is enough? If that's your idea of risk management, best stay on the ground.
mbav8r
Post by mbav8r »
ahramin wrote:I certainly hope I'm never in the back of an aircraft with someone up front who always uses full length in case they mess up the takeoff power/speeds. How would they know full length is enough? If that's your idea of risk management, best stay on the ground.
I hope I'm not in the back of an aircraft who's pilots thinks they can't make a mistake, much worse in my mind. I happen to be very conscientious and very deliberate with regard to ensuring the correct flap and data is being used, it's not just a checklist item to read and say, it's the opportunity to make sure the data and the flap match but I'm not so arrogant to think it can't happen.
To be frank, I've grown tired of the idiots who can't see that as a general rule full length has benefits over an intersection and I think you are just trying to justify your actions at this point, I'm done.
Return to “WestJet”
