Hedley wrote:Grow up, STL. Try really hard to act like an adult.
Just because you disagree with me that Canada has
problems, is no reason to spew your obnoxious,
offensive venom. Unless you're a child.
What, can't handle it when somebody has balls to call your BS what it is? You call me a child when you make baseless proclamations that wouldn't hold up to the scrutiny of a Grade 8 class?
You stated you hated Canadians and Canada....That we don't do anything but collect welfare and smoke Crack... You expect me to sit and listen to that? Not on your life. Talk about growing up....
I'm plenty adult thank you very much, it seems to me you started it, it's all in black and white above if you care to read. I was taught to finish what you started... perhaps you were not.
I love the terms "obnoxious and offensive venom." Just scroll back up and read what you wrote. If that's not the definition of "obnoxious and offensive," then I'm not sure what is. You need to learn that if you're going to "spew" your brand of obnoxious venom, you'd better be prepared to have it come right back, because you obviously can't defend it.
To that end, here's your opportunity.
Tell us what you've done to make Canada a better place? What is it that you're contributing to our society that gives you the right to say what you did? I'm all ears, and am quite serious in the invitation. Your alleged gene-pool doesn't count, I want to know what YOU are doing that makes you so much better than your fellow Canadians.
