There is 3 GS in March (2,16,30)KenoraPilot wrote: ↑Mon Feb 17, 2020 10:17 amYes both March GS are full.Flightfanatic wrote: ↑Fri Feb 14, 2020 3:23 pm Any news on march GS is filled? Anyone got called in?
New hire bids
Caterpillar
Re: New hire bids
Since I’m flying the King Air, does that qualify me to fly the Queen of the skies?
Re: New hire bids
[/quote]
Is March 30 full?...
[/quote]
- KenoraPilot
Re: New hire bids
GGN pilots took CA and FO RJ at various bases
OTS: 2x Q400 YYC, 4x DH8 YYC
- Flightnerd
Re: New hire bids
Question about the actual process on GS day 2 for the new hire bid.
I know that you will get seniority decided thru a lottery, and ALPA members get an advantage in choice as well (how much practical difference this will make??)
But what is it like to go thru the process? Are you given time to think about the pros and cons of different types and different bases? Is there somewhere (official) to look and see what equipment is at which base? So that you can pick a type and move to a base later.
I know there is a ton of movement and flux with the types and bases.
I’m just trying to get ready for my March 16th GS
A
A
Stayfly121
Stayfly121
Re: New hire bids
With the recent GGN merger, I'm assuming there will be very limited number of RJs if any in the next couple GSs?
Re: New hire bids
Jazz is loosing over 50 pilots a month to AC. I don't think there's a limited number of anything.Stayfly121 wrote: ↑Thu Feb 20, 2020 8:09 pm With the recent GGN merger, I'm assuming there will be very limited number of RJs if any?
Caterpillar
Re: New hire bids
It’s actually a fact. No RJ was awarded very recently to OTS hires.derateNO wrote: ↑Thu Feb 20, 2020 8:12 pmJazz is loosing over 50 pilots a month to AC. I don't think there's a limited number of anything.Stayfly121 wrote: ↑Thu Feb 20, 2020 8:09 pm With the recent GGN merger, I'm assuming there will be very limited number of RJs if any?
Re: New hire bids
There are 122 unfilled CRJ FO vacancies. Effective dates are mostly anticipated in the second half of 2020. Therefore there will be opportunities going forward for some new-hires on some initial courses at Jazz to bid for the CRJ.
Timing is everything. Same at AC.
Re: New hire bids
No YVR positions offered?KenoraPilot wrote: ↑Wed Feb 19, 2020 1:53 pmGGN pilots took CA and FO RJ at various bases
- KenoraPilot
Re: New hire bids
OTS:
2x Q400 YYC
4x DH8 YYC
- Flightnerd
Re: New hire bids
New hire and looking for information about the bid process in groundschool.
How does it work? Do you know a little ahead of time what the choices will be?
Do you have time to make a educated choice? Where could you find out if the plane you chose is even at a different base if you are planning on transferring.
I understand that basic idea of what the selection is like. Also if you get YVR is there time in the training schedule to go look for a place to live?
A
A
- KenoraPilot
Re: New hire bids
Flightnerd wrote: ↑Fri Feb 21, 2020 5:59 pm New hire and looking for information about the bid process in groundschool.
A
Hey,
On day 1 of GS they will post the positions and bases available. On day two you’ll drawn numbers for your seniority and choose type/base from what’s available. As for time to find a place to live it’s tricky. They’ll give you time to move (days off) but you’ve got to multi task a little. If you’re DH8 or Q you could be doing training in YVR which means you could be looking at the same time.
My advice, choose a base over a plane if you can. Where you live is far more important to what you fly. You can always change planes later.
Re: New hire bids
Remember your froze on type for 4 years so if your hoping to move to another base you have to be on a type that’s at that base. Right now all bases have all 3 types (RJ, D8, Q) except YVR which has no D8KenoraPilot wrote: ↑Sat Feb 22, 2020 10:34 amFlightnerd wrote: ↑Fri Feb 21, 2020 5:59 pm New hire and looking for information about the bid process in groundschool.
A
Hey,
Re: New hire bids
YYZ Q is very senior. You probably can't hold it for at least one year.
- Flightnerd
Re: New hire bids
Thanks for the help, also I was told ALPA members get a preferential choice as well. Or at least we might move up a little (depending on the make up of the GS) but do I need to do anything before hand in that respect. Is there a hold over time from when you leave one job for Jazz? It’s only going to be a couple days for me.
Re: New hire bids
It's based on your date of joining ALPA. Whoever joined the earliest gets to pick first. This can certainly make a huge difference on getting what you want vs getting whats left.Flightnerd wrote: ↑Mon Feb 24, 2020 6:22 pm Thanks for the help, also I was told ALPA members get a preferential choice as well. Or at least we might move up a little (depending on the make up of the GS) but do I need to do anything before hand in that respect. Is there a hold over time from when you leave one job for Jazz? It’s only going to be a couple days for me.
- Flightnerd
Re: New hire bids
Is there anything I have to do ahead of time? Or do I just make sure I have my ALPA number with me for the first couple days of ground school?Techno wrote: ↑Tue Feb 25, 2020 6:22 pmIt's based on your date of joining ALPA. Whoever joined the earliest gets to pick first. This can certainly make a huge difference on getting what you want vs getting whats left.Flightnerd wrote: ↑Mon Feb 24, 2020 6:22 pm Thanks for the help, also I was told ALPA members get a preferential choice as well. Or at least we might move up a little (depending on the make up of the GS) but do I need to do anything before hand in that respect. Is there a hold over time from when you leave one job for Jazz? It’s only going to be a couple days for me.
Re: New hire bids
Hey, welcome to Jazz, I don’t know the answer but I assume they know who is coming from an ALPA carrier. Being said, I would just ask on day oneFlightnerd wrote: ↑Sun Mar 01, 2020 5:51 amIs there anything I have to do ahead of time? Or do I just make sure I have my ALPA number with me for the first couple days of ground school?Techno wrote: ↑Tue Feb 25, 2020 6:22 pmIt's based on your date of joining ALPA. Whoever joined the earliest gets to pick first. This can certainly make a huge difference on getting what you want vs getting whats left.Flightnerd wrote: ↑Mon Feb 24, 2020 6:22 pm Thanks for the help, also I was told ALPA members get a preferential choice as well. Or at least we might move up a little (depending on the make up of the GS) but do I need to do anything before hand in that respect. Is there a hold over time from when you leave one job for Jazz? It’s only going to be a couple days for me.
Caterpillar
Re: New hire bids
What’s the bids for march 2nd GS ?
- KenoraPilot
Re: New hire bids
The 2 OTS: YYZ DH8
The last of the GGN pilots: all RJ at various bases
GS from now on are all OTS
20+ in the next two classes (16 & 30)
Re: New hire bids
Any insight of what will be available (base and type) for the 16th and 30th? Thanks
- KenoraPilot
Re: New hire bids
The company only chooses what will be available right before you start, not even ALPA knows what is coming up in the next GS. Its always a crap shoot, so just cross your fingers and have many contingencies.
