Slips are when the ball falls to the inside of the turn,
as a result of excessive top (outside) rudder. I used
one a couple days ago in a Citabria turning on final, to
slow it down to 55 mph so I could land on a 1000 foot
grass strip. ]]
Just so no youngsters gets the wrong idea; untill you have tens of thounsands of hours like the colonel its much easier and more reliable to get slowed down for shorter than usual strips with a long straight in stabalised approach. A slip is a vital tool to have, but you had better practise it a lot before using it to set up for a short landing.
On another note...I read somewhere that using a slip with much power on produces some unhealthy forces on the prop and airframe. Anyone know for sure if this is true and why?
Im talking about non-areobatic planes here of course, the sort of plane you might want to avoid pulling power to avoid shock cooling, but still need to because you didnt plan your desent far enough back.
