What about descending through 12 500 into VMC, on an IFR flight plan, into Class E airspace inbound to Kitchener.Sulako wrote: ↑Fri Oct 06, 2023 12:58 amWe have previously agreed that if a plane is hopping over from Hamilton to Kitchener on a VFR itinerary and joining the circuit for landing on a clear day and just eyeballing it, that's not valid instrument time.
But! If you are the aircraft behind them and you have the ILS dialed in and you are using the pointers and the autopilot is on and you have done your approach briefing and you have the minimums set in and you are doing all the approach callouts, that is valid instrument time. Because you are flying the plane with sole reference to the flight instruments. It doesn't matter if you can see outside until you hit your DH/MDA.
Now here's the extreme case. A pilot can be on a VFR flight plan and shoot a bullshit ILS into an airport where the weather is lousy and log the instrument time. It's loggable because they were flying the plane with sole reference to the instruments. They would likely face enforcement action for flying below VFR weather limits and being a general doorknob, but the actual instrument time would be loggable. That's obviously just a troll-like situation that no smart person would put themselves in, but the definition allows it. The sustainable and smart practice would be to file IFR![]()
With respect to Class E, services shall provide separation between IFR aircraft, but you must maintain visual separation from VFR aircraft. As an IFR aircraft you must have visual reference outside to provide visual separation from VFR aircraft and can not be solely focused inside.
Now what?
My logbook had a 10% default for actual. I log instrument time on all IFR filed flights. Good enough. I have yet to have a license or job turned down over actual vs instrument.
