Rules are rules, for everybody. Flying a non precision approach to the MDA then fly along level to the MAP is NOT unsafe, nor is flying a constant descent to the MDA and miss from there. The rules say I can do it anytime I want, into any weather conditions I want if I announce in advance it's a planned miss for training purposes. That detail emphasizes my point, it's safe to the MDA, in any weather conditions, even with visibility solidly at zero.Rockie wrote: Golden eagle, rules aren't meant for just you, they're meant for everybody. You're thinking like the guy who doesn't believe speed limits should apply to him because he's a good driver, and mistakingly believes he's the only person who will get hurt by his actions. You're wrong.
It only becomes unsafe when you start down below the MDA without actually having the required visual reference for a landing.
The thing you seem to be mis-understanding here, there is a big difference between flying an approach, and continuing on to land. THERE IS NOTHING UNSAFE ABOUT FLYING AN APPROACH TO MINIMUMS, then miss. It's only unsafe if you DESCEND BELOW MINIMUM ALTITUDES without required visual references. An approach into zero visibility IS NOT UNSAFE. It only becomes unsafe when you get into the 'get-r-done' mentality and head down below minimum altitudes without seeing enough to safely find and land on the runway.
I'm sure you folks at AC have some definitions of exactly what you need to see to continue down, and they are (according to the report I read in links from this thread) a LOT less than what I use. I'm pretty firm on what I need to see from the MDA on a back course before I start down from the minimum altitude. The runway will have some approach lights, that look like a T in front of you on the ground. Since it's a localizer, they will be 'right there' in front of you, plus or minus any crab you have on for wind. Beyond that, two lines of lights, one on each side. Look up that line on the left side and count to 4. If I see the approach lights and _at least_ 4 of the other ones, I can see the runway and probably land ok, altho I'm more comfortable seeing a lot more than 4. If I'm tired after a long day, I actually want to see a dozen or more. At night, some of them have those annoying bright flashers at the end of the runway, the ones that totally mess up my night vision, but that's easily solved in most cases, just ask the tower to 'kill the strobes please' when you go past the FAF. Likewise that annoying rabbit thing, another one that totally messes up my night vision, and frankly, if it's needed to find the runway, I'm not likely to see enough of those white ones anyways.
I will say with absolute certainty, sitting at MDA if I see 'some lights', but they dont have that recognizeable T shape with the correct colors, and runway lights beyond, I'm not going to blindly descent and hope a runway shows up.
You can harp on playing the safety card all you want, but, there is NOTHING UNSAFE about flying an approach to the MDA in ANY visibility conditions, including ZERO VISIBILITY, this is well acknowledged in the regulations. It only becomes unsafe once you go below the MDA if you haven't got a visual on where you are going to land.
