ATR versus Dash
midwingcrisis
Re: ATR versus Dash
Post by midwingcrisis »
Why the ATR-72 sells better than the Q400
http://theflyingengineer.com/2012/01/30 ... -the-q400/
imarai
Re: ATR versus Dash
Post by imarai »
Dash-8 territory..
rigpiggy
Re: ATR versus Dash
Post by rigpiggy »
last production figure I had shows over 400 q400's delivered. how many 72's have been delivered?
Beefitarian
Post by Beefitarian »
imarai where is that?
CL-Skadoo!
Re: ATR versus Dash
Post by CL-Skadoo! »
imarai wrote:Dash-8 territory..
Wouldn't want to put an ATR in there would ya?
Skyhunter
Re: ATR versus Dash
Post by Skyhunter »
imaria, would be no issue putting an ATR in there at all.
Donald
Re: ATR versus Dash
Post by Donald »
Beefitarian wrote:imarai where is that?
http://en.wikipedia.org/wiki/Honningsv% ... ort,_Valan
Beefitarian
Thanks Donald. Norway probably has a few spots like that. Add some winter WX and early darkness. Yikes.
yak8
Re: ATR versus Dash
Post by yak8 »
midwingcrisis thank you.
I got my answer.
Too bad.
Rudy
Re: ATR versus Dash
Post by Rudy »
So the Q400 out climbs/cruises the ATR but doesn't sell because it burns more fuel. What happens if you just pull the power back a bit?
imarai
Re: ATR versus Dash
Post by imarai »
You go slower and burn a little less fuel..
pilotman329
Re: ATR versus Dash
Post by pilotman329 »
onspeed wrote:In terms of cargo compartment the ATR have both forward and aft which make the weight and balance simpler.
So do the Dash Q4s, and they are way easier to trim when they are fully booked than the ATRs... Plus the Dash Q4s don't need a tail stand to be loaded, whereas the ATR 72 does. All of our customers using ATR 72 (mainly OK and LOT) have SOPs regulating the loding of the aft compartment only to started after the first passengers have / are boarded, so the chance of tail tipping is minimized. LOT even goes further and forbids a loading where the aft compartment will have more weight than the front. All that is unnecessary with the Dash, as it is pretty nose heavy.
bic
Re: ATR versus Dash
Post by bic »
station60
Re: ATR versus Dash
Post by station60 »
CL-Skadoo! wrote:
imarai wrote:The Dash-8 series carries ice much better than the ATR-42 -72 series. With the exception of the Q400, the ATRs are a wee bit faster in cruise.
Have you flown the ATR in ice? Because I will argue with you all day on that point. The Dash 8 does just fine with ice as does the ATR.
I've never flown a Dash-8, but the ATR42 & 72 carry ice just fine. If you people are referring to the Roselawn accident in 1994 as an example of how the ATR doesn't carry ice then you're out to lunch.
Re: ATR versus Dash
The ATR has a poor record in icing conditions relative to the Dash-8.
GARRETT
Re: ATR versus Dash
Post by GARRETT »
pelmet wrote:The ATR has a poor record in icing conditions relative to the Dash-8.
Pelmet, it's been said before, unless you have actually flown the ATR, how can you even comment on its icing characteristics? If you are referring to Roselawn, any large turboprop in the same conditions would likely have had the same outcome.
I've flown the ATR for 6.5 years in Canada and have never had an icing issue. Enough about the icing already, the ATR is quite capable of handling ice.
teacher
Re: ATR versus Dash
Post by teacher »
The ATR accident in ice was poor procedures that have been changed. They were holding with some flap down which allowd ice to accumulate behind the boots. On the dash we avoid that for this exact reason. I believe ATR operators have changed their procedures as well to avoid this situation.
