Doesn't have to necessarily as far as the water-way is concerned ... except that way (the way he chose) there's less chance someone will try to cut across his path from the right (his right is also the aircraft's green light/starboard). Any craft encroaching the floatplane's take-off path from the right (from starboard) has the right of way. So the pilot makes sure there's no one that can encroach from that side; even the rowers were still at the dock. Any water-craft approaching the aircraft from the left side are required to yield.LousyFisherman wrote:So does that mean to be legal he has to stay to the proper side of the light as long as he is on the water?
Lets see ..."proper side of the light" (as far as 'water-craft encroaching on each other's path' goes) applies "as long as he is on the water", but still in effect if there's conflict during or after flying under the bridge at 10-15'AGL; ie if he was catching up to traffic in early rotation there, or it was still encroaching him from the right. It applies "as long as he is" in conflict with any boat-traffic, which is obviously possible until the floatplane has climbed clear of the tallest mast in its departure area.
