Ok, so it was a bad decision all around . How high up on the glidelope at the first 1/2 scale deflection ... 5-6 miles out ? 1/4 mile high ?captcrunch2013 wrote:In this case, the pilot's errors of judgment and skill were so damning that
they could not be left out.. Everything else was.
To the south, YGK is already showing the 30kts starting at the surface ... CYOW only has one surface-gust showing 16-17 knots just before their approach, otherwise had 6-7 knots sustained East/ENE til then (but that's 5 miles ahead right at the airport).
The report states 100kts airspeed on approach (an estimate ?) which is what the Flight-aware records for CF-EFQ are showing in Groundspeed. How is this measurement recorded ? With any icing catch involved ... what is the minimum airspeed speed suggested for an approach ? How easy is it really to dip down to an iced minimum speed if not ruling out the unexpectedly gust-prone crosswind conditions ?
On the southerly heading in the procedure turn the GS is 80kts, but turning Northeast during interception of the glideslope is 110kts GS. If the component got to be tailquartering ... it must have been a southerly one at the higher altitudes of the approach track for rwy 7 ( ~ 60 degrees true).
