Ok Big Iron drivers, I got some questions from ATC
invertedattitude
Re: Ok Big Iron drivers, I got some questions from ATC
Post by invertedattitude »
Rockie wrote:
invertedattitude wrote:I thought I read somewhere that TCAS switches to TA only below a certain altitude? Or is that only on the ground.
It varies from aircraft to aircraft, but generally RA's are inhibited below approximately 1000 feet. Also if the other aircraft is not reporting mode C (altitude) then RA's will not be generated at any altitude.
