Cherokee 140 near Sioux Lookout
Re: Cherokee 140 near Sioux Lookout
7ECA wrote: Mon May 09, 2022 5:46 pm Rumour has it, or rather it's being reported that one (or both) of the pilots was advertising chisel charters in this aircraft at some point. Apparently the owner was also the girl friend of one of the pilots on board the Cherrytree's last ride.
Needless to say, chisel charters for time building plus hauling two convicts around in absolutely not VFR WX was just asking for trouble.
Plane that crashed with fugitives was overweight, heading for Toronto: Witness
© Provided by The Canadian Press
VANCOUVER — A woman who knew the pilot of a fatal flight that killed two men wanted in separate murder plots says he told her he was heading for Toronto and was concerned about the plane's weight.
The woman, who asked not to be identified because she was afraid for her safety, said she spoke with pilot Abhinav Handa at the Boundary Bay Airport in Delta, B.C., before his plane took off on the cross-country trip in late April.
Handa told her he was carrying three passengers and had been planning the journey for at least a week, she said, although he only confirmed the date of the flight the day before departure.
The pilot expressed concern the plane was too heavy, but the woman said she didn't know if any luggage or cargo was removed.
"They were a little overloaded and they were trying to reduce their weight," the woman told The Canadian Press.
The woman did not see the three passengers and she said she and Handa also talked about weather conditions.
Police have said Handa, Hankun Hong, Gene Lahrkamp and Duncan Bailey died in the crash near Sioux Lookout, Ont.
The Combined Forces Special Enforcement Unit, which is British Columbia's anti-gang unit, has identified Lahrkamp as one of two men wanted in Thailand for murdering another man with links to B.C. gangs.
A man with the same name and age as Bailey was wanted by police for breaching bail conditions related to a separate murder plot in B.C.
The Piper Cherokee that crashed was travelling between Dryden, Ont., and Marathon, Ont., however the aircraft was registered in B.C. The woman, who had some knowledge of aviation, said a plane that small would have made several fuel stops en route to Toronto.
She could not confirm exactly which day she saw Handa. Another man at the airport said he did not want to be interviewed but he said he also saw Handa on the same day as the woman, although he could not confirm the date either.
Nav Canada, which operates flight information centres across the country, referred questions about the flight's itinerary to the Transportation Safety Board.
The board referred questions to the Boundary Bay Airport, which said it could not release the information.
The safety board, which is investigating the crash, has said a cause has not yet been determined. It said Thursday it will share an update "shortly."
Online flight tracking site FlightAware shows a gap in flight records for the plane between British Columbia and Alberta.
The site shows the plane arrived at the Boundary Bay Airport at 7:44 p.m. on April 23. The next entry shows the plane flew between Claresholm, Alta., and Shaunavon, Sask., on April 28 before continuing east. The final entry tracks its path from Dryden, Ont., to the crash site near Sioux Lookout, Ont., on April 29.
Hong and Handa do not appear in criminal records, however the federal aviation regulator said Handa was not certified to offer charter flights.
Transport Canada says neither Handa nor a company to which he was linked, called A&T Flights, held a valid Air Operator Certificate.
The certificate is one of several requirements for commercial pilots offering charters, tours and other services to paying customers, the agency said.
A public aircraft registry also lists the plane that crashed as being registered for private, rather than commercial use.
"Abhinav" is listed as the contact for A&T Flights Inc., on the company's Instagram page.
Hong is tagged in a video on A&T Flights page, advertising its services.
"Pilots having fun renting plane and flying all over beautiful British Columbia," the post on April 8 says.
Accounts for both Handa and Hong follow the A&T Flights Instagram page.
pelmet wrote: Fri May 13, 2022 6:21 am
In other news today, scientists have also determined the sun rises in the east. And we have a breaking report from our nature correspondent about the recent discovery of bear poo in the nearby woods.
karmutzen
Post by karmutzen »
Overweight has as much relevance as whether or not the news reporter writing it was overweight. Did not cause the crash. In fact that they got to Ontario proves they were handling the weight competently. More troubling is their ground track and the implications to flight conditions.
But how much overweight for us pilots to argue about? An optimistic empty weight for a 140 is 1300, gross is 2150. 4 guys and gear at 190 each is 760. Leaves 90 lbs for fuel. So could be done legal in one hour hops. Add extra fuel for longer legs and providing you could take off and climb (which they did, especially through BC and Alberta) and you'd be back under gross after some fuel burn off.
They could have just left the second pilot behind if Jimminy Cricket was beaking at them about weight.
karmutzen wrote: Fri May 13, 2022 10:53 am4 guys and gear at 190 each is 760
You're having a laugh, aren't you?
If only they'd been smart enough to do that then they'd have saved at least one person's life.
It just means that the bad thing hadn't happened yet. If they were overweight, being out of C of G limits was also possible, and that condition sometimes is not apparent until lost control cannot be regained.
JasonE
Post by JasonE »
My 140 was an early one with no toe brakes and lighter than most with 910 lbs useful. Some I've seen as low as 750 useful.
Bede
Post by Bede »
Just found out that this plane was owned by my wife's best friend's sister. Her fiancé was the pilot. He was running a chisel charter operation.
Apparently quite the sordid affair straight from the pages of a thriller novel. Details when I get them...
Mike Flynn
Post by Mike Flynn »
What is the latest news on this story.
broken_slinky
Post by broken_slinky »
Looks like some freshly released updates. Nothing really new or surprising related to the flight itself. Some interesting information about the passengers though.
https://ca.news.yahoo.com/plane-crash-k ... 53661.html
https://www.tsb.gc.ca/eng/rapports-repo ... c0027.html
golden hawk
Post by golden hawk »
