Caravan Honeywell TPE331 conversion
snaproll20
Post by snaproll20 »
Methinks you all forget that the real problem with the Caravan in icing is tailplane stall.
So there!!!!
Doc
Post by Doc »
Methinks the REAL problem is departing with a contaminated wing in the first place?
Ali G
Post by Ali G »
Oops Doc,
Apologies. I totally agree with you.
Endless, the fact is whether you have 900hp or 675hp, you are at 100% power when you figure out you are getting hooped. Then, there is nothing left for these engines to give.
That is why I suggested derating this thing so that it could give you another 'out'. But that defeats the whole point, and, it has already been done.
Booyakasha!
flyinphil
Post by flyinphil »
endless wrote:twotter and phil,
So what part of the equation do you guys not understand?
I don't understand how the properties of ice and additional weight based on the type and exposure I will be carrying will affect the performance. I fail to see where the info fits in an equation for lift. Manufacturers don't either which is why the effects of icing has to be test flown.
There are people out there that would believe they have 10% more thrust so they can carry 10% more weight or 10% more ice. It aint so. Most will only judge the severity by diminished performance and (as Doc said) it will be all over but the cryin'.
When I read this stuff from pilots about icing I want to crawl into a cave and pull a rock in front of it.
Why is it so difficult for some pilots to understand that icing is not to be taken lightly and is capable of bringing any aircraft out of the air in short order if the wrong set of circumstances occur...like real quick ...like with that poor woman in Winnipeg last year.
nacho
Post by nacho »
Icing aside, the Garret si the best engine I think. More power is always better, added bonus it doesn't use as much fuel and it can use any fuel.
No filters to change and less oil per hour used ... I like it better.
Over the Horn
Post by Over the Horn »
None of you guys have realized that there's a ton of operators that have floats hanging underneath their Caravans 900hp could be handy getting on the step, just a thought for you guy's, not everyone wants an IFR Caravan. The instant power a garret would deliver could be handy getting in and out of small lakes in the mountains and make it a viable replacement for turbine Otters an area the Caravan has never had a good rep.
Pile-it
Post by Pile-it »
Three winters in S Ont. on the 208. The key is always have an out, and know when to say no, or wait it out. The 208 is a fine machine; it's envelope wide. Run your flaps up slowly on departure, and fly it on as is if you have the runway available.
You cut it...
ei ei owe
Post by ei ei owe »
Cat Driver wrote:Why is it so difficult for some pilots to understand that icing is not to be taken lightly...
I really don't think that's where the argument was intending on going. Endless had brought up a point about more power leading to more lift being produced. I don't believe anyone's wanting to hash out the 208's icing issues because we all know it sucks.
To make it plain and simple, more power will help you out when icing's in the picture. Does it need to digress anywhere else?
oldenoughtoknowbetter
Post by oldenoughtoknowbetter »
Cat Driver wrote:
" The Garrett will give you more power for less fuel, a higher initial TBO and instant power when you need it."
You forgot to mention instant drag when you need it for a slam dunk.
Some will argue the value of the dunk Cat but it is good practice and a sheit load of fun........the immediate power is nice for recovery as well God forbid we'd ever phuck up :shock: Don't expect a recovery with the 6, get it right the first time.
This is explaned and validated by the the flap restrictions on the 6, and not the Garrett on -3's.
