Hi Eric. The point of the question was to challenge
people's acceptance as fact that a stall always results
in the nose dropping back to the ground. Gravity has
overcome lift.
However, consider the case where an aircraft is inverted wings
level - forget about any bank, that's simply me being cruel
as usual - approaching the top of a very high speed inside loop,
and then attempting to pull (e.g.) +6G's. If the aircraft doesn't
have enough airspeed, it will stall.
When the aircraft stalls, it will fall
upwards which I am
sure will make people here howl - they will say it's impossible
to stall, and fall upwards.
Sure you can.
The forces acting on the aircraft are simple vector summation.
We have one lowly G downwards (gravity) but a crapload of
centrigual force pulling the aircraft upwards, which is opposed
by the lift of the wings pulling the aircraft downwards. Gravity
and lift pull the aircraft down.
If the lift of the wings disappears - consider it to go to zero,
which of course it won't - then all you have left is the ballistic
summation of the +1G of gravity and the upwards centrifugal
force, which overcomes the +1G of gravity, and the aircraft
falls upwards when it stalls.
I tried to drop a hint when I posted the picture of the water
bomber releasing water while pulling G inverted - note that
the released water, like a stalled aircraft, falls upwards - but
I guess that didn't help.
Doing outside loops, many many times I have stalled and
fallen upwards. Start inverted, straight and level, and push.
If you don't have enough entry speed (or G) as the aircraft
falls through the vertical - it is now in an upright 45 upline,
but with fading negative G on, trying to push the nose down -
the aircraft with tremble and grumble with a negative AOA
stall. If it happens, you fall upwards as centrifugal force
overcomes combined lift and gravity.
Actually, what I like to do right then, is say ok you mother,
let's do it - full forward stick and full rudder to asymmetrically
negative G stall, which gives you the prettiest little half outside
snap roll. You end up inverted (instead of upright) at the top
of the loop. Pulling through is not recommended because of
GLOC considerations, though. Pity.
tl;dr You can have a positive G stall which results in the
aircraft falling upwards
Last time I checked, a waterbomber wasn't usually
considered eligible for aerobatic competition, so I
really haven't rigged the deck that badly.
Bonus question: talk to me about the energy of
the water in the above photograph. There is a
fascinating lesson there, if you notice a little detail.
