Big Pistons Forever wrote:I should have said if upon reaching the MDA you don't have the runway environment in sight then you should go around.
I disagree. Fly at MDA until the point where you know the landing can't be safely executed anymore, even if you'd be visual by it. This point (VDP), for many aircrafts, would be where the 3 degrees glidpath from the threshold intercepts MDA. If the runway is long enough, that point can be moved slightly closer to the runway.
I do get your point about it being generally safer for people. Get away from the ground ASAP, and don't start fixating on the few pieces of ground you can see, slowly creeping down towards it. However, I believe it's still more effective to train to fly the approach to the real minimums (not only the vertical min, but also the horizontal one). When the weather is bad, you might not always have the luxury of finding an approach where you get visual way before minimums.
You have much more IFR time than me, so I'd like to hear more about it.
