Small plane crashes near Quebec City airport
No Conflict
Re: Small plane crashes near Quebec City airport
Post by No Conflict »
Sincere condolences and heart felt thoughts go out to Crew, passengers and family... Another tragedy rocks our small family..
robbreid
Post by robbreid »
NTSB ADVISORY
National Transportation Safety Board
Washington, DC 20594
June 24, 2010
NTSB ASSISTS GOVERNMENT OF CANADA IN AVIATION ACCIDENT
The National Transportation Safety Board has dispatched an
aviation investigator to assist the government of Canada in
its investigation of the crash of a Hawker Beechcraft
Corporation King Air B-100 (C-FGIN).
At approximately 05:58 a.m. Eastern Daylight Time on June
23, the aircraft crashed near Quebec City, Quebec, Canada,
shortly after takeoff. Preliminary reports indicate 7
persons were fatally injured. There are no reported injuries
on the ground.
NTSB Chairman Deborah A.P. Hersman has designated air safety
investigator Ed Malinowski as the U.S. Accredited
Representative. His team will include a technical advisor
from Hawker Beechcraft.
The investigation is being conducted by the Transportation
Safety Board of the Government of Canada, which will release
all information on the progress of the investigation. The
agency's phone number in Canada is (1) 819-997-7887 (24 hour)
and the agency's email address is: airops@tsb.gc.ca.
Post by 55+ »
With the little bit of time I have in a A100(3000+), it can be a handful if you let it with those 4 bladed props and relative short wings, AF was an option on the A100 and the ones that I flew didn't have it. From what I read in the papers this particular airplane got to 500 ft and a bit so at that point you should have more going for you, however I certainly won't speculate. Of course the 200 was much better with AF and rudder boost and more power. If I am correct the A100 was Beech's first stand alone design for the turbine cabin class twins, the 90's had the same fuselage as the old Queen Air and the 200 had the same fuselage as the A100 but with t-tail, long tapered wings and more hp(850 ea), but I could indeed be wrong.
Condolences to family/friends/co-workers of those who died in this tragic accident.
Highflyinpilot
Location: Holy Hell, is that what you look like in the morning
Post by Highflyinpilot »
My condolences to the family and friends of all on board.
Were any names released on this one?
RenegadeAV8R
Post by RenegadeAV8R »
Highflyinpilot wrote:... Were any names released on this one?
The names are posted on the following website. It is in french (I could not find the equivalent in english), but pilote = pilot and copilote = co-pilot.
http://www.quebechebdo.com/article-4646 ... letee.html
Mister
Post by Mister »
Here is the translation of the above noted article.....Rest in Peace Andre...
The seven bodies of the victims of the crushing of plane of last Wednesday in Quebec were identified by the Office of the coroner.
It is about André Faucher and Dominique Lefebvre, respectively pilot and copilot of the plane. The five passengers were Nicole Brouard, Frédérick Dufour, Jacques Gagnon, Gérald Joncas as well as Norman Tremblay. For some days, the names of the victims circulated in mass media, nevertheless the coroner transmitted names in mass media in party today.
« Any information relating to reasons and circumstances of these seven deceases will be made public by means of the reports of coroner loaded with investigations, Miss Andrée Kronström. In view of the complicacy of this type of accident and as reasons and circumstances of the crushing of the plane are nowadays under inquiry by the Office of the security of the transport of Canada, several months will be necessary for the production of these reports », it was mentioned in the press release.
Ask and you shall receive!! But remember you have to ask!!!!
warner
Post by warner »
I read somewhere that Andre was from Manitoba, can anyone confirm that and if so I might have worked with him around Winnipeg.........thanks
FL020
Post by FL020 »
André was from Edmonton, AB - and flew in Peace River for some time. Rest in Peace André.
station60
Post by station60 »
My thoughts go out to the deceased family, friends. Tragic loss.
x-wind
Post by x-wind »
My sincerest condolences to all the families involved. I knew André personally and would like to attest to the good man I knew him to be.
skymarc
Post by skymarc »
RIP and condaleance to friends and family.
I heard from reliable source, no cockpit recorder or FDR, TSB investigator is pretty pissed off, " All I got to worked with is a burned up cratter"
Post by 55+ »
Don't think BE-A100 had CVR/FDR, nor was it a requirement. As for the TSB being"pissed off" well they do have investigative authority in order to establish a probable cause but do not have any regulatory authority. In their investigating process and findings(probable cause) they can only recommend, they can't order.
Percy
Post by Percy »
Actually a CVR IS required if the aircraft is configured for more than 5 passengers and if the aircraft is flown two crew. Aeropro had challenged the CAR's requirement for a CVR in the courts and subsequently got a waiver from TC for the CVR.
Old fella
Post by Old fella »
Must be new requirements cause when I was with TC we had a fleet of BE90/A100 and there was 1 Be200 in the Atlantic - none were fitted with CVR/FDR. I also know for a fact there are currently BE200's around in industry not fitted with CVR/FDR
flyinthebug
Post by flyinthebug »
Percy wrote:Actually a CVR IS required if the aircraft is configured for more than 5 passengers and if the aircraft is flown two crew. Aeropro had challenged the CAR's requirement for a CVR in the courts and subsequently got a waiver from TC for the CVR.
This is true. We also got a waiver from TC for our 1st A100..but we had to limit configuration to 9 seats or less (703) not 5, and ran it two crew at all times. As long as we abided by those terms, we did not require a CVR. 9 revenue seats in a PA31-350 or 9 revenue seats in an A100, same thing. Both under 12,500 and both can be run 703. Im not sure where the (5) seat limit comes into play? Anyone?
Twigs&Berries
Post by Twigs&Berries »
CARS 605.33
(2) Subject to section 605.34, no person shall conduct a take-off in a multi-engined turbine-powered aircraft that is configured for six or more passenger seats and for which two pilots are required by the aircraft type certificate or by the subpart under which the aircraft is operated, unless the aircraft is equipped with a cockpit voice recorder that conforms to section 551.101 of Chapter 551 of the Airworthiness Manual and section 625.33 of Standard 625 — Aircraft Equipment and Maintenance of the General Operating and Flight Rules Standards.
Benwa
Post by Benwa »
Twigs&Berries wrote: for which two pilots are required by the aircraft type certificate or by the subpart under which the aircraft is operated
That's why we can fly the King Air 100 without CVR... even single pilot.
--In his wrapup remarks, the FAA chief said, "If you think the safety bar is set too high, then your
standards are set too low."
Percy
Post by Percy »
If the aircraft is operated 703 (IFR), configured with 6 or more seats it can only be operated single pilot if a CVR is not installed. If the aircraft is being operated by 2 crew, either by regulation or customer requirement or due to equipment (funtioning autopilot required for single pilot operations) a CVR must be installed, unless a waiver has been obtained.
For accident investigation along with accident prevention I believe the $30,000.00 for a digital CVR (installed) is well worth the investment!
Rest in peace Andre', you will be missed.
