Care to tell the inside joke?
The majority of problematic pilots are post-2022 hires. FWIW.
Did he see it?bobcatdriver wrote: ↑Sun Oct 05, 2025 7:11 pm [quote=co-joe post_id=<a href="tel:1345677">1345677</a> time=<a href="tel:1759382654">1759382654</a> user_id=53]
[quote=digits_ post_id=<a href="tel:1345008">1345008</a> time=<a href="tel:1758037602">1758037602</a> user_id=34065]
[quote=Blueontop post_id=<a href="tel:1345006">1345006</a> time=<a href="tel:1758033337">1758033337</a> user_id=45620]
Rumour mill saying he’s been shown the door.
The problem with the Halifax accident is they were conducting a non -precision approach in precision approach conditions. I don't believe they ever saw the runway until they ended up on it after landing short.pelmet wrote: ↑Mon Oct 06, 2025 10:23 am This incident reminds me of the Halifax one. At minimums, maybe a bit of a glow or very, very fuzzy lighting and then decided to continue in the hope that the indicated descent path would lead to the runway. In the case of Halifax, there were Airbus issues with the descent path where turbulence creates a sort of descent path recalculation which did not lead to the runway. In this case I am not sure if they were doing it visually based on the training captain stating he had visual reference or if the pilot flying continued descent on the cockpit indications which did not lead to the proper point on the runway.
I do believe that there is a general element to that. Regulators allow a company to have very little fuel left when they reach their alternate.
Wouldn't they still have had their diversion fuel and the extra approach fuel and the final reserve? Should be plenty to go missed, no?
I'll take as much as I think is necessary. I give a reason for the extra uplift - never hear anything further.
Typically tanker fuel is an economic decision, cheaper to haul it than pay for it at destination.Eric Janson wrote: ↑Wed Oct 08, 2025 8:50 amI'll take as much as I think is necessary. I give a reason for the extra uplift - never hear anything further.
It will depend on Location/Weather/Alternate/Client/Previous Experience.
I work for a global operator flying to all 7 continents. If I'm going somewhere new I will always take extra.
I've done flights where we tanker fuel up to Maximum Landing Weight.
The last two airlines I worked for implemented policies of a maximum of two go-arounds at destination. Apparently, someone did seven go-arounds on one of our jets that led to the policy at the former company.cdnavater wrote: ↑Wed Oct 08, 2025 10:17 amTypically tanker fuel is an economic decision, cheaper to haul it than pay for it at destination.Eric Janson wrote: ↑Wed Oct 08, 2025 8:50 amI'll take as much as I think is necessary. I give a reason for the extra uplift - never hear anything further.
As for extra, if you can justify it, it’s not usually a problem with dispatch. The problem is when you have used your extra fuel and now you are on minimum fuel where a go around is almost an automatic diversion to your alternate airport, that is typically a psychological pressure. If weather is good, a go around does not automatically necessitate a diversion but you are now using your alternate fuel at destination, that is also pressure inducing because you have put yourself and everyone else in a position of get in or die trying.
I was in the back and experienced three go arounds at destination, clear skies but nasty winds, three times encountering wind shear, those poor bastards were on a line check. I chatted with them after we got in, no one said it but the fourth attempt almost certainly had windshear, they flew through it, because we had no other options at this point, used up all of our alternate fuel!
Anyhow, worrying about diverting should not be a reason to not go around when needed, we preach it at Jazz, no one will get called in for doing the right thing, unless of course it’s self induced and often, that will result in some remedial stable approach and landing SIM training.
Diverting after the second go-around was policy at every Airline I've worked at.
The correct thing to do is plan ahead. If conditions are marginal then a diversion is a reasonable course of action.cdnavater wrote: ↑Wed Oct 08, 2025 10:17 am Typically tanker fuel is an economic decision, cheaper to haul it than pay for it at destination.
My longest diversion to an alternate was two hours. Weather at the alternate was great but things can happen in a two hours and I was worried about another aircraft becoming disabled on the runway in that time period. Perhaps worrying too much but asked Arctic Radio to monitor notams for me as I did have a couple of other airports along the way(but with no fuel available).Eric Janson wrote: ↑Thu Oct 09, 2025 1:35 am
I've done flights where the alternate was in another country (Africa) and flights where the alternate was over 5 hours away.
For years I did a flight where the alternate was 2 hours away - never diverted. Then someone not familiar with the operation diverted. This caused so many issues that the client wanted extra fuel taken on these flights. We were then landing with 4+ hours of extra fuel - fine with me!
cdnavater wrote: ↑Sun Oct 05, 2025 7:18 pmDid he see it?bobcatdriver wrote: ↑Sun Oct 05, 2025 7:11 pm [quote=co-joe post_id=<a href="tel:1345677">1345677</a> time=<a href="tel:1759382654">1759382654</a> user_id=53]
Care to tell the inside joke?bobcatdriver wrote: ↑Thu Nov 06, 2025 3:03 pmcdnavater wrote: ↑Sun Oct 05, 2025 7:18 pmDid he see it?bobcatdriver wrote: ↑Sun Oct 05, 2025 7:11 pm [quote=co-joe post_id=<a href="tel:1345677">1345677</a> time=<a href="tel:1759382654">1759382654</a> user_id=53]
And if he lost sight of the door, would he just keep walking towards it and hope it opens on its own?
If they are putting junior FOs into instructor positions, does that not mean that more senior pilots are not applying? Or, does the company prefer junior pilot salaries in the training department?altiplano wrote: ↑Wed Nov 12, 2025 9:13 am You get these junior FOs that go into sim instructor positions to avoid junior schedules, then they upgrade and stay in training, sim instructor, maybe line indoc, plying their hopeful road to become checkers, avoiding their lack of seniority. They're a pretty big deal.
