You'll outgrow giving a poop.notwhoyouthinkIam wrote: ↑Fri Jun 25, 2021 8:17 amI mean, not having obnoxious passengers critique your landing is also a plus.WestJet Puke wrote: ↑Fri Jun 25, 2021 6:18 am ....plus there are folks among us who actually enjoy the night flying....
WestJet Dedicated Freighters
ALPApolicy
Re: WestJet Dedicated Freighters
Sometimes I slam them on to let everyone knows who’s in control (or not) of the airplane.ALPApolicy wrote: ↑Fri Jun 25, 2021 3:08 pmYou'll outgrow giving a poop.notwhoyouthinkIam wrote: ↑Fri Jun 25, 2021 8:17 amI mean, not having obnoxious passengers critique your landing is also a plus.WestJet Puke wrote: ↑Fri Jun 25, 2021 6:18 am ....plus there are folks among us who actually enjoy the night flying....
notwhoyouthinkIam
The flight attendant in back asked me to let her know when we arrived...AnonPilot wrote: ↑Sat Jun 26, 2021 11:40 amSometimes I slam them on to let everyone knows who’s in control (or not) of the airplane.ALPApolicy wrote: ↑Fri Jun 25, 2021 3:08 pmYou'll outgrow giving a poop.notwhoyouthinkIam wrote: ↑Fri Jun 25, 2021 8:17 am
flyingcanuck
ALPApolicy
I understand that sentiment.AnonPilot wrote: ↑Sat Jun 26, 2021 11:40 amSometimes I slam them on to let everyone knows who’s in control (or not) of the airplane.ALPApolicy wrote: ↑Fri Jun 25, 2021 3:08 pmYou'll outgrow giving a poop.notwhoyouthinkIam wrote: ↑Fri Jun 25, 2021 8:17 am I mean, not having obnoxious passengers critique your landing is also a plus.
After years of trying to milk a smooth landing out of the approach, and accepting all the praise forthcoming, I reached the phase a couple of years ago where I just don't want to be the guy running off the end or off the side of a taxiway. I like to put the plane down reasonably close to where I plan to put it down. I have issues with former Q400 drivers (sorry to generalize) who are used to carrying power on until touch down, or carry it until just prior and then slap the thrust levers back. That residual thrust floats a 37 good way further than necessary.
(That said, I landed in my parachute last week in a tree because I thought I was all that and a bag of chips, so maybe disregard anything I have to say...)
notwhoyouthinkIam
As a former Q pilot, I am here to remind other Q pilots that you don't need to add power in the flare.ALPApolicy wrote: ↑Sat Jun 26, 2021 6:16 pmI understand that sentiment.
That's a common turboprop transition issue. If your Q pilots are getting through sim and line indoc and still doing that then your training department has an issue.ALPApolicy wrote: ↑Sat Jun 26, 2021 6:16 pmI understand that sentiment.
verified girls for adult fun - https://privateladyescorts.com - real girls for exclusive hookups
For Flap 35 true.notwhoyouthinkIam wrote: ↑Sat Jun 26, 2021 7:32 pm As a former Q pilot, I am here to remind other Q pilots that you don't need to add power in the flare.
If you are at Flap 15 and flaring at or below Vref, with intentions of touching down at or near your aiming point, quite often you do need a touch of power to prevent a "very firm" landing.
I don't know what Encore does, but Jazz has a procedure where you can add 10 Knots to the Flap 15 Vref on a normal landing, runway length permitting. If you do this you rarely need to add power in the flare. This also helps at busier airports to fit in with the jets.
it's not really about "can" in my mind. "Can" you land a Q at vref without adding power. Yes you can, but you defs cant walk it back to idle b4 touchdown, not if you are at or close to vref. I find it is more of a mitigating risk issue, if your trying to touch down without the additional power that close to ref, your margin of error is very small, if you flair abit too high (smash), loose a gust (smash), get hit with minor windshere (smash). Or worse case scenario tail strike. Either that or you wind up adding the power later on in your flair to compensate for the error. Which, now you are right where you started. I've noticed that if you are 5-10 kts above vref, and you add about 5 % power once in flair attitude then you consistently land with about a 4 degree nose up attitude, which I think is a safe but effective use of the limited pitch authority we have in the Q. The problem comes in when you are way over ref or add way too much power and are landing with like 1 degree pitch, that's excessive and you notice it with you landing distance. I make it my goal every landing to touch down and have the aircraft stable below 60 kts, within 4000 ft runway.airway wrote: ↑Sun Jun 27, 2021 10:42 amFor Flap 35 true.notwhoyouthinkIam wrote: ↑Sat Jun 26, 2021 7:32 pm As a former Q pilot, I am here to remind other Q pilots that you don't need to add power in the flare.
In the short term, this is a good way to maximize the size of the fleet and in the long term, obviously this is good for the corporation.
bobcaygeon
How is this any different than doing the red-eyes from YVR/YYC to YYZ/YHZ, etc? Did you read anything factual that said its dedicated crews ? I haven'tdigits_ wrote: ↑Wed Jun 23, 2021 7:14 pmDoes it?Longtimer wrote: ↑Wed Jun 23, 2021 6:47 pmBeats the S..it out of not working. Lots of pilots enjoy the steady wages earned from Large Cargo Air operators.Re: WestJet Dedicated Freighters
Post by digits_ » Wed Jun 23, 2021 9:06 am
Does that mean that recalled junior pilots will have the joy of flying night freight for the next 10 years?
It's probably safe to assume that if the junior westjet pilots wanted to fly night cargo, they would have gone to a night cargo operator.
I haven't flown night cargo, but I did night medevac, and I can honestly say I would take a non aviation job over going back to the night flying any day.
That's what my question was: if there would be dedicated crews or not. If junior crews would be stuck on freight only for the next few years. So no, nothing factual, just asking in the hope someone would have known the answer.bobcaygeon wrote: ↑Fri Jul 16, 2021 7:15 amHow is this any different than doing the red-eyes from YVR/YYC to YYZ/YHZ, etc? Did you read anything factual that said its dedicated crews ? I haven'tdigits_ wrote: ↑Wed Jun 23, 2021 7:14 pmDoes it?
There’s no junior/senior when it comes to bidding schedules….digits_ wrote: ↑Fri Jul 16, 2021 8:01 amThat's what my question was: if there would be dedicated crews or not. If junior crews would be stuck on freight only for the next few years. So no, nothing factual, just asking in the hope someone would have known the answer.bobcaygeon wrote: ↑Fri Jul 16, 2021 7:15 amHow is this any different than doing the red-eyes from YVR/YYC to YYZ/YHZ, etc? Did you read anything factual that said its dedicated crews ? I haven'tdigits_ wrote: ↑Wed Jun 23, 2021 7:14 pm
Does it?
notwhoyouthinkIam
"Spread the shit around" is not an industry standard, so I'm not surprised that some aren't aware of it.
WestJet Puke
No need to disparage potential WJ cargo night flying. There are a some guys in our midst who enjoy the night flying, who will happily bid the cargo stuff. For some folks, flying in the o'dark hours, the lower-keyness of it (want to say showtime was only 45 minutes prior, on the cargo side), no airport terminals and security, plus no pax and fa drama sounds awfully good.
notwhoyouthinkIam
Benefits of flying at night:WestJet Puke wrote: ↑Sat Jul 17, 2021 5:24 pm No need to disparage potential WJ cargo night flying. There are a some guys in our midst who enjoy the night flying, who will happily bid the cargo stuff. For some folks, flying in the o'dark hours, the lower-keyness of it (want to say showtime was only 45 minutes prior, on the cargo side), no airport terminals and security, plus no pax and fa drama sounds awfully good.
- Less likely to have GDP
- No late passengers
- No cranky flight attendants
- Less likely to have to wait for gate/stand
- No worrying if the bumps are too much for the pax
- No pax announcements
- No waiting for pax to deplane before heading to the car
ALPApolicy
I would add: Less likely to meet someone who will tell you what their pronouns are.notwhoyouthinkIam wrote: ↑Sat Jul 17, 2021 9:35 pmBenefits of flying at night:WestJet Puke wrote: ↑Sat Jul 17, 2021 5:24 pm No need to disparage potential WJ cargo night flying. There are a some guys in our midst who enjoy the night flying, who will happily bid the cargo stuff. For some folks, flying in the o'dark hours, the lower-keyness of it (want to say showtime was only 45 minutes prior, on the cargo side), no airport terminals and security, plus no pax and fa drama sounds awfully good.
Mostly Harmless
I identify as a Toaster.ALPApolicy wrote: ↑Sun Jul 18, 2021 7:17 am I would add: Less likely to meet someone who will tell you what their pronouns are.
notwhoyouthinkIam
I'm a broomMostly Harmless wrote: ↑Mon Jul 19, 2021 1:37 pmI identify as a Toaster.ALPApolicy wrote: ↑Sun Jul 18, 2021 7:17 am I would add: Less likely to meet someone who will tell you what their pronouns are.
Eric Janson
Freight flying is not necessarily a night operation any more than passenger flying is exclusively a day operation.digits_ wrote: ↑Fri Jun 25, 2021 9:38 amIf you are signing up for a job flying pax, somewhat during daylight hours-ish, and that suddenly changed to a full night freight schedule for the next few years (my original question/premise), I'm sure quite a few pilots would be unhappy with that.
But hey, good for you if you don't mind, if it scares other people off, it will only be good for your seniority number!
My Company was one of the first to remove the seats from our aircraft and start flying cargo. Didn't notice much difference in timings vs passenger ops.
In the beginning we couldn't overnight in China so we flew out and back with 6 Pilots. We lived on board for 2+ days. Nowhere near as bad as you might think.
I did multiple "Eastbound around the World flights" and even flew 15+59 non stop with cargo on board. Didn't know the aircraft could do this.
Most of us didn't mind the change at all.
Personally - I enjoyed the challenge.
Would be an even greater challenge doing it for 10% less!
notwhoyouthinkIam
That's the difference between ALPA and ACPA.
Not the only difference, sadly.
ACPA = Management Training Club.
notwhoyouthinkIam
It sucks that you are having such a bad experience with your union. I was part of Teamsters for a short time, so I'm well aware of the stress and discomfort a shitty union can cause.acpaleaks wrote: ↑Fri Jul 23, 2021 6:26 amNot the only difference, sadly.
