Whats your Shortest non stop flight?
gustind
Re: Whats your Shortest non stop flight?
Post by gustind »
Personally, a 5km flight from a nursery where I bought a Lavender plant then back to CNY3.
Although I met a guy once who was called in on his single Beaver to transport barrels of something across a trench. The trench was 10m wide and they had no way of moving the barrels across it. So, he landed on one side, loaded her up, took off and landed on the other side of the trench. Repeat for a few hours.
Daniel Gustin
Online Ground School
5x5
Post by 5x5 »
Not so short compared to many here but shortest for me and on the way back from Oshkosh. 06D (Rolla, ND) to S28 (Int'l Peace Garden) - 18 miles. Notable mostly because S28 is a fairly cool stop as you land on top of a hill and walk down to either US Customs or Canadian Customs depending which direction you're going.
Mark Twain
VSF
Post by VSF »
CYAM to KANJ. 6nm
Flying around all the BC lower mainland airports were some pretty short flights for me ypk-yly-yxx... but slow and simple airplanes make it like driving down the block...
YYZ-YTZ in a -8 was probably the shortest great circle for me flying commercially, 11nm, but track miles were more with all the handling.
YBW-YYC in a King Air was quick.
14 NM
SJC-SFO in a Boeing was really quick.
Great circle map says 26 NM but felt like less
Straight out SJC 30L, sid cancelled, cleared straight in SFO 28R.
That’s the thing with faster planes and terminal airspace. Done YYJ to YVR and back and YVR to YXX but plenty of track miles were added by vectors.
Cessna 180
Post by Cessna 180 »
CYAM to KANJ, 6 nm. Went there when YAM was out of Avgas and that was the closest airport.
AppleOTP
Post by AppleOTP »
Heliian
Post by Heliian »
YMO to moose factory 2.5ish miles.
TG
Post by TG »
Schooner69A wrote: Sat Dec 08, 2018 9:38 pm From the end of the runway to where I landed: about 1100 meters
From the end of the runway to where the airplane landed: about 2500 meters
Winner! :mrgreen:
SR22
Post by SR22 »
Many years ago when I kept my aircraft in the Wardair hangar at YYZ and had to taxi from Customs at the north end back to WD. Called ground for taxi and was subsequently cleared "take off 15, cleared to land 24.
I used to keep the 310 on the apron at Field at the north end, just across Kilo from the customs circle. I'd shut down in the circle to clear customs, and often have a challenge starting it again to taxi 100 feet to the parking spot. I begged Customs to allow me to taxi into their circle, wait for their acknowledgement, then taxi and shut down in my spot for inspection there, but they would never agree.
J31
Post by J31 »
Cessna 185 amphib from Fort Providence airport to the water at Whitlock Island. The job was to man up a Coast Guard ship which was wintered next to Whitlock island. The only way to get to it was to fly 5 miles over the ice flows to open water by the ship. Manual pump...85 strokes to get the wheel gear up and land in the water 4 minutes later. Off the water and 50 strokes to get the wheel gear down to land on the runway 4 minutes later. Repeat....12 trips.
Rooster69
Post by Rooster69 »
Grey_Wolf wrote: Sat Dec 08, 2018 4:37 pm Fort Albany (YFA) to Kashechewan (ZKE), in Ontario. 90 seconds at 500' in a PC-12
Did that one. I was getting paid like 7 cents a mile. Earned less than a buck that day.
prettyFLY4awhitegal
Post by prettyFLY4awhitegal »
lhalliday wrote: Sat Dec 08, 2018 4:41 pm CYNJ-CYPK, 8nm. Zero cruise time, as soon as I'm clear of Langley's zone I'm starting my approach in to Pitt Meadows.
KBLI-CYXX, 16 nm. Shortest international flight.
...laura
A couple of times while doing circuits in Abbotsford I've been told to extend downwind and have almost hit Lynden. Less than 6nm
yhz41
Post by yhz41 »
YRT-YXN and YHD-YXL both 37 NM. 10 minutes in a king air, slightly longer in a light twin.
broken_slinky
Post by broken_slinky »
CYQG to KDET. It's about 8NM as the birds fly. We use Coleman to clear customs and pick up fuel if it's less expensive. Doing the EAPIS, booking a customs appointment and opening the flight plan takes way longer than the flight.
lhalliday
Post by lhalliday »
prettyFLY4awhitegal wrote: Sun Dec 09, 2018 8:00 pm A couple of times while doing circuits in Abbotsford I've been told to extend downwind and have almost hit Lynden. Less than 6nm
I flew some circuits at Abbotsford some years ago on my student pilot permit. I checked the ATIS before I departed, noted that the active was 25 and discussed the airspace implications with my instructor.
He told me that The Authorities would take exception to me filing a flight plan to Bellingham (or Victoria, via U.S. airspace), but a wide downwind at Abbotsford that happened to be a few meters in to Whatcom County wouldn't be an issue.
...laura
Gilles Hudicourt
Post by Gilles Hudicourt »
2.5 NM, from Port-au-Prince's old military airfield, Bowen Field, to Port-au-Prince International, twice, once in a Beech F33C, a second time in a Beech E-18S.
Last edited by Gilles Hudicourt on Mon Dec 10, 2018 11:33 am, edited 1 time in total.
Andjam
Post by Andjam »
Andjam
Post by Andjam »
robshelle
Post by robshelle »
Port McNeill to Alert Bay. 4.3 NM
Robshelle
Captain S itmagnet
Post by Captain S itmagnet »
Fort Frances Ontario to International Falls Minnesota. PA31-350 six miles in a straight line.
jschnurr
Post by jschnurr »
St Andrews to Winnipeg. 12nm.
Not the shortest flight possible, but I flew that corridor at least 315 times...
FICU
Post by FICU »
Under 5 minutes wheels off to wheels on in a 737.
V3-HGX
Post by V3-HGX »
Andjam wrote: Mon Dec 10, 2018 11:24 am MZBZ to MTZA ; Belize International to Belize City, 5 NM
I do this leg all the time. Takes about 3 minutes by Caravan. Every day I will do numerous flights between the islands in Belize that are less than 5 minutes long.
