goingnowherefast wrote:It is impossible for a Citation to conform to a 152/cub circuit. This was established several posts ago.
Nonsense. It was *stated* several posts ago, I don't agree that it's correct. Conforming to a circuit does not necessarily mean flying the exact same path that every other airplane flies. It means slotting in without f*cking up the established pattern. If it's just one NORDO, as in the quoted scenario, then fly a big loop and let him land, because he was there first.
Plus the scenario you quoted was a NORDO in bad weather and a Citation on an instrument approach. Please don't take comments out of context.
Correct, but the scenario given was a NORDO landing in minimum conditions, not landing below VFR. I've flown many times at VFR minimums. I don't see why "at minimums" is any different than "CAVOK". The VFR aircraft is established in the circuit. The IFR aircraft is joining an established circuit.
That's exactly how things normally go. IFR traffic makes radio calls, works out a plan with the other traffic. The guy in the cub knows that 3 minutes of fuel is one liter and less than the price of the coffee he bought on the way to the airport. But again, you are removing the context of the scenario.
I wasn't trying to remove the context, just to clarify that the situation is clear, from a regulatory standpoint. The VFR traffic in the circuit has right-of-way. Personally, I would be the first to offer to extend my downwind if an IFR aircraft was approaching and it looked potentially conflicting or if they asked me to. But if I was NORDO and not expecting an IFR arrival, i'd be damned startled to find a Citation on short final as i'm coming down my base leg.
A typical scenario...lands before the first 152 turns base again.
That's exactly what I call "conforming to the circuit". By all means, the IFR pilot should ask if the circuit can accommodate him. I'd bet that a lot of the time people will be accommodating. But if the circuit isn't skilled enough (yet, as in students) to accomodate, or if there are NORDO traffic that communication can't be established with, then the skilled commercial pilot must fall back to making do, by making their own gap.
