Wasaya caravan missing
pdw
Re: Wasaya caravan missing
Post by pdw »
Sidebar wrote:I think the TSB probably used "estimated" because they were using met data from an observation drone about two hours before the accident.
"Estimated" component data which KCAS values are based on, starting at 9:03 (represented by the light green line of the TSB flight data chart above dark-green/groundspeed) is pretty close. Maybe is a bit faster AS at a couple of spots ...
The "radiosonde" component-info (chevrons between 2500' and somewhere just below 5000') are given North at 20-25kts (looks like) for/after the early altitude ("5kts-NNE"/lowest chevron) where the northerly course started around 2500ft around the left turnout. IMO there must be at least the 20kt spread between these two speedlines for the middle of this five minute northerly climb .. in-between 9:03:10 and 9:08:30.
The first track data "9:03 to 9:03:34" includes "800fpm" for 10-15sec and the "100ft" lost right-after, which is signature of some brief performance increase, yet still ends up only 240ft of net altitude gained in that 34sec segment.
Following the +/- fluctuation and after another five minutes of climb to 9:08:41 there is obviously performance decrease (shearlike) where the Cargo Caravan transitioned into lighter/warmer West component moving at/above 5000' (indicated by radiosonde-infochart/wind-chevrons) near where the climb-rate ceased. Such relativewind reduction going-on ahead-of "event 1" is a secondary climb-performance loss coming alongside the primary one (the lift-degrading icing buildup/encounter described in the report).
pdw
Post by pdw »
rxl wrote:This airplane has a deplorable safety record.
27 years old (1990) with 36,063 hours on the airframe.
GyvAir
Post by GyvAir »
A more interesting number and more relevant to the initial comment would be the worldwide fleet hours.
pdw
Post by pdw »
Can you get an average?
GyvAir
Post by GyvAir »
pdw wrote:Can you get an average?
Tough to find real or current stats.
https://www.avbuyer.com/articles/jets-f ... -one-19970
8,400,000 fleet hours according to the above article from back in 2005.
7,000,000 hours/1522 produced to date = average of 2800
So, add 12 years of fleet flight time and 1000 new production units, minus retired and destroyed airframes and there's your average.
I'm sure it's been argued a thousand times that the Caravan accident statistics have more to do with pilot experience, mission type, runway conditions and the parts of the world that many of them operate in than the airframe itself.
pdw
Post by pdw »
GyvAir wrote:pilot experience, mission type
For this profile (mission type), namely the icing related accidents in the database of reports for this aircraft, there seems to be a mix of low and hightime pilots (pilot experience) in 60-70 that are in there.
