New pot legislatiion brings on talk of pilot pee in a cup
cncpc
Re: New pot legislatiion brings on talk of pilot pee in a cup
Post by cncpc »
C.W.E. wrote: Thu Jun 14, 2018 8:28 pm How many people here would hire a pilot knowing they use cannabis for recreation?
Far more than you think, ..
C-GGGQ
Post by C-GGGQ »
cncpc wrote: Thu Jun 14, 2018 9:50 pm
I would also say that much like drinking, recreational use shouldn't matter (don't smoke, tried once and literally can't get high. Friend told me I was just wasting it :lol: )
I also know the research says that physically you cannot get addicted to weed. It's technically not an addictive substance. That being said, I know anecdotally several people who are absolutely addicted to it. It's purely psychological. They like how it feels so they want to keep that feeling. As stated before, some intensive research into longterm effects, and what impaired constitutes is called for.
AirFrame
Post by AirFrame »
C-GGGQ wrote: Thu Jun 14, 2018 10:17 pmI also know the research says that physically you cannot get addicted to weed. It's technically not an addictive substance.
Actually that's not quite correct. I had the same misconception until someone pointed me to the research showing that the body does form a mild chemical dependency, that will manifest withdrawal symptoms when the user stops smoking. Apparently only tested in heavy smokers though, and I don't recall what it said about the severity of symptoms. I recall it suggested that casual users either do not form the chemical dependency, or it's so mild that you wouldn't know it's there.
Keep in mind that these two terms are mutually exclusive... Addiction implies a chemical dependency that you're driven to support, not just a belief that you like getting high so you keep doing it.
C-GGGQ
Post by C-GGGQ »
AirFrame wrote: Fri Jun 15, 2018 6:58 am
I do realize that addiction is a chemical dependancy, however, your mind is more than strong enough to convince you of a "need" for something which is what I meant versus say meth where your body absolutely needs it or withdrawl sets in.
JasonE
Post by JasonE »
I think we often forget flying is a privilege. If I have to pee in a cup, then so be it.
GRK2
Post by GRK2 »
Hmmm, not sure if if I agree with that. A privilege? Probably not. A job? Or a hobby? Yes. A privilege is really a position one has over others because of wealth, or rank. I fly for a living, I have for 40 years, that's not a privilege, it's a career. I do agree with the second half of your statement though. If the public wants to trust me to carry them from A to B without being high on the herb, I don't mind peeing in a cup. Where I work now, (not in Canada) I am subject to random testing at work. It seems to be of little concern to my colleagues as well. It's just part of the terms of employment.
Rockie
Post by Rockie »
JasonE wrote: Fri Jun 15, 2018 9:00 pm I think we often forget flying is a privilege. If I have to pee in a cup, then so be it.
So is driving. Would you support random drug testing on the highway?
upnatem
Post by upnatem »
Rockie wrote: Sat Jun 16, 2018 6:46 am
They already do it for alcohol and they're working to get a reliable, portable test for pot as we speak.
GRK2
Post by GRK2 »
Driving, more like a need to do...still not a privilege. Pee in a cup argument not relevant here. Unless you're being paid to carry people.
Rockie
Post by Rockie »
GRK2 wrote: Sat Jun 16, 2018 7:56 am
Recreational drivers operate on the same roads professional drivers do and therefore put paying passengers at risk. I'd argue it is exactly the same. And nobody can operate a plane or a car without a license to do so by the government that can be suspended or revoked for cause. Privilege.
cncpc
Post by cncpc »
Rockie wrote: Sat Jun 16, 2018 8:03 am
90% in agreement with you on that bit. It's not quite that simple at law though. I think you've covered that by specifying "...for cause". It is a privilege, but other common law and Charter provisions require that there be objective grounds for granting that privilege (i.e. study, training, and testing). Passing a drug test is not one of them. In theory, everyone has the opportunity to earn the "privilege", some class of pilot license. However, once granted, and especially where the privilege of holding a license is connected to earning income and thus to the section 7 Charter right of security of the person, it cannot be removed except in accordance with the fundamental principles of justice.
The government may pass a law which fails the security of the person, or some other, Charter test if it shows that the law is a reasonable exception to the right. Obviously one aspect of that is that the right to life and security of their persons of all those behind the pilots. In the first step of the reasonable analysis, that is a very significant factor arguing for an exception to Charter rights. However, if we are talking about a marijuana pee test and assuming the lack of clarity on when marijuana use took place that is now inherent in those tests, that would likely result in the reasonable test being failed. Certainly removing a license for marijuana use generally would fail the Charter test.
When marijuana is legal, some judges and police will be either recreational or medical consumers. That is not a bad thing for pilots. Because judges will know of marijuana's effects first hand, they will know the effect it has on their judgment, their motor skills, all of that. Judges will know that there is a public imperative to ensure that pilots are clear headed when carrying out any duty related to the operation of an aircraft, beginning the moment duty time starts through to the end of duty time. They will not find that a test which cannot measure impairment and only posits use within the last 30 to 60 days meets the fundamental principles of justice test. To take away a license simply for marijuana use when not flying would violate another reasonableness test in that it impairs the impugned right as little as possible.
There is a hole in the factual basis that should inform policy making on pot. That has to do with a different type of impairment that may be in effect long after the normal periods when marijuana's effects are still present in the person. Or for some time after a person has quit using marijuana. We don't know much about the not high effects of use in heavy users, or perhaps even medium users, that directly relates to operating an aircraft. I am fairly sure that is an important piece of the puzzle that is now missing. When facts are known on this, it may be that heavy use, or even medium use, may be grounds for denying medical certification.
TeePeeCreeper
Post by TeePeeCreeper »
cncpc wrote: Sat Jun 16, 2018 10:44 am
I agree with you on most of that.
However judges are there to apply the law not to write it or base their decisions on personal knowledge in regards to their own impairment experiences.
It is my understanding that unless a pre employment condition stipulates drug screening that it goes against the charter.
At the end of the day, much like alcohol, love and chocolate everything is best in moderation and can become an addiction if too heavily relied upon.
All the best,
TPC
No Smoke, No Fire
Post by No Smoke, No Fire »
cncpc
Post by cncpc »
Beefitarian
Post by Beefitarian »
I just finished typing a tale about drug testing in another thread.
Cannabis testing is really pathetic. I once got hired at the same time as an apprentice by a company that sent everyone for pre hire drug testing. They made a big fuss about it warning you several times, "We require you get a medical. There's a drug test. Are you sure you can pass." I had never smoked any so I was reasonably sure.
The next week at work, during lunch one day, the apprentice claimed to smoke often and that he had even done so the evening before. Then he explained he bought two liters of orange juice. Drank half the night before, then the other half in the morning before the test.
I'm not suggesting you need to do that, but it supposedly worked. I have worked with lots of other users that also passed some form of test.
I have heard marijuana usually metabolizes in less than a week, whether you drink orange juice or not.
So I suppose if they test often some guys will be found to have used it. The next problem being they can't tell if you are high or smoked it a few days ago.
So if you like the weed I guess you could Lawyer up.
Victory
Post by Victory »
I can't help but feel jealous. All of Canada will be smoking and having a good time while we have to abstain because most of us fly to countries where it's still illegal and can be tested for it.
