The 40 Degree Flap Question
By the way, I just don't get the problem with using the flaps that are available and the airplane was certified to use..
Over the past few years, I see more people using climb flaps when taking off with a beaver and using take off when landing. Do you think DeHavilland was stupid?? Why do you think they call it take off flap?? Or landing flap for that matter. Why would you want to take off or land at a higher speed than you need to?? Other than a severely gusty X wind, I always use them for taking off or landing.. That is the way the airplane was designed.. As for the twin otter, I will sometimes only use 30 if it's a gusty x wind (25+) or glassy water but other than that it is the full 37 1/2.. Sometimes, I've even been known to use the dreaded 30 for t/o. For those of you in a cessna, they put 40 on it for a reason.. Think about it..
I just don't get why people are scared to use their flaps.. They are there to help you.
Idriveplane
I took my car out one night and measured it and thats what it came out to (very roughy). Agreed though, can be a lil short if one comes in hot. I love the braking action we have now after those warm daysYou think it's 1700 feet? I'm sure it's gotta be shorter than that... 1500?We should go out there and pace it someday we're bored
Edit: I stand corrected - it's 1800 on Google Earth this year, last year and the year before 1500 & 1600 or so. Seems awfully short eh? I don't recall if you were around last year but it is a good 10 feet wider this year.
- Driving Rain
I thought 40 degrees was just there cuase the designers were bored though. Obviously they had no idea what they were doin, just really loaded off of cheap beer.
I carry my crucifix
Under my deathlist
Forward my mail to me in hell
Liars and the martyrs
Lost faith in The Father
Long lost in the wishing well
Wild side
Under my deathlist
Wild side
- Rudder Bug
DHC-2 and use of full flaps
This accident report speaks volumes about the use of flaps with a Beaver
http://www.tsb.gc.ca/en/reports/air/200 ... 4c0098.asp
- Rudder Bug
- Cat Driver
It is ingenuous to suggest that there is any inherrent danger in flying any certified aircraft within its design limits and using the flaps for the purpose they were designed.
Incorrect loading, incorrect airspeed control or incorrect attitude for said airspeed is not the fault of the design.
Airplanes do not crash themselves, pilots crash airplanes.
just curious
- Rank Moderator
- Rudder Bug
That guy was an examiner???I got docked on a flight test once I was asked to do a "normal landing" and used full flap on a 150 and got told I was doing and emergency landing and had to do it again.
- Cat Driver
This is what I tell pilots on a checkout:
Whatever flap setting you normally land in that's the one to use in an engine failure. I think that if you normally land with 30 degrees adding 40 when the engine quits, is a bad idea. The approach attitude is already different enough when gliding, no need to add an unusual flap setting in as well.
The full flap power off landing, is encouraged whenever possible. Ideally I want to see full flap approaches with the power coming off just before the flare (do not carry power into the flare to smooth the TD)
In the Beaver, I start by using just a bit more than t/o flap for landing, then slowly increase the amount of flap to the landing mark. For normal ops I use just slightly less than landing flap, (better aileron control) and landing flap when needed.
I think the worst thing you can do in a Beaver is lose the engine and try gliding in with full flaps.
In any other airplane full flaps unless its really gusty.
Comments ?
Comments ?
There's no point on quoting any single person, since there are many who are talking about 'people being afraid of flaps' and about 'the designers not being stupid' etc.
I don't think anyone is afraid of using flaps. When used in inappropriate situations they can produce problems: ie full flaps in gusty x-wind conditions in the cessnas, full flaps at gross on larger aircraft, ect. Some of those can be more dangerous than others, mostly depending on ones experience.
The idea that they were designed in and thus are inherantly always safe to use doesnt make sense. Obviously the Cessna engineering team is not made up of idiots, but they don't expect the pilots to be idiots either. It's akin to saying that the engine primer was designed into the plane, so it must be a good idea to use it as much as / whenver you like... but we all know different amounts are required for different conditions and should only be used at different times.
Sure, full flaps are a tool that's there to help you fly the plane. Just like emergeny power, alternate air, or the electric engine starter. Use them to make your flying easier, better, and safer.. at the right times, in the right conditions.
Flaps beaver
Flaps on the beaver I found to be tricky to get used to I guess. I suppose in less than two months we'll all be back at er, so now's a good time to start thinking about it again. My memory is horrible so I think this is how I was doing it:
On Normal landing, powereded back some maybe 20-25 inches, when the speed came around 85-90 (I think 85-90), I just slowly added flaps a few pumps at a time. The amount all depending on the lake and my desire to descend. Sometimes I'd just give a pump or two. Generally in the last 100-200 feet, I'd bring the flaps to take-off or a little more than that. And thats it.
If I remember correct here, with take-off flap on a not-so-gusty day you could approach at 60 knots (if you feel like it...various factors and what-have-you), and land the beaver in in swimming pool and still need to step taxi to the other side.
I rarely used landing flaps because I just didn't need to. But I'd have no trouble using them. As for Full flaps, used them twice ever on landing and that was two more times then I needed too. I just ran out of elevator and got lucky that my float tips were up.
Anyhoo...crucify me if you must...
I think I've confused 'landing' with 'full' flaps. The last notch of flap in a Beav is not supposed to be used on floats, but you can (unless its in the limitations) under the right circumstances.
That is all.
That is all.
xsbank I don't think whether the aircraft is on floats or wheels or anything else for that matter will affect the limitation imposed by DH: "the use of FULL flap is only required for emergency landing in very restricted areas" which is what is says in the AFM. It makes no destinction between the landing gear configuration.
As for the guy who claimed the use of 40 flap was incorrect for a normal landing on a flight test, I would have knocked him in the head with the POH, opened to the page with the landing checklist itemizing: "FLAPS..... as required"
Well that depends on what airplane you are talking about. As mentioned, the DHC2 is not designed for full flap landings except in exceptional circumstances - i.e.: not a nice happy return to your three-mile-long lake of a base. The 206 is limited to 30 degrees, and I believe the old 172's with 40 flap were limited to 30 when on floats as well."There is nothing wrong with full flap landings.. Thats what full flap was designed for."
I have heard of a couple who weren't so lucky...As for Full flaps, used them twice ever on landing and that was two more times then I needed too. I just ran out of elevator and got lucky that my float tips were up.
- Cat Driver
For those of you who have difficulty figuring out how and when to use different flap settings here is the answer.
http://i43.photobucket.com/albums/e353/ ... f4e977.jpg
Problem solved, you will never have to worry about what flap setting to use.
hotspur666
The Walter Otter, full flaps...35 knots and
IT STILL FLOAT AWAY!!!
A touch of reverse make it plop down just where you want.
(We're talking with the Barron leading edge here.)
However, careful of crosswinds...
Still, no commercial airplane can fly as slow as the Walter Otter.
- Rudder Bug
Hotspurr,
Trevor had the right flap setting. A tree buted a strut and he lost a wing. We thouhgt the main cause was the absense of a tail ski and wet snow, which streched his takeoff to the point where he had a split second to take a vital decision. He took the wrong one.
hotspur666
Could somebody explain to me THAT accident?
http://aviation-safety.net/database/rec ... 20031216-0
First, how can you operate an Otter on skis without tailwheel skiis???
If you dont need skiis on the fragile tailwheel, you dont need skis at all!
And how can someone NOT takeoff an Otter on a 3200feet runway?
You only need 500 feet, no wind.
Maybe they did NOT have the Barron mod...
hotspur666
- Rudder Bug
Hello Hotspurr,
I also operate without a tail ski these days. The snow is so hard that the tailwheel does its job. We have lots of ice patches and more use the wheels/brakes than the straight skis.
I once broke a tail ski an a long takeoff with a stoneboat in rough hard snow. It swrilled around so bad and poked big holes in the lower fuselage side.
hotspur666
