Airplane into building in Richmond.
rsandor
Post by rsandor »
There are some rumours on another forum that the landing gear was not coming down, and the pilot was circling to burn off gas before landing.
Does this make sense to any of you? Cuz it doesn't to me...
I dunno, it just seems really weird how the plane could have gotten itself into that situation... I'm sure there's a simple explaination, but I have no idea what it might be..
200hr Wonder
Post by 200hr Wonder »
Up the thread does it not say the gear was down? And I would think if they where landing 08s in YVR they would have him circle out over the water in the Steveston area so he could do a quick right base to landing when he decided he was ready.
GottaFly
Post by GottaFly »
the media has been having a hayday with all these airliners having gear problems at YVR in the last little while. Pasco and Air China in the same day a few weeks ago, and then I think the next day it was an Air Canada A320. Methinks it was the media jumping to conclusions again. Earlier in this feed someone mentioned the aircraft being parked at Aviat Esso earilier that day.
GF.
xsbank
Post by xsbank »
The roof of the Richmond Centre is large enough to land a small jet...
invertedattitude
Post by invertedattitude »
Little to no fire damage on impact, burned off a bit too much fuel?
broompusher
Post by broompusher »
Has anyone been able to find the ATC feed? That would certainly clear up a few questions and speculations. I looked on liveatc.net but the feed for the time of the accident is not currently available.
My condolences to the family, friends and co workers of those involved
WTF, over
A girl I used to date called me up and told me what she'd heard (happened to be about a block away when it happened) said it sounded like the aircraft had gone to full power and it "sounded like it was on one engine before I heard a crash" she called me just shortly after 4..
The media has done a fine job of skewing all the facts so far. Doesn't suprise me. Other than a couple of the flight schools I know at ZBB who operates senecas? private? or?
Regardless.. my thoughts and condolences go out to the friends and family of the lost pilot.
Expat
Post by Expat »
Another twin that cruised to the crash site? :shock:
Justwannafly
Post by Justwannafly »
Rowdy wrote:The media has done a fine job of skewing all the facts so far. Doesn't suprise me.
You mean to tell me that there is no such thing as a twin Cessna 172 like one report I heard? :)
80% of the time the press get's it 90% wrong :? :(
bob sacamano
Post by bob sacamano »
Rowdy wrote:A girl I used to date called me up and told me what she'd heard (happened to be about a block away when it happened) said it sounded like the aircraft had gone to full power and it "sounded like it was on one engine before I heard a crash" she called me just shortly after 4..
Wow, your ex is good.
:smt109
rigpiggy
Post by rigpiggy »
According to the registry, hfd is a 1972 pa34-200. this would be unturboed, unless stc'd at sea level that shouldn't have been a problem. Rampant speculation won't really help, however maybe they'll stop building hirises around yvr.
the PA-34-200 Twin 6, first flew in October 1969 with fuel injected 150kW (200hp) IO-360s. Production deliveries of the initial PA-34-200 Seneca began in late 1971.
Handling and performance criticisms were addressed from the 1974 model year with the PA-34-200T Seneca II which introduced changes to the flight controls and, more importantly, two turbocharged Continental TSIO-360
I was there when c-gvof crashed just short of the dyke on approach to 30. it hit the soil preload for a new condo complex going in, bounced and hit the power lines.
AirAddict
Post by AirAddict »
I know for a fact there were no Sennecas at the Avitat that day...
isn't a 200 a seneca 2 and a 220 a seneca 3?
200hr Wonder
Yes but it is a 200T if it is Turbocharged.
Aren't all 200's turbo charged?
I thought the 1 was the only non-turbo seneca?
MichaelP
Post by MichaelP »
I don't like the way the media report these things...
But the fact that some of you resort to very poor use of the English language using words like the F*** word makes me wonder about the people who write on this forum.
So on the one hand you've got the media and their bad reporting, and on the other pilots who profess to be professionals but can't write in a decent manner.
Some of you need soap in your mouths, and your keyboards.
The fact is someone lost control and hit a building in an aeroplane.
We should show professional respect and not give the media a hint that we might be anything less than educated respectful people.
Lost in Saigon
Post by Lost in Saigon »
the_professor
Post by the_professor »
MichaelP wrote: The fact is someone lost control and hit a building in an aeroplane.
In that case, you're going to have to get the mods to delete all the archived threads on here too.
Alex YCV
Post by Alex YCV »
rsandor wrote:
Not hard to see the angle that the plane went in, right wing down about 30-40 degrees. I think we aren't seeing much of the plane because it looks like the bulk of the plane hit above and below floors, which means that it probably went all the way in until it hit something solid, like maybe the wall between the units or an interior post.
The angle wouldn't seem to suggest a plane dropping nose down out of the sky through... hmm.
This is a my sig... I hope you like it.
Hapless
Post by Hapless »
From a friends coworker who saw the A/C at Shell that day. Was on the ramp watching this unfold...
-Pilot started L/H engine
-4 starts made on R/H engine before it ran. Previous 3 starts ran, but for less than 10 seconds.
-run up performed at wide hotel
-a/c depated, noticed hard yaw to right
-coninued close to ground not climbing until a/c disappeared from his point of view at the Shell.
Sounds like R/H engine troubles to me.
Thoughts and Condolences to friends and loved ones.
Pratt
Post by Pratt »
Global news reporting that the pilot who is deceased was 82 year old Peter Garrison(sp) from Maple Ridge, who owned the plane. When it hit the building it continued through the apartment until it hit the elevator shaft.
RIP
PilotFlying
Post by PilotFlying »
The Globe And Mail quotes CTV as reporting the aircraft to be an "eight-seater Piper-Cessna twin-engine aircraft".
I should personally drive down to the studio in my Ford-Toyota and punch these reporters in the face.
What a joke. :roll:
Don't like it? Don't read it.
privateer
Post by privateer »
Peter is the same guy who clipped the fence at Pitt Meadows and crashed on the side of the runway. Poor guy. Maybe TC should rethink their medical standards. 80 year olds tend to forget things, like procedures.
Go Guns
Post by Go Guns »
Condolences to Peter's friends and family.
A speedy recovery to the folks in the building.
Justwannafly
Pratt wrote:Global news reporting that the pilot who is deceased was 82 year old Peter Garrison(sp) from Maple Ridge, who owned the plane. When it hit the building it continued through the apartment until it hit the elevator shaft.
RIP
yea like I said above....90% wrong 80% of the time
privateer wrote:Peter is the same guy who clipped the fence at Pitt Meadows and crashed on the side of the runway. Poor guy. Maybe TC should rethink there medical standards. 80 year olds tend to forget things, like procedures.
Maybe you should wait to see what TSB report says B4 coming to conclusions....otherwise your no better then the press
