Depends on the aircraft and how much fuel with ferry tanks and extra weight was on board.co-joe wrote:I seriously question the logic of keeping an overspeeding prop running until final. In my mind, the only reason they could barely hold 4000' was the drag of an essentially windmilling prop. I don't know ducks but in the piston planes I've flown, the only way to control RPM would have been to reduce power out of the prop governing range. That would be a very low power setting causing much more drag than thrust wouldn't it?
Side question from those in the know: Wouldn't they have been a tonne or two over their landing weight with all that ferry gas? Doesn't that require a pretty major inspection to the landing gear?
And from a few episodes ago I'd just like to point out that nothing says "class" like wearing your very best plaid jacket to a wedding!I guess you can put a dress on a pig...
I doubt they were over weight on landing, and I'm sure they were aware of that. As for the overspeeding prop, I don't know the performance or limitations of this aircraft but to bring the prop rpm back to the green arc probably wouldn't be so much that it would cause more drag than thrust. The benefits of leaving that engine running (as long as you're within all operating limits), means you're still producing power. Even if it isn't contributing to adding a lot of thrust, it's still acting as a power plant (think generating purposes).
