You forgot to log your cross-country and float time:Night Multi IMC PIC Jet Solid Rocket Booster column
Night Multi IMC X/C PIC Jet Solid Rocket Booster Amphib column
HUH!?Big Pistons Forever wrote: The way things work in the aviation industry is really simple and will never change.
Yup like the "simple minded pilots" who are sitting on the job interview panel and will think you are an complete tool when you call your King Air hours "jet time".ETOPS wrote:HUH!?Big Pistons Forever wrote: The way things work in the aviation industry is really simple and will never change.
Suggestion: change "in the aviation industry" with "for simple minded pilots".
Listen, most of us know that turboprop, turbofan and turbojet are all forms of gas turbine engines. ETOPS initial posts where in reference to what is or isn't considered jet time not what is or isn't considered a jet engine. Jet time is in reference to the type of aircraft flown not the type of engine operated. So while the type of engine bolted to the airframe is important in the distinction, it isn't the final say in what is or isn't jet time.Gino Under wrote:Pardon my being pedantic, but I understand jet engines are jet engines and jet aircraft aren't propeller aircraft, and we all know the difference. Perhaps some should re-read this thread from the begining.
ETOPS wrote:My search didn't turn up much...sorry if this has already been discussed.
Does turbofan time count as "jet" time?
Does "turbine" time incorporate all three groups (prop, fan, jet), or does it just refer to turboprops?
Thanx
ETOPS wrote:But turboprop is not "jet" time?
I'm pretty sure the answer is NO.
What I'm trying to get at is: why does a turbofan count as "jet" time while a turboprop doesn't?
They both have a jet component producing thrust. So maybe the jet component on the fan produces a greater percentage of its total thrust, but where do you draw the line and why?
I'm guessing the distinction comes from the operation.
What exactly is so different (more complex) about the operation of a turbofan vs. a turboprop?
Gino Under wrote:ETOPS
Well, that depends. Are you talking about your logbook and the logging of flight time, or what a prospective employer is looking for? Because, yes, a turbofan engine (airframes aren't engines, they're airframes) is a gas turbine engine as opposed to a piston four stroke engine. And, it is usually logged as Turbine time because most log books don't have provisions for the logging of jet time, if that's what you are asking. Which is apparently unclear to some. Jet engines include four types of gas turbine (jet) powered engines, etc., etc., etc..
So if I have time on a 777, and I tell them I have xxx jet hours on a 777, I'll look foolish? Are you sure about that?broompusher wrote:flying4dollars wrote:No it doesn't. Turbofans are jet engines, and therefore considered jet time. So to answer his question, yes, turbofan time is jet time.
Take that one into your next interview and see how far that will get you. If you tell them that you have jet time, and the interviewing company asks on what, and your answer is the above, well, good luck with the interview, that's all I have to say.
This is the stupidest topic I have seen here in a very very long time.
A BE20 is powered by turboprop engines. A 777 is powered by turbofan engines.broompusher wrote:Use your head, of course if you have time on jet aircraft such as a B777, Airbus, Citation, Lear or whatever then that is that. But, If you go into an interview saying you have jet time whilst flying nothing but a BE20, you will not last too long in said interview.
Nope.ETOPS wrote:JETJOCK wrote: However, turboprop time is "jet" time, simply because a turboprop engine is a jet engine.
Consider the exhaust of a turboprop engine (PT6 or other). Is it not a jet (a high-velocity fluid stream forced under pressure out of a small-diameter opening or nozzle)? Does this not follow with your previous definition of a jet engine?
Read it carefully, and then tell me you still feel I need to use my head.No it doesn't. Turbofans are jet engines, and therefore considered jet time. So to answer his question, yes, turbofan time is jet time.
All 3 are turbine engines, but we should keep turbines and jets as separate concepts? So then all 3 AREN'T turbines. The PPL you have sure has you knowing more than the commercial pilots on here hey? Smart guy.slam525i wrote: So all three are "turbine" engines, right? GOOD.
Just keep turbine and jet as separate concepts and we can all agree.
You have a flaw in your logic. If we treat all three as turbines, and we keep turbines and jets as separate concepts, the fact that only 2 of the 3 are jets does not disqualify any of the 3 as a turbine engine. It's the classic "A is a subset of B, but A does not encompass all of B." type logical fallacy.rooster wrote:All 3 are turbine engines, but we should keep turbines and jets as separate concepts? So then all 3 AREN'T turbines. The PPL you have sure has you knowing more than the commercial pilots on here hey? Smart guy.slam525i wrote: So all three are "turbine" engines, right? GOOD.
For your sake I'll assume you meant "keep turboprops and jets as separate concepts". Just clearing up the 'semantics' for you
