And every third Monday thereafter.RegionalPilot wrote: ↑Tue Apr 19, 2022 11:41 am First ground school confirmed on May 16. Best of luck to all applicants!
Job Posting
Re: Job Posting
Re: Job Posting
Let the good times roll!rudder wrote: ↑Tue Apr 19, 2022 1:43 pmAnd every third Monday thereafter.RegionalPilot wrote: ↑Tue Apr 19, 2022 11:41 am First ground school confirmed on May 16. Best of luck to all applicants!
58
Re: Job Posting
Interesting,
I got an email last week asking me to do the hireVue "interview" although I didn't even submit my application yet...
Re: Job Posting
It’s a small IFR flight test at least that how it looks like.
Takeoff with approach and go around with a NDB HOLD!
Once that is done you do an approach with one engine
45 minutes before the sim you have access to the SOP and speeds and everything to memorize before the sim
You memorize the best you caN
The most important is the communication DONT DO ANYTHING before talking.
They wanna see your CRM level aswell
Hope it helps
Hope it helps
Re: Job Posting
Unlike pre covid if you did the process then, now they match you up with another candidate. Mine was on the Dash-300 at YYZ CAE. All the candidates show up as a group in the morning and throughout the day will have a physc evaluation as well as your sim eval. On arrival, you’ll be given a set of basic SOPs to review, the plates you will be using, as well as a Dash 8 cockpit poster. You and your partner will have about 90 minutes to review.
They're not judging you on your abilities to fly a Dash 8, as obviously very few candidates actually have Dash 8 experience. To make it a level playing field, no FMS, no autopilot and no flight director. The “Dash 8” is now effectively like any other multi engine aircraft, just slightly more complex in terms of performance.
The evaluation itself will take place in either pretend YYZ or pretend YVR, so it’s not a bad idea to familiarize yourself with some of the approaches and SIDS at these airports, also familiarization with Jep plates will help.
It’s basically just a MIFR flight test. SID departure, steep turns, hold clearance, engine failure + memory checks, then they’ll give you the engine back. You’re no longer required to fly the approach on one engine. You may or may not have runway contact at minimums, so be prepared to call a go around using the SOPs they gave you on arrival. Then you’ll do a visual approach to a landing.
Overall they’re judging your basic IFR skills and knowledge, your CRM, and they want to get to know you as a person. If your partner is unstable on the approach, call a go around. They love to see this stuff as it shows great CRM and that you’re not in a rush to finish. It can be very overwhelming to go into a sim for the first time, of an aircraft you’ve never flown, with someone you’ve never met, with a job on the line. They understand this, and you’ll probably do better than you expect.
Re: Job Posting
Not for the time being at least. The way they’re doing it now seems to work well, it was a positive experience for me that’s for sure. Very well organized and put together.
Re: Job Posting
hsilgnepilot wrote: ↑Sat Apr 23, 2022 3:34 pmUnlike pre covid if you did the process then, now they match you up with another candidate. Mine was on the Dash-300 at YYZ CAE. All the candidates show up as a group in the morning and throughout the day will have a physc evaluation as well as your sim eval. On arrival, you’ll be given a set of basic SOPs to review, the plates you will be using, as well as a Dash 8 cockpit poster. You and your partner will have about 90 minutes to review.
This is awesome to see, very exciting. Certainly better than the “Frankenstein” sims that were used when I went through this process.
Hopefully for the ones who’ve gone already (and the ones to follow shortly) you’ll get a real appreciation for the company and what you’re working towards.
The airline is by no means perfect, but getting a look behind the curtain at this stage of the game should be pretty d@mn cool.
Good luck everyone!
T.
Re: Job Posting
May be able to earn some brownie points too if you remember if you’re hired at jazz you’ll have an FA. After anything abnormal on the sim eval (hold, engine failure, go around) once the plane is flying nicely causally say “let’s give the FA a call and let them know what’s happening”. Shows an extra level of CRM that will be expected at any sim you do at jazz once hired.
Re: Job Posting
Anyone as any idea whats the dealio with DEC application for YYZ? Each time I click on the link it just brings me straight to the general pilot application.
There are no ways to manifest my personal interest for that position.
Re: Job Posting
Look in the requirement section for the "Pilot" posting. DEC will be offered to the best suited candidates that have an ATPL and preferably some 705 time.kiwi_paradise wrote: ↑Thu May 05, 2022 5:11 am Anyone as any idea whats the dealio with DEC application for YYZ? Each time I click on the link it just brings me straight to the general pilot application.
Everyone has to file an application under the same posting.
Re: Job Posting
Makes perfect sense. We will wait for some news from then thenthe-minister31 wrote: ↑Thu May 05, 2022 6:20 amLook in the requirement section for the "Pilot" posting. DEC will be offered to the best suited candidates that have an ATPL and preferably some 705 time.kiwi_paradise wrote: ↑Thu May 05, 2022 5:11 am Anyone as any idea whats the dealio with DEC application for YYZ? Each time I click on the link it just brings me straight to the general pilot application.
Re: Job Posting
To be extra clear, if a DEC position is of interest to you, don't wait for the vacancies to be announced, in some misplaced hope that you will have somehow jumped the line. Understand that FOs with ATPLs being hired now are going to get those CA slots (and the associated seniority) well before CA that will be hired OTS.kiwi_paradise wrote: ↑Thu May 05, 2022 8:03 amMakes perfect sense. We will wait for some news from then thenthe-minister31 wrote: ↑Thu May 05, 2022 6:20 amLook in the requirement section for the "Pilot" posting. DEC will be offered to the best suited candidates that have an ATPL and preferably some 705 time.kiwi_paradise wrote: ↑Thu May 05, 2022 5:11 am Anyone as any idea whats the dealio with DEC application for YYZ? Each time I click on the link it just brings me straight to the general pilot application.
In other words, don't read more into this announce than a fair warning that upgrades are about to become very quick, and that Jazz will very likely be unable to fill CA vacancies internally. Sooner you apply and get hired, sooner you will be a CA. It's that easy.
58
Re: Job Posting
Have they actually hired anyone yet or just interviewed?
Any word on course dates or if they have actually made any calls to fill a course?
Re: Job Posting
First class back is on May 16th, after that, a new class will run every 3 weeks.
Re: Job Posting
Is it every 3 weeks, or a ground school per month (the 3rd monday of each month)?There is conflicting information on the board…
Re: Job Posting
Effective June 06 it will be 16 hired every third Monday. At least that is the plan.RegionalPilot wrote: ↑Sat May 07, 2022 6:20 amIs it every 3 weeks, or a ground school per month (the 3rd monday of each month)?There is conflicting information on the board…
So it would look like this:
May 16 ?
Jun 06 16
Jun 27 16
Jul 18 16
Aug 08 16
Aug 29 16
Sep 19 16
Oct 10 16
Oct 31 16
Nov 21 16
Dec 12 16
For a total of approximately 160-176 hired in 2022. All subject to change (class size). Current limiting factor is training resources available.
2023 hiring required for attrition will likely be 320-360 (class of 20 every third Monday).
Re: Job Posting
Out of curiosity how long did you wait for the call after the drug test?
Re: Job Posting
I got the call yesterday as well. About 9 days after drug test. 2800 Tt + ATPL. Mix of 705/704 but all FO after flight school.702pipeliner wrote: ↑Sat May 07, 2022 12:06 pmOut of curiosity how long did you wait for the call after the drug test?
Re: Job Posting
All Yyz and yul based?rudder wrote: ↑Sat May 07, 2022 6:43 amEffective June 06 it will be 16 hired every third Monday. At least that is the plan.RegionalPilot wrote: ↑Sat May 07, 2022 6:20 amIs it every 3 weeks, or a ground school per month (the 3rd monday of each month)?There is conflicting information on the board…
May 16 ?
Jun 06 16
Jun 27 16
Jul 18 16
Aug 08 16
Aug 29 16
Sep 19 16
Oct 10 16
Oct 31 16
Nov 21 16
Dec 12 16
Re: Job Posting
About two weeks702pipeliner wrote: ↑Sat May 07, 2022 12:06 pmOut of curiosity how long did you wait for the call after the drug test?
