AuxBatOn wrote: ↑Mon Aug 24, 2020 6:39 am
[quote=iflyforpie post_id=<a href="tel:1125261">1125261</a> time=<a href="tel:1598196899">1598196899</a> user_id=16238]
Yes. It’s child’s play to introduce a disconnect system into an irreversible powered flight control system or a FBW aircraft.
Not so much at the small, manual, general aviation side of things. All they have is a clutch or servo you can overpower, or a button to disconnect.
If an autopilot is unable to cope with the forces it is subjected to (regardless of pilot input or aerodynamic forces) it should disconnect. It is a fairly simple logic to implement (if the difference between the commanded output and the actual output grows by y over x seconds, disconnect). It means the autopilot is not able to do its task and control should be handed back to the pilot.
It’s not simple logic to implement if you don’t have any data to work off of. Lots of small aircraft autopilots don’t have any form of feedback at all, or only in pitch for the purposes of trimming away the forces.
You also have to balance between having an autopilot that can be overpowered by the pilot, yet not disconnect all of the time in any turbulence or fuel imbalance situation (since most don’t control rudder or aileron trim).
Well.. having a clutch or servos that can be overpowered achieves the same thing.
Having an autopilot disconnecting because it “can’t cope” can introduce many more problems. What is the definition of “can’t cope” if you can’t measure the force at the servo? An altitude excursion? An attitude excursion? A stall? What about some of the more complex modes like Flight Level Change and Vertical Speed? What if this is a single pilot IMC and all he need to do is for the AP to keep the plane flying while he sorts himself out?
You could make a light aircraft to transport category standards, and you’d have an airplane too expensive to buy and too heavy to fly. All flying is risk. Your airplane suffers a mishap rate much higher than that of transport category aircraft—is it unsafe and should it be redesigned to a higher standard?
No.. we weigh risk. Risk is defined as the likelihood combined with the severity of something happening.
Likelihood of a pilot having control problems because of an inadvertent autopilot activation. Slim. I remember as a 30 hour student pilot I accidentally turned on the autopilot in the 172S. I didn’t like what it was doing, realized the autopilot was on, so I turned it off. End of story.
Severity of outcome of an inadvertent autopilot activation? I think this would be more of a case where the pilot isn’t fighting the controls and isn’t aware of what his aircraft was doing. UPS 1354 is an example of this. Though the autopilot was intentionally on, the captain was unaware of what the AP was doing and the FO not effectively briefed or monitoring and it flew them into a hill.
In those cases, the autopilot is coping fine, it’s the pilots who are unaware of what the autopilot is doing.
In the case where the pilot wasn’t aware and continued to fight it, he was very aware of his aircraft’s immediate state, and was able to land successfully.. though with difficulty.
So I think the risk of inadvertent autopilot activation with the pilot having to overcome it is negligible, personally.
So a better solution—one that’s been mentioned in this thread and how most companies with automated aircraft operate... and a catch all for both inadvertent activation and situational awareness—is proper training on the aircraft automation and awareness of its state.. which include callouts for activation, modes selected, values selected, modes annunciated on the rumour board, training in emergencies and abnormalities regarding the automation, and all of the ways to disconnect it—of which there are six distinct ones in the aircraft I fly.. three of which are HOTAS.
