Typical sched
skybluetrek
Re: Typical sched
Post by skybluetrek »
Timetoflyagain wrote: Sun May 08, 2022 6:12 am …there is never really a typical sched as it’s all seniority and preference driven. With 12 guaranteed days off, and a mix of single day, 2/3/4 day pairings if you like being home and can hold those pairings…great. Some like splits (2 flights, late evening returning early next morning, so full day at home, but probably tired), others with a long drive want a 4 day pairing and will rack up the taxfree perdiems. Due to the new more restrictive duty regs we generally see shorter pairings, to give a bit more buffer to avoid cancellations due wx, ATC, AOG delays. choose (and get awarded) high credit pairings and have more than 12 days off. Choose low credit and only do 2 or 3 flights per day, but more days worked per month. Fortunately there’s enough mix of pairings that with a bit of seniority you’ll get more of what you like than not.
Thanks a lot for the explanation/info.
Return to “Porter Airlines”
