photofly wrote:More research...
TC AIM 3.16.9 says
Note that for NDB or VOR approaches that are not part of
the GPS overlay program described in Section 3.16.5.2.2,
pilots shall use ADF or VOR as the primary source for
final approach track guidance. For these approaches, and for
approaches based on a localizer (LOC) for lateral guidance,
pilots shall not use GNSS as the primary source for missed
approach guidance when the missed approach procedure
requires flying a published track to or from an NDB or VOR.
You are correct that you can use the GPS to locate the IAF.
But not, apparently, for missed approach guidance.
Sorry for dragging up this old thread, but this seems to be the only spot where Instrument flying with a GPS but no ADF is discussed. By my interpretation we're not reading this right, but we're very close. 3.16.9 says we can't use the GPS as the primary guidance for the missed approach with a "
published track" to or from a NDB/VOR. For example (all non-overlaid approaches):
Climb to 2200 on track of 261. (The final track from the FAF (a NDB) was 261) Left turn to "7B" NDB.
Clearly the 261 track is based off the FAF NDB. We must have a ADF here.
Now it gets a bit more fuzzy, for CYSB VOR/DME 04:
Climb to 3500 on R-035. LEFT turn direct to "SB" NDB.
The only track specified here is R-035, so we require a VOR and can't use GPS for this track. But there's no specific track to the NDB specified - just "direct" which could be many different tracks depending on your performance to 3500. Can we use the GPS to fly direct to the NDB where the track is not specified (after 3500)? A reasonable person will probably tell you that you can, but 3.16.9 says "when the missed approach procedure requires flying a published track to or from a NDB or VOR", and the VOR part of the missed approach procedure certainly qualifies, so a strict interpretation probably means you're out of luck.
However, CYOO LOC(BC)/DME 30:
Climb to 1500 on track of 302 (localizer track). LEFT climbing turn to 3200 to "SN" NDB.
Ok, so we've got a published track of 302 to 1500, but it's not to the NDB - it's following the localizer. Then there's a turn "to" the NDB without a track specified. Thus there's no published track to or from a VOR or NDB in this missed approach, and the prohibition against using GPS as the primary missed approach guidance does not apply. Just track the localizer to 1500 and then you're legal to navigate using GPS to the NDB.
And this one is pretty clear, CYQG ILS or NDB 25:
Climbing Left turn to "QG" NDB at 2400
No published track - just get to the NDB. We can use GPS for this missed approach.
