It was probably in the heat of the moment for them, but always, always, always check the FMA is you want to know "what mama's doing." Of course it's 20/20 now.telex wrote: ↑Fri Mar 22, 2019 10:50 amGA will become active in pitch and roll. Annunciated on the Flight Mode Annunciator.ReserveTank wrote: ↑Fri Mar 22, 2019 10:34 am Doesn't the 767 have a "Go Around" annunciation or something similar on the PFD?
Atlas Air 767
ReserveTank
Re: Atlas Air 767
Re: Atlas Air 767
Would 4G negative be possible to achieve, even instantaneously? A loaded 767 is a lot of mass to make change its velocity that quickly by diving, isn't it?
- Boreas
Re: Atlas Air 767
There is a pretty long arm between the 767 cockpit - where I presume the reading was recorded - and its lateral axis. The longer the arm, the higher the linear acceleration for a given angular acceleration about an axis.
Re: Atlas Air 767
So, theoretical situation: Three g-meters, one in the cockpit, one on the spar and one in the tailcone, all reading simultaneously. At the inception of a sharp pushover and dive, there would be a high negative in the cockpit, a high positive in the tail and a moderate negative at the spar or lateral axis?Boreas wrote: ↑Fri Mar 22, 2019 2:52 pmThere is a pretty long arm between the 767 cockpit - where I presume the reading was recorded - and its lateral axis. The longer the arm, the higher the linear acceleration for a given angular acceleration about an axis.
Re: Atlas Air 767
There's a plethora of articles out about disputes and safety concerns at Atlas/Amazon. Apparently people there were dreading something like this happening.
Of course it's taking a back seat to the Max thing, but may be just as relevant if not more so, being in our own backyard.
I haven't been able to find anything about the experience level of the crew, anyone know?
Re: Atlas Air 767
CA total 11 000 hours and 1250 on type.DanWEC wrote: ↑Fri Mar 22, 2019 4:05 pm There's a plethora of articles out about disputes and safety concerns at Atlas/Amazon. Apparently people there were dreading something like this happening.
FO total 5 000 hours and 520 on type.
- Boreas
Re: Atlas Air 767
Yes to 'high' negative in the cockpit and to 'high' positive in the tail. There wouldn't be a negative at the lateral axis at the inception of the push over - it would be close to 1g still.GyvAir wrote: ↑Fri Mar 22, 2019 3:52 pmSo, theoretical situation: Three g-meters, one in the cockpit, one on the spar and one in the tailcone, all reading simultaneously. At the inception of a sharp pushover and dive, there would be a high negative in the cockpit, a high positive in the tail and a moderate negative at the spar or lateral axis?
If you're in the tail you'd hit the floor and if you're in the cockpit you'd hit the ceiling... hard!
Re: Atlas Air 767
this is unlikely. the 767 has a cam type override which requires 25 pounds of force to disengage one column from the other. also the same thing at the tail.
if the FO was holding full forward, all it should take is 25lbs of force from the Captain to disengage the columns. then they both have control of one elevator. until the columns are brought to the same place again, then they lock back together.
Eric Janson
Re: Atlas Air 767
Works very well - location makes it quite easy to push one of the switches when needed. Fingers on top of the thrust levers and you would hit the TOGA switch with your thumb.
A vast improvement on the 737 switches which are very poorly located imho.
Re: Atlas Air 767
Fair enough, just wondering how easy they are to accidentally bump vs a button on the side like you see in many.
Eric Janson
Re: Atlas Air 767
I don't recall ever doing it.
Nothing will happen unless you are in a condition where TOGA mode has armed.
Starting to look like inadvertent TOGA mode selection and a reaction to Somatogravic Illusion.
Re: Atlas Air 767
Looks like inadvertent TOGA activation and the FO thinking they were about to stall. He then pushed to a 40 degree nose down attitude. The captain yanked so hard back on his control column that it disconnected from the elevators. Once they were below the cloud deck the FO tried to recover but it was too late. Also nobody had retarded the thrust levers either so with the nose down attitude the speed was enormous. There’s a lot of breakdown of said event over at Pprune.
Re: Atlas Air 767
my god how does that happen.....
how does it disconnect from the elevator does each side disconnect independently for a jammed stab event?
cheers for the info how completely random poor guys
Re: Atlas Air 767
There is a limit in any given aircraft, to the amount of abuse that it will tolerate , before it exacts it's revenge.
Treat all aircraft, as if , your life depends on it, because it does.
Re: Atlas Air 767
According to my inside sources, this is pretty much correct. They had speedbrakes out for descent and the 767 has a known burble caused by this that was misinterpreted as a stall. Toga pushed while captain not looking which initiated a climb and lots of thrust. The FO started pushing nose down too much which was opposed by the captain.jpilot77 wrote: ↑Thu May 09, 2019 11:41 am Looks like inadvertent TOGA activation and the FO thinking they were about to stall. He then pushed to a 40 degree nose down attitude. The captain yanked so hard back on his control column that it disconnected from the elevators. Once they were below the cloud deck the FO tried to recover but it was too late. Also nobody had retarded the thrust levers either so with the nose down attitude the speed was enormous. There’s a lot of breakdown of said event over at Pprune.
Or something like that.
Re: Atlas Air 767
Pilot Of Doomed Amazon Air Flight Had Poor Training Record, Seemed Confused Before Crash, NTSB Probe Suggests
https://www.forbes.com/sites/jeremyboga ... 4348ce79cc
ReserveTank
Re: Atlas Air 767
Referring to the FO of the accident flight...
The industry in the US is booming and is desperate for pilots. Unfortunately, this means that there's a lot of bottom-of-the-barrel talent being pushed through training programs everywhere. I've trained with guys like this all through my career. They exhibit a common trait--a complete lack of situational awareness. Guys like this will keep shopping for an airline that will submit to the sunk cost fallacy, finally forcing the examiners to pass them. PRIA doesn't catch everything, as this story shows. I've worked with guys that were employed for several months before being fired due to failure to disclose multiple unsat checking events. They usually only get caught when going to upgrade. It's a crock if his family really goes after Atlas about working conditions. This FO had no business at work to begin with.
Re: Atlas Air 767
Copypasta from PPRUNE
Training Incompetency and Failures
6/27/11 - Resigned from CommutAir for failing DHC-8 initial
8/13/12 - Resigned from Air Wisconsin for failing CRJ initial
4/22/14 - Failed EMB-145 Oral at Trans State Airlines
5/11/14 - Failed EMB-145 Type Rating at Trans States Airlines
5/17 - Failed EMB-175 Upgrade Attempt at Mesa Airlines
5/17 - Nearly failed FO Requal after failing upgrade attempt at Mesa Airlines
7/27/17 - Failed B-767 Oral at Atlas Air
8/1/17 - Unsat Judgement/Situational Awareness during FBS-1 at Atlas Air
8/5/17 - Failed DBS-5 at Atlas Air
8/11/17 - Almost Failed FFSI-1 at Atlas Air
8/31/17 - "Regression of Situational Awareness" during FFSI-3 at Atlas Air
9/22/17 - Failed B-767 Type Rating for "Very Low Situational Awareness", incomplete procedures, and exceeding limitations at Atlas Air
Past Training Notes (directly quoted from the NTSB Docket)
Air Wisconsin CRJ Initial Failure - "They were conducting the emergency procedure cabin altitude ... where they are at FL350 or so, and he gives the students a cabin altitude message requiring an emergency descent to 10,000 feet" ... "Conrad then goes to descend the simulator. He was not sure of Conrad's background, but instead of descending on the autopilot, Conrad disengaged the autopilot and abruptly pitched down well below horizon. They got stick shaker and overspeed alert together. He was not sure if it was an extreme nose down, but remembered that it was abrupt input on the controls"
Mesa Airlines ERJ-175 Upgrade Failure (Instructor 1) - "He had previously failed simulator lesson 2 with different instructor, and he had requested a different instructor. She was conducting his retraining for lesson 2. She said his performance was a "train wreck" and he performed very poorly in this lesson. In the briefing room he did well, and explained things well. However, in the simulator and something he wasn't expecting happened he got extremely flustered and could not respond appropriately to the situation." ... "When asked about her comment in her notes about Conrad's "lack of understanding of how unsafe he was," she said he was making very frantic mistakes, lots and lots of mistakes, and did a lot of things wrong but did not recognize this was a problem. He thought he was a good pilot never had any problems and thought he should be a captain. he could not evaluate himself and see that he did not have the right stuff."
Mesa Airlines ERJ-175 Upgrade Failure (Instructor 2) - "He first met Conrad Aska during a recurrent checking event in March 2016. That session went ok and nothing stood out. He did have some trouble with the stall series. The problems were with his attitude control, and he had a hard time getting the airplane back to level flight" ... "He said when Conrad would make a mistake in training he had an excuse for everything"
The quote that stands out the most to me in this second Mesa instructor interview is, "When asked if Conrad would get startled in the simulator, he said that during one stall recovery, Conrad pitched down about 40 degrees for recovery, then a pitch up about 20 degrees. His flight path was all over the place."
AirportCoffee
Re: Atlas Air 767
Yikes. You would think the system would catch up to him sooner or later with all of those failures
PostmasterGeneral
Re: Atlas Air 767
Not when the system is flawed and people these days are hired in order to meet some sort of “diversity” quota instead of being hired based on their credentials and ability.AirportCoffee wrote: ↑Sun Dec 22, 2019 7:39 am Yikes. You would think the system would catch up to him sooner or later with all of those failures![]()
Re: Atlas Air 767
Ding ding ding ! That’s it right there. The elephant in the room.PostmasterGeneral wrote: ↑Sun Dec 22, 2019 7:58 amNot when the system is flawed and people these days are hired in order to meet some sort of “diversity” quota instead of being hired based on their credentials and ability.AirportCoffee wrote: ↑Sun Dec 22, 2019 7:39 am Yikes. You would think the system would catch up to him sooner or later with all of those failures![]()
ReserveTank
Re: Atlas Air 767
Not to hijack, but it's related--The MAX (and Airbus to an extent) software was written exactly for this purpose. Vibrant and diverse people who can neither fly attitude nor figure out which mode the aircraft is in. That's the future of aviation, unfortunately.daedalusx wrote: ↑Sun Dec 22, 2019 9:52 amDing ding ding ! That’s it right there. The elephant in the room.PostmasterGeneral wrote: ↑Sun Dec 22, 2019 7:58 amNot when the system is flawed and people these days are hired in order to meet some sort of “diversity” quota instead of being hired based on their credentials and ability.AirportCoffee wrote: ↑Sun Dec 22, 2019 7:39 am Yikes. You would think the system would catch up to him sooner or later with all of those failures![]()
Re: Atlas Air 767
Which remind me about this thread running on Av Canada a few months ago, about what to do when you get to fly with somebody that incompetent.AirportCoffee wrote: ↑Sun Dec 22, 2019 7:39 am Yikes. You would think the system would catch up to him sooner or later with all of those failures![]()
-Report it?
-Give more training?
-Fire the person from the company?
-All this combined?
-etc...
Where do you draw the line?
I think being in two crew environment that quick in his carrer (it seems) Is probably what kept him alive that long.
Single pilot's IFR World would have weeded him out the hard Darwin way earlier.
Amazing how he managed to thread his way that long though.
Re: Atlas Air 767
-Report it?
-All this combined?
-etc...
I think being in two crew environment quick in his carrer (it seems) Is probably what kept him alive that long.
