pelmet wrote:I disagree that is impossible to prevent but I check your remarks...so if you magically get a flight there tomorrow under the same circumstances as they had with no reliable electronics to align you with the runway, what is your plan to prevent a repeat captain?
No, I didn't say it was impossible to prevent, just that with the proven info we have right now, and not knowing why it happened, it is impossible to guess how to prevent it.
Take your quoted example... the ILS. You are going on the premise that they didn't have it tuned, and that's likely true, but it isn't proven to be true. So, deciding now that AC should come up with new policies to always tune the ILS or replace the aircraft with newer ones, is a solution for a problem that only hypothetically exists.
What do we really know for sure? Distances, times, heights, couple of screen caps, atc tapes, notams, and weather. That's about it.
Based on those alone, I have no idea why what happened happened. Couple of wild theories perhaps, but it this moment, that's all they are.
