Originally probably, I can calibrate it against the master orifice or against another unit. Besides this is on a private a/c by the owner, sure I just have to move the duct tape holding the jug to the case to get to the hole i drilled in the head to do this, but it should be pretty easy and accurate enough.Dr. Mcillicuddy wrote:Im sure that it has a calibration cert with it.![]()
Compression question
Re: Compression question
