AC emergency
valleyboy
Re: AC emergency
Post by valleyboy »
Good stuff -- text book -
http://www.blackair.ca
Laser Tilt
Re: AC emergency
Post by Laser Tilt »
Re: AC emergency
Laser Tilt wrote: Fri Feb 07, 2020 12:04 pm VasAviation video of this.
https://www.youtube.com/watch?v=z44W_S5skis
Thanks,
Overall seems like a good decision to burn off the fuel for a lighter landing with at least one tire blown out.
Some interesting insight from the recording including what sounded like poor wording/misunderstanding from ATC which perhaps was part of the cause of them turning in the wrong direction at one point. It did sound like there was a miscommunication for the holding clearance based on the track they took but the tape is condensed so I am not sure. It almost seems like at places like this one should request the holding clearance in full again for confirmation that you heard it correctly, if it sounds like there was any chance you were both talking at once or any other reason for doubt.
Strange how the gear wouldn't go up at first but could go up later. Also nice of ATC to tell them that they have an almost 4000m runway available which later turns out to be 3050m(basically 10,000'), although one can easily see the very long displaced threshold on the airport chart resulting in it being not overly long and there was plenty of time for review. But there can be situations where there is not much time and a quick return is required. At my company, during the takeoff briefing, a lot of people mention the longest runway that could be used in the event an emergency return(with wind as a consideration). 32L was definitely not that.
Tailwind on landing wasn't the preferable situation at probably close to max landing weight with only one reverser available combined with a reduction in braking capability. Not surprisingly, the brakes did get very hot which can be hazardous, especially if there was leaking hydraulic fluid which is quite possible after a gear issue like this one.
It appears that there is an approach in the opposite direction available, perhaps with a longer LDA and into wind landing which could no doubt be acceptable to ATC for an emergency. Personally, I would suggest using the into wind runway in such a situation.
Actual pic here....
https://scontent.fybz2-1.fna.fbcdn.net/ ... e=5ED5DA9C
Gannet167
Re: AC emergency
Post by Gannet167 »
I'm not a 767 guy so I'm probably missing something. Why try to raise the gear? Weather looks VMC, no big obstacles to climb above, gear damage so why risk having it get stuck retracted? Especially when it doesn't want to come up. I'd leave it down and locked and not risk having problems getting it back down. Need to burn fuel, gear is generally the most effective drag to help increase fuel flow.
Re: AC emergency
Gannet167 wrote: Sat Feb 08, 2020 6:33 am I'm not a 767 guy so I'm probably missing something. Why try to raise the gear? Weather looks VMC, no big obstacles to climb above, gear damage so why risk having it get stuck retracted? Especially when it doesn't want to come up. I'd leave it down and locked and not risk having problems getting it back down. Need to burn fuel, gear is generally the most effective drag to help increase fuel flow.
Thanks,
In the video, the pilot states that "the gear will not retract". I assume that this means that there is some sort of malfunction preventing retraction such as a damaged air-ground sensor/tilt mechanism/etc. Later on, it does retract. There does appear to be a lock override trigger on the 767 so I wonder if that was used to eventually raise the gear.
Voluntarily keeping the gear extended after an engine failure during the takeoff roll/initial climb in a heavy twin engine aircraft can be an extremely risky decision due to the lack of initial climb performance, which can be very poor even with the gear retracted. They did ask for vectors toward lower terrain, so performance was obviously a concern.
The last aircraft that I remember having a 50% power loss and unable to retract the gear was the Air France Concorde in Paris. Perhaps different aerodynamics, but they didn't get very far.
hamstandard
Re: AC emergency
Post by hamstandard »
Someone out there created a collage of pics/videos....
https://www.news../air-ca ... to-madrid/
valleyboy
Re: AC emergency
Post by valleyboy »
Just stop and think abut what we are seeing here. How many Twin engine 705 aircraft will fly with one engine inop at heavy weight with the gear hanging down. Boeing got it right with this one but there were likely growing pains as well.
Gear does not fix its self and I would think that we miss something in the recording. They likely elected to leave the gear down until either the had to pull it up for performance, proper cool down period or (as happened) they got a visual. There could of been concerns of a wheel well fire. I know I would have been thinking that way. From what I can see all actions were deliberate and thought out well. It also shows confidence in the engine to fly around as they did. We also must be aware that they are also coordinating all steps with with all aspects of who might be involved at home like operations, maintenance and SOC.
A type that has been operated for years with established training and crew competence, Senior equipment and routes appears to have benefits. It magnifies some of the safety issues plaguing the aviation industry. Turkey, right in the same time frame and yes issues ignored by the 2 high profile tragic events.
New Antique Pilot
Re: AC emergency
Post by New Antique Pilot »
About 40 years ago a DC-9 at MTOW took off from Toronto on a longer than usual domestic flight. Vr would have been close to 180 kts. Right around rotation they blew a tire. Pieces of the tire went into one of the engines and also took out the hydraulic lines in the wheel well.
Now they had an engine failure and the gear would not come up. I can’t recall if they were ever able to get high enough to dump fuel or to a fuel dumping area. Anyways they safely made it back after staggering around west of YYZ. Perhaps someone out there has more details.
NAP
Canoehead
Re: AC emergency
Post by Canoehead »
New Antique Pilot wrote: Sat Feb 08, 2020 8:50 am About 40 years ago a DC-9 at MTOW took off from Toronto on a longer than usual domestic flight. Vr would have been close to 180 kts. Right around rotation they blew a tire. Pieces of the tire went into one of the engines and also took out the hydraulic lines in the wheel well.
NAP
Sadly they didn't get airborne. They were departing off of what is now 24R.
https://en.wikipedia.org/wiki/Air_Canada_Flight_189
(Unless there was another incident in that era. I don't believe the DC9s had fuel dumping capabilities)
New Antique Pilot
Re: AC emergency
Canoehead wrote: Sat Feb 08, 2020 10:10 am
NAP
Yes that was another one. The one I am talking about definitely got airborne. It was a year or 2 after the accident one off the end of 23L or whatever the runway # it was at the time.
NAP
New Antique Pilot
Re: AC emergency
DC-9-32’s definitely could dump fuel.
NAP
fish4life
Re: AC emergency
Post by fish4life »
New Antique Pilot wrote: Sat Feb 08, 2020 10:36 am DC-9-32’s definitely could dump fuel.
NAP
Are you sure about that? A quick google search says they can’t
TheStig
Re: AC emergency
Post by TheStig »
Thanks for posting the links. Kudos to a job well done by the crew, MAD ATC and the Spanish Air Force. With respect to the comments about the 767, Boeing absolutely got it (and the 757) right. It will be interesting to find out how much power the engine produced after ingesting the tire debris, however, with a 138 people and 40-45T of gas it wouldn't have matter too much. Incidents such as this and the Southwest uncontained engine failure and subsequent depressurization make a strong case for training for multiple related failures as opposed to just individual failures.
valleyboy
Re: AC emergency
Post by valleyboy »
We were always training multiple related failures and like this incident a blown tyer was almost always an engine inop or a wheel well fire. When something grenades there is always the possibility of multiple failures.
New Antique Pilot
Re: AC emergency
fish4life wrote: Sat Feb 08, 2020 2:05 pm
NAP
A retired Air Canada DC-9 mechanic friend of mine says that they could dump fuel. Lever was on the floor near the Captains seat. A red hinged cover on the floor was lifted to access the dump handle. Maybe it was an option. Sorry for the thread drift. I just wanted to point out that there have been other cases besides the Concorde accident when the gear wouldn’t come up.
NAP
