Halifax crash report coming Thursday
AuxBatOn
Re: Halifax crash report coming Thursday
Post by AuxBatOn »
A METAR is a snapshot of what happened around a certain time. While it may give an idea of the conditions during an accident, but it is not to be considered to be the precise conditions during an accident.
A history of METARs and SPECIs may give you trends but again, intrapolation may not be accurate enough to determine actual conditions at the time over the course of an accident.
Going for the deck at corner
Gilles Hudicourt
Post by Gilles Hudicourt »
AuxBatOn wrote: If you bury the important parts of a report into things that while may have had a slight effect on outcome, but are a couple of degrees removed from the outcome (relevancy), it will make for a report that is is too verbose (conciseness), and you will lose things that truly need to be addressed in the noise.
Precisely. For example, the report makes no mention of the accident aircraft having or not having GPS, and makes no mention of the configuration of the aircraft's NAVAIDS. With no GPS installed, Airbus states that an accuracy check must be done before the approach is attempted and it must be on High if the FMS-based position is to be used. Or else it must be done on raw data.
How did the crew determine when it was time to begin the descent from 2200 feet on a 3.5 degree FPA ? With the FMS ? With the DME ? With the NDB ? We dont' know.
Airbus FCTM states that the runway threshold must be inserted in the PROG page of the FMS "ie CYHZ05" in order to display a constant distance to the threshold, which allows the crew to monitor the approach. Did they do this ? Maybe but we don't know.
The LOC frequency is automatically tuned when the LOC 05 approach is selected from the FMS but the associated DME, if not paired with the LOC on which the approach was was flown, as was the case here, is not automatically tuned and must be manually tuned in the NAV page. Was the DME manually tuned and monitored ? Maybe, but we don't know.
The NDB, if one is needed, must also be manually tuned and the needles selected properly for them to appear on the ND, just like they would for an electro-mechanical RDMI. Was the NDB tuned and selected in the ND ? Maybe it was, but we don't know.
The report makes no mention of any of this.
The same way the health and the rest or fatigue of the crew are mentioned in the report, even if these were not determined to be causal factors in the accident, the items I just listed should have been mentioned as well and I was very surprised that they were omitted.
It seems that the draft of the report did too much back and forth between its authors and the legal departments of the concerned parties before it was released, to the point where it no longer serves the purpose for which the TSB writes reports: to allow people to understand what really occurred and avoid similar occurrences in the future. If the real causes are buried in the noise....
I would have loved seeing the first draft of the report.......
Last edited by Gilles Hudicourt on Sat Jun 03, 2017 7:28 pm, edited 1 time in total.
Rockie
Post by Rockie »
Gilles Hudicourt wrote:I would have loved seeing the first draft of the report.......
Me too!
We learn nothing from it - which is the entire point of doing it - if all the facts aren't laid out on the table.
confusedalot
Post by confusedalot »
[quote="Gilles Hudicourt"][quote="AuxBatOn"]
Sadly, knowing the system, this is exactly the problem. Political correctness, under the guise of legalities, strikes again.
pelmet wrote:
Rockie wrote:While a lot of airline safety today is thanks to unions goldeneagle, it isn't a union driving this. Nice try though.
I believe Rockie is correct. It is a business decision by management to level the economic playing field with their competition that now has a competitive advantage because of the different safety record on the issue.
The quest for rule changes has absolutely nothing to do with interest in safety. Otherwise the case to make regulatory changes and internal procedures would have started long ago before there was an accident.
I wonder where thare are good examples of measurable differences on what airline gets to do an approach versus who doesn't under this new proposal? Just a guess using YTZ as an example. Maybe AC can scoop up some business pax due to their Low Vis Approach advantage in YYZ compared to increased cancellations and diversions from the competition(and their excellent safety record) while at the same time possibly eliminating a rerciprocal disadvantage at a CAT I airport like YOW. Advantageous for AC if it were to be true. And a situation that has no doubt hurt AC for years after their tryng to eliminate YTZ.
Any idea how other airlines like Porter might just happen to be affected Rockie, or should I avoid the subject?
pdw
Post by pdw »
AuxBatOn wrote: .. intrapolation may not be accurate enough to determine actual conditions at the time over the course of an accident.
I think i know what you mean here but just to be sure ... it's actually interpolation and extrapolation. I can illustrate point-of-view on this a bit more accurately over the next few days on this post (and hopefully other discussion isn't interrupting for a minor/potential variable we're talking about).
EDIT (Thurs Jun8):
The day of this accident flight (late Saturday) had noticed a LO image South of Nova Scotia on ADDS.
Rockie
Post by Rockie »
To answer that I'd have to know what kind of approaches Porter does and the historical meteorological information on the island. But given their proximity to the city do you think their business plan hinges on the ability to use 1/2 the charted visibility on instrument approaches?
As this is a safety issue you also seem to be implying that only companies who can afford safety should be required to have it.
Anybody else know if the self-regulating rules that AC now uses and which seems to be desired by some for all carriers would create a disadvantage to operators at YTZ?
AuxBatOn
Post by AuxBatOn »
If you are estimating at a time between two known data points, it is interpolation. Given the continuous nature of METARs at YHZ, it would ve difficult, in the context we are discussing, to extrapolate (unless you are estimating the weather in yhe future).
pdw
Post by pdw »
AuxBatOn wrote:(unless you are estimating the weather in yhe future).
METARs a ways away from the action can interpolate via isobars/ speed / direction BACKwards-in-time for an accident's time/alt/location elsewhere. Wx info prior-to but a distance away can offer evidence where the storm's pattern was affecting and where had moved to from that point at the time the sequence event unfolded. TSB report lists all available wx-data from a single YHZ station well before and well after, which helps indicate where Halifax harbour was in relation to the passing pattern and also evidencing the extreme "54kts" mentioned.
Meatservo
Post by Meatservo »
Personally, and sorry for interrupting the narrative thread here, I think better visual approach-slope indicators need to be installed on instrument runways, and having visual contact with them should be requirement for deciding to continue below minimums, not just the lead-in or edge lights. That, plus the weird approach-slope guidance the crew had that doesn't take geographic location into account (apparently), makes me glad I wasn't there. I might have done the same thing. Feel free to abuse me for saying so. Without the PAPIs or VASIs, slope is difficult to ascertain visually at night. The "bird" instrument described in the report, which if I am reading correctly computes slope relative to the aircraft and not relative to the touchdown point, does not seem up to the task.
Rockie
Post by Rockie »
Meatservo wrote:Personally, and sorry for interrupting the narrative thread here, I think better visual approach-slope indicators need to be installed on instrument runways, and having visual contact with them should be requirement for deciding to continue below minimums, not just the lead-in or edge lights. That, plus the weird approach-slope guidance the crew had that doesn't take geographic location into account (apparently), makes me glad I wasn't there. I might have done the same thing. Feel free to abuse me for saying so. Without the PAPIs or VASIs, slope is difficult to ascertain visually at night. The "bird" instrument described in the report, which if I am reading correctly computes slope relative to the aircraft and not relative to the touchdown point, does not seem up to the task.
Your understanding of flight path angle (FPA) is correct, but you are incorrect in saying it is not up to the task. It is a stable, safe way to conduct non-precision approaches, provided non-precision visibility limits commensurate with the available lighting exists. Where Canada goes wrong is allowing precision approach visibility limits to be used.
It's a recipe for this kind of accident.
Meatservo
Post by Meatservo »
But that's what I meant: it wasn't up to THIS task.
Rockie
Post by Rockie »
I understand and you're absolutely right. What I'm saying is that since TC cannot conjure an approach to match the visibility, they must properly regulate the visibility required for the approach.
goldeneagle
Post by goldeneagle »
Rockie wrote:I understand and you're absolutely right. What I'm saying is that since TC cannot conjure an approach to match the visibility, they must properly regulate the visibility required for the approach.
That would be the case if there was an expectation folks would continue an approach with insufficient visual reference 'just because the vis report doesn't ban the approach' which is indicative of a 'must get in' attitude.
Your insistence that regulations must be changed because it's not appropriate for a big heavy jet that is blindly adhering to the constant descent 'must keep descending' mantra does not acknowledge that not all airplanes are created equal, and it's a whole different world in a well powered nimble light twin. If the big jets need higher limits, so be it, but suggesting it applies to everybody is kinda like saying we need a regulation saying nobody can go into a 500 foot grass strip which is perfectly useable for a light super cub, but, rather unsafe with your big jet.
A completely different tack, that would satisfy your desired objective, leave regulations alone, but increase the plate numbers for the cat C and D big heavy fast stuff that seems to be incapable of levelling off at MDA if they are a bit short. Double those numbers and you achieve your objectives for big jets, and leave those of us that can doddle along low and slow at MDA with the option to do exactly that.
Rockie
Post by Rockie »
goldeneagle wrote:A completely different tack, that would satisfy your desired objective, leave regulations alone, but increase the plate numbers for the cat C and D big heavy fast stuff that seems to be incapable of levelling off at MDA if they are a bit short.
Not a bad idea, but there's nothing wrong with the plate numbers except that they don't consider the approach lighting available. I think more appropriately the charted minimums should apply without reduction to any aircraft utilizing SCDA's. That would be a suitable compromise in my opinion, although I still don't get why Canada feels using lower than published minimums is safe when the rest of the world does not. We are the outlier and we need to question why.
Remember when they used to print the visual descent point (VDP) on non-precision approach plates? The idea was you would descend down and level off at MDA, then drive in safe and level until the missed approach point watching for visual references to the runway gradually appear...or not. As you passed the VDP you knew your chances of being able to land safely rapidly diminished, and descending from MDA required an actual decision and positive action on your part based on your assessment of position.
In a precision approach you already know you are headed laterally and vertically toward the correct touchdown spot on the runway (that's why it's called precision), and all you really need to see is essentially any of the required visual references to continue. Completely safe unless you subsequently lost sight and were forced into a go-around.
With SCDA we are forcing the same decision making criteria on the crew without any of the safeguards a precision approach offers, and without any of the advantages a dive and drive NPA provides.
I would definitely be in favour of eliminating the approach ban for SCDA's only if that were an option.
Eric Janson
Post by Eric Janson »
This is already the case - at my Airline we are not allowed to fly approaches below charted visibility requirements. These visibility requirements ensure that adequate visual references can be seen at MDA/DA/DH to allow for a safe continuation and landing.
Rockie wrote:With SCDA we are forcing the same decision making criteria on the crew without any of the safeguards a precision approach offers, and without any of the advantages a dive and drive NPA provides.
I don't agree - SCDA is the safest way to fly an NPA. Dive and Drive can lead to an unstabilized approach close to the ground.
I've worked for companies where we were allowed to level off at MDA because the NPA's at that time did not have a CDA profile published. This is extremely dangerous imho and has resulted in plenty of CFIT accidents over the years.
On an SCDA you have altitude vs. DME to allow monitoring of the vertical profile. This should put you in a position from which you can land with only minor corrections. The LOC Rwy 05 approach has 7 points at which this can be done after passing D9.5 IHZ.
There is nothing difficult about flying an NPA using LOC/FPA modes imho.
The only thing that I would have preferred to see on this approach is a co-located DME on the localizer IGX that would read zero at the threshold.
Flying an NPA in precision approach weather is asking for problems as is choosing to ignore the manufacturers SOPs.
I can see an issue flying NPA if you don't do them regularly. I imagine it's perfectly possible to never fly an NPA outside the Simulator.
Rockie
Post by Rockie »
You misunderstand my meaning Eric. The advantage I'm referring to using a dive and drive method is the ability to watch the required visual references develop as you approach the runway environment level at MDA within your bubble of visibility. This allows you time to make the assessment.
While the SCDA is unquestionably safer from a CFIT point of view it does not permit you the same time to watch the visual references develop, and when you reach MDA you have to make a decision without knowing precisely where you are. Which is why the visibility has to be good enough, and the required visual references have to be increased to actually permit you to assess your position instantly.
I do not advocate dive and drive in transport aircraft. I'm merely pointing out the "handicap" SCDA's impose on a crew without any of the guarantees a precision approach offers, nor the advantage a dive and drive gives in time to assess.
av8ts
Post by av8ts »
If AC had invested in GPS aboard this aircraft like most other Canadian companies the crew would not have been "handicapped " doing a nonprecision approach. This was probably in the original accident report but removed after pressure from AC
Rockie
Post by Rockie »
av8ts wrote:If AC had invested in GPS aboard this aircraft like most other Canadian companies the crew would not have been "handicapped " doing a nonprecision approach. This was probably in the original accident report but removed after pressure from AC
Not necessarily true. The LOC approach uses DME as the descent point making it just as accurate as GPS. it would however have provided vertical guidance within the temperature range of the LNAV/VNAV which may have made the difference. In this case the AP would disconnect automatically at MDA -50, so who knows what effect that may have had given the visibility.
You won't find anybody arguing against equipping with GPS though except maybe the accountants. WAAS would be better.
You're also speculating that the TSB would editorialize on the equipment onboard the aircraft, when they had the legal equipment to do a legal approach to legal weather. A bit of a reach.
Eric Janson
Rockie wrote:You misunderstand my meaning Eric. The advantage I'm referring to using a dive and drive method is the ability to watch the required visual references develop as you approach the runway environment level at MDA within your bubble of visibility. This allows you time to make the assessment.
Don't forget the additional 'handicap' of trying to fly VFR in IMC whilst trying to find the runway on a dive and drive approach. That's killed a lot of people.
SCDA will get you to a point from which you can easily continue to landing with minimal changes to your vertical profile. You'll see the same 'picture' every time.
Not working out? - Go-around.
It's very simple - I'm a big proponent of keeping things simple.
Rockie
Post by Rockie »
Yes, once again I agree with you. The problem with SCDA's is that they are not precise as Halifax amply demonstrated. It is not good enough to just see "something" as permitted in the required visual references, and is sufficient with the guarantees present in a precision approach. You have to see that you are in the right place at the right altitude and with the right flight path trajectory. That requires significantly more than precision approach visibilities.
pdw
Post by pdw »
from the report/ wrote:This is the first time these two pilots had flown together.
IMO to ID "something" in the min-vis WX at 05-HZ with the above SCDA-description, and being "first time", ... ie they'd have had to have done the approach before in that soup to recognize anything and to anticipate it correctly.
Canoehead
Post by Canoehead »
It was the first time they'd flown together. It happens every day hundreds of times. It's why we have standard calls and SOP's.
That has nothing to do with what they saw/identified/didn't see.
pdw
Post by pdw »
Just that it was mentioned (about the first time pairing ... CRM) ... then the "staff change in the tower" during approach, also in there. It's challenging to understand how these variables all fit ...
