hiring at Jazz!!!
bravowhiskey
Re: hiring at Jazz!!!
Post by bravowhiskey »
I just had a running application for over a year but kept updating it. Update your application every month is what I was told to do. Keep an eye on the amount of "views" to your resume as well. I heard when I got hired that 2 or more views was a good sign. I had 2 or 3 when I got called, good luck!
sweet, I got 4 views since last week!
teacher
Post by teacher »
Also make sure your resume is "nonsearchable" which means that only those jobs you have applied for will "view" your resume. If it's searchable you'll get emails and views from other employers that have searchs that match your listed skills set, that may throw off your count.
https://eresonatemedia.com/
https://bambaits.ca/
Franky Jr
Post by Franky Jr »
Hey Folks,
If a fellow does get on with Jazz and opts to commute, do the travel benefits kick in right away or do you have to wait until your gs or line in doc is done?
Stinky
Post by Stinky »
Pretty sure it kicks in right away now.
Pourdu_fun
Post by Pourdu_fun »
Yes, just for you. The reste of your family will be on after 6 months.
Pourdu
bravowhiskey
as a new hire can you actually commute? if so how many days per month would you be away from home?
JazzJetDriver
Post by JazzJetDriver »
"as a new hire can you actually commute?"
Yes.
"if so how many days per month would you be away from home?"
Depends. If you are on reserve...which you most probably will be, it depends where you live and where you are based.
Pourdu_fun
On reserve its 12 days off per month.
Pourdu
Stinky
Post by Stinky »
As pourdu said reserve get 12 days off per month. You could bid to have your days off bunched together to facilitate commuting but you may occasionaly have a single day off stuck in there. Also, you will have to commute in the day before if you're reserve A and may not catch the last flight out on your last day of reserve depending on your assignment. As you can see, a lot of your days off will be lost so you definitely won't be home for 12, I'm guessing between 7 and 9 depending on your sched and where you commute to.
First groundschool in March I hear.
Canoehead
Post by Canoehead »
Franky Jr wrote:Hey Folks,
I'm pretty sure it is pass privileges only between your base and your 'home' airport (ie YYZ-YYC or YYZ-YOW etc...). I may be wrong, but I'm pretty sure you still have to wait for 6 months for the full package.
Mclovin
Post by Mclovin »
Your passes kick in from day one and you can use them for anywhere. There are no restrictions. I commuted during line indoc and for my first 6 months with no problems. It is doable just not a lifestyle that I liked personally.
Goodluck
following our will and wind we may just go where no one's been.
TopperHarley
Post by TopperHarley »
The jumpseating (ie. OAL, other airline agreement) passes take 6 months for you to obtain. But your travel priviledges start day 1 of your g/s, at least that's how it was last year.
Stinky
Post by Stinky »
I've never actually used another companies jumpseat, but how would they know your start date if you use your license and RAIC as identification?
Post by . . »
C-HRIS wrote:The jumpseating (ie. OAL, other airline agreement) passes take 6 months for you to obtain. But your travel priviledges start day 1 of your g/s, at least that's how it was last year.
C-HRIS: Your correct about the 6 month wait for the OAL tickets. The jumpseat stuff starts from the day you get your red pass.
TopperHarley
My mistake, you guys are right. Thanks for the clarification.
dream_big
Post by dream_big »
sorry, I still a bit confused here. Your travel benefits kick in on the first day of ground school correct?
also when you guys opt to commute, how exactly does it work. You lets say live in YOW and are based in YYZ. So whenever you work, you just commute back and forth between yow-yyz. How does that work? Are you put up somewhere in yyz? what if you bid and dont end up getting all your shifts bunched together? Just hoping if someone would clarify on how this works.
Chuck Yeagermister
Post by Chuck Yeagermister »
dream_big wrote:sorry, I still a bit confused here. Your travel benefits kick in on the first day of ground school correct?
Correct! your flight benefits kick in your first day of ground school.
If you want to commute, it is your responsibility to get to work on time. That means checking the loads and wx, making sure you can show up on time for work. Where you stay while in YYZ is up to you, there are quite a few crashpads around the airport in YYZ. Bidding all depends on where you sit on the list, if you are fortunate to get all your days bunched up and likewise for days off that will save you less time commuting. If your talking about going home during groundschool and sim. You get the option of going home on a pos ticket or staying in your hotel in YYZ. Jazz pays the bill for all that while in training.
Canoehead
Post by Canoehead »
Mclovin wrote:Your passes kick in from day one and you can use them for anywhere. There are no restrictions. I commuted during line indoc and for my first 6 months with no problems. It is doable just not a lifestyle that I liked personally.
Goodluck
Good to know. They made changes to the pass system during the 05-07 hiring 'blitz'. Just playing the devil's advocate here, but make sure you ask and get a clear answer about it during your interview process, just in case they have changed things again since the hiring stopped. It's Air Canada's pass system, so they can change the rules at their discretion. You could try to get the info from the Jazz pass bureau in YHZ if you wanted the black and white of it all.
It's nice to have that ability now from day one to travel. Good luck applicants.
navajo_jay
Post by navajo_jay »
Got called today!, Interview in 2 weeks in YUL good luck!
TopperHarley
Jay (and anyone else getting a call)
Here is a list of sample questions from an old thread. They pretty much summed up my interview perfectly. There are some duplicates, so just weed thru these questions and try to come up with an honest answer. You'll probably be asked about 10-15 questions or so and they'll most likely resemble something from below.
Personnel conducting the interview wanted specific examples from you’re career when
answering the questions. Follow the SPARE
S – Situation Briefly describe the situation where the problem occurred.
P – Problem State the problem faced.
A – Action State what you did to resolve the problem.
R – Results What happened (good or bad, successfully or unsuccessfully).
E – Experience What you took away or learned from this event.
S/P – Situation / Problem
A – Action
R – Result
1) Tell us about yourself?
2) Why do you want to work for us?
3) What do you know about our company?
4) How did you get into aviation / how did you become a pilot?
5) What do you like / dislike about your present job?
6) Have you ever failed a checkride?
7) Does your boss know you are here?
2) Tell us a time when you made a mistake and what did you learn from it.
3) Do you have any incidents or accidents?
4) What will the biggest challenge be for you seating in the right seat?
5) How do you feel about seating in the right seat for 10 years?
6) How will you survive on our starting salary in Toronto?
7) Tell us about you’re career to date and the positions you held.
Tell us a time when outside factors influenced you at work.
9) Tell us an example of a satisfying work experience.
10) Have you ever failed a medical?
11) Have you ever had to take control of an aircraft from a First Officer?
12) Have you ever attempted to train anyone that was “untrainable”?
13) Describe a time when you went above and beyond you’re job description.
14) Have you ever had a conflict with a fellow pilot? How did you resolve that situation?
15) Describe a time when you would have liked to see more out of the managers in
you’re company.
16) Have you ever been unprepared for a flight?
17) What do you know about Jazz?
1. Tell me about yourself and how your aviation career led you to this point
2. What do you know about Jazz?
3. Why do you want to work for Jazz?
4. Why should we hire you?
5. Why would you be good at Jazz?
6. What do you think the toughest part of the transition to Jazz will be?
7. Do you think you have the skills to fly a jet?
8. Does anyone from your company know that you are here? (management)
9. Why do you want to leave your present job?
10. What will you miss about the job you are in?
11. Describe your daily life at your present job.
12. What do you do to prepare for a flight?
13. What is your goal before a flight?
14. What is the most important part of your job at wherever you work?
15. What is the most difficult part of your job at wherever you work?
16. Tell me a time when you were EITHER satisfied or dissatisfied with the company
that you work for
17. What was the most fun job you ever had?
18. What was the best job you ever had?
19. Have you ever had a personality conflict with somebody you worked with?
20. Name a time when you and an F/O butted heads.
21. Name a time when there was tension in the cockpit.
22. Name a time when you were at fault and took the blame for it.
23. Name a time when you made a mistake
24. Have you ever had to take control from somebody?
25. Has anyone ever had to take control from you?
26. Name a time when you had to discipline somebody
27. Name a time when you had to turn down a flight
28. Name a time when you rushed into something?
29. Name a time when you had to confront somebody for breaking the law or a
regulation or a procedure.
30. Name a time when your piloting skills came into play.
31. Tell me a time when you had to get a group of people to do something they
refused to do.
32. Have you ever had to force and issue?
33. Have you ever had to motivate or diffuse a group in order to achieve a goal
34. Tell me a time when you had to persuade a group to do something they didn’t
want to do
35. Have you ever let the pressure get to you?
36. Name a time when you worked as a team and didn’t accomplish your goal.
dream_big
Post by dream_big »
When does salary commence for new hires? After ground school or does it commence on first day?
swervin
Post by swervin »
It starts on day 1 of Groundschool. I believe it's about $36000 a year to start. After all your deductions I think it's about $2000 a month plus per diems of probably between $300-$700 a month once you start flying the line. Not sure if per diems are paid during training.
TopperHarley
swervin wrote:It starts on day 1 of Groundschool. I believe it's about $36000 a year to start. After all your deductions I think it's about $2000 a month plus per diems of probably between $300-$700 a month once you start flying the line. Not sure if per diems are paid during training.
Yes per diems are paid during your training. I dont think its the regular pilot rate though and I dont really remember what they were. Hotel and travel is all taken care of all throughout your training.
qwert
Post by qwert »
navajo_jay wrote:Got called today!, Interview in 2 weeks in YUL good luck!
COngrats,
Your on your way to:
making 900 bucks every 2 weeks. Cant even whipe your ass with that...
Getting shafted by benefits cause they go up every year and ALPA does nothing about it.
Living in a crash pad while all your other friends are earning a descent income with real paying jobs and nice homes.
Paying close to 100 bucks a month to ALPA which is worthless.
Gettting your pay deducted so much that you cant justify even showing up for work...
Dont worry things will get better with the next contract. :lol:
GOOD LUCK...
mattedfred
Post by mattedfred »
COngrats,
GOOD LUCK...
hey qwert, do you or have you ever worked for an ALPA carrier? what would you like ALPA to do about it? what do you think ALPA could do about it? Why do you think ALPA isn't worth 1.94 of your income?
