NT Air King Air Accident - Pilot Discussion Thread
cncpc
Re: NT Air King Air Accident - Pilot Discussion Thread
Post by cncpc »
TreeBlender wrote:
cncpc wrote: I also can understand how an experienced company man would want to land his machine with an issue at the most convenient location for a specific company's maintenance (like a machine based and maintained out of Calgary that has an issue Westbound over Banff might feel a "duty" to limp the plane back to Calgary where the mechanics are waiting inside a heated hangar with tool and parts at an arms reach rather than stranding the machine and passengers in Springbank) and I think this is where chief pilots, training captains and owners have to stand up and let their guys know it's not only OK, but it is preferred by them to first and foremost land at the closest/safest airport and worry about the passenger's and mechanic's convenience second.
CP's should look at how accidents like this can be prevented but they should not be making blanket standards such as land at the first available field. In this scenario, landing at Pitt could have resulted in even less survivors.
Springbank does not have ARFF services and neither does Pitt Meadows.
Springbank and Pitt have municipal Fire Fighters that are the same as the fire hall in your neighborhood. Their firefighters may have some minor courses that pertain to Aircraft Rescue Fire Fighting but they are by no means ARFF. Their lack of training and equipment is a minor concern.
The major concern is that the firefighters at Springbank and Pitt, are not required to be at the station. I watched someone in a plane crash die while waiting a substantial amount of time for rescue services to arrive. The Fire Hall on the field was empty as they were attending a vehicular accident elsewhere. The pilot was pulled out of the plane by an airport maintenance worker and their summer student.
Take a balanced approach. If there are two suitable airports within reach and one has ARFF, take the one with ARFF. You can check if ARFF's are present at an airport and the type, by looking under services in the CFS. Abbotsford has limited hours.
Actually, I didn't write that, I quoted it from another poster. I highlighted the bit I supported.
I doubt that this aircraft would have crashed at either Pitt or Abbotsford, so the availability of emergency services is really a moot point. It does seem that the longer the aircraft flew, the closer it came to the point of failure. Conversely, the shorter time it flew, the more it remained within a period of safe and normal operation.
This is not a criticism of the crew. The crew proceeded as if they had a minor issue, not an emergency that would require any emergency vehicles at all. They stated that on final. There was another aircraft waiting to take their passengers to their destination in Vancouver. There was no apparent risk in going to Vancouver. I doubt that the quality of emergency services had anything to do with the choice of Vancouver as the point of return.
I think that we first have to wait to learn the sequence of events in the transition from safe flight to loss of control. That may lead to a conclusion that, in future, based on what we have learned from this accident, that the best choice in at least a King Air 100 with oil temp and pressure indications is to land as soon as possible. It may also suggest shut down and secure is a wise course. I don't know if there is a previous incident that would have added this wisdom to our knowledge pool, but perhaps this will be the one that does. I would be surprised if this accident does not result in those who pilot these aircraft, and their passengers, being better equipped and thus safer. It is too bad the cost was so high, and fortunate that it wasn't higher.
twistedoldwrench
Post by twistedoldwrench »
I use to work on XRX many years ago, and I must say that back in the day it was a good aircraft, with way fewer "snags" than other 100's operated by our company at the time. As a maintenance provider I would have to say that the chain of events that lead to this tragedy should be of upmost importance to all in the industry to learn what may of happened and why. The event was obviously some sort of mechanical malfunction, the how and why of which I believe will be brought to light by the TSB investigation. As a maintenance person I hope and pray that some sort of oversight like leaving an oil cap off is not the case, as the knowledge of having done that would be hard to live with given the outcome.
A mechanical malfunction on the otherhand should be obvious and fairly easy to find once a tear down of the equipment in undertaken.
My guess- totally speculative, but given what I know about the configuration of the aircraft is that they experianced a power section gearbox problem, fluctation in pressure and temps would tell me they had metal in the oil, degraded pump function due to contamination, and maybe the leak from damage or crack in the PS housing. The Raisbeck (sp) kit that installs the 4 bladed Hartzell prop also pulls the engines rated torque at about 2 -300 less PRPM than the oringinal 3 bladed configuration, which in my opinion (no scientific proof here) puts more stress on the reduction gear bearings and shafts etc.
So following this , and given the fact that a PT6 will "almost" always keep on running, as long as they maintained the GG N1 at adequate power, the PS kept on turning- until they pulled the power back to land??????------ then the PS started to seize up or at least degraded PRPM, LH prop turned into a big sheet of plywood!!!
Just throwing that out there as my guess.
Really hope they find a mechanical issue as enough hurt is already out there- My condolances to all involved.
Old enough to know better, too young to quit
AEROMONKEY
Post by AEROMONKEY »
Please do not hesitate to call out the emergency equipment!!
We are here on standby all day for you guys.....thats what we get paid for! It frustrates us when we find out a pilot had a problem and didn't request our services...not saying thats the case here but i've seen it happen. I've also heard the tower trying to convince someone to declare after an engine failure!
again...if you need us ...do not hesitate to make the call!
Canoehead
Post by Canoehead »
^ I agree with AEROMONKEY. If in doubt, call them out. Better to have them go back to the hall emptyhanded and do 5 minutes of paperwork than wish they were 2 or 3 minutes sooner on scene.
It sounds like response was quick anyways, but could having the boys out on the field waiting perhaps made a difference in the loss (or saving) of Capt. Fortin's life?
These guys were real pros who were handed a raw deal at the last minute.
Condolences to all affected.
The Old Fogducker
Post by The Old Fogducker »
The whole idea behind "I won't declare an emergency because of all the paperwork, and this will likely work out OK" is bogus.
I've called the trucks out and there as zero paperwork, just an explanation on ground when it was all over, and that was the end of it. That explanation to the controller seemed to be more curiosity based than like facing a Spanish Inquisition Interrogator looking for aviation heretics.
So let me add my voice to "Call out the trucks" .... it's a free service.
OFD
fish4life
Post by fish4life »
The Old Fogducker wrote:The whole idea behind "I won't declare an emergency because of all the paperwork, and this will likely work out OK" is bogus.
OFD
I'd have to agree 100% with that, I have never heard of anyone having to do paperwork on the ground other than an SMS report but that would be completed anyway since you had an abnormality and had to return.
goldeneagle
Post by goldeneagle »
AEROMONKEY wrote:Please do not hesitate to call out the emergency equipment!!
Ok, now this may be a dumb question. Assume the trucks were on standby near the threshold for a 26L landing at YVR. Aircraft ends up short, on Russ Baker way as happened in this incident. What route would those trucks take from the threshold to the incident ?
a) Would they plow thru the fence, and go direct ?
b) Would they backtrack to the gate at one of the cargo terminals, then take the road ?
I'm asking, because I have been wondering over the last couple of days, if the trucks were on standby at the threshold, are they equipped and capable of going thru the fences on the approach end, to get directly to the incident location ? Or, would that route end up with trucks tangled in fencing, and unable to reach the incident only a few meters away from trucks disabled by tangled fences ?
Unit 969
Post by Unit 969 »
Knowing is half the battle
enbt
Post by enbt »
I found this statement from one of the survivors interesting.
In a telephone interview with CBC News, passenger Loralie Sobolik said the first sign of trouble was a leak she spotted as she was boarding the plane, but said the pilot told her there was nothing to worry about.
e300d
Post by e300d »
I have to dig, but I read in one of the Van Sun articles that one of the trucks ripped right through the fence...
Redneck_pilot86
Post by Redneck_pilot86 »
I believe it said that the truck crashed through a gate near the accident and a few others went around the road.
Post by North Shore »
AND
OFD
Given that there seems to be some reticence on our (pilots') behalf to call out the trucks, wouldn't it be better to simply add a page to the Control Tower manual, stating that whenever a pan/mayday/mechanical is issued by an aircraft, the trucks will be dispatched prior to landing?
Happiness is V1 at Thompson!
The Old Fogducker
That most likely is the SOP for a Mayday or a Pan .... no separate request for CFR required, you get "full service." The mechanical issue may be what is at the heart of this ... I don't profess to know.
Oscar Fox Delta
C-FABH
Post by C-FABH »
For rapid response vehicles, direct, absolutely. Not only are specialized ARFF trucks designed to drive through chain-link fences at 70 mph, but they're also capable of flattening most small trees. They're built to handle that.
FastFlyBy
Post by FastFlyBy »
Lets see if this works, try plugging these into google earth
Initial impact spot: 49.181759, -123.150677
Final resting spot: 49.181738, -123.151160
Gate: 49.18478, -123.150546
Response Centre: 49.195139, -123.188217
The gate is only 400m from where the aircraft ended up.
cncpc
Post by cncpc »
That's an interesting bit of research. Your post seems to have gotten lost in the discussion about calling out the trucks.
Does anybody know if this information went to Canadian operators?
Its What I do
Post by Its What I do »
As far as I can see they didnt get a straight in ???why not??
With a mechanical issue I would hope for a straight in approach .
And such a nice day little wind , why didnt he shut down for a precaution ?
Lots of things make one think ..30 more seconds he would have been on the ground .
If the engine let go 5 minutes earlier he would have been higher and probably been able to shut it down and make a single engine landing ...Damn ..
But what do I know
RatherBeFlying
Post by RatherBeFlying »
Part of airport design is the provision of frangible emergency gates. ARFF knows where they are and there's reports they crashed through one.
viccoastdog
Post by viccoastdog »
Dude, that link is to a TC website! Every operator knows about it to check for ADs.
cncpc
Post by cncpc »
Yes, I know, I didn`t quite phrase that the way I wanted to.
Not implying anything untoward. Wan`t even effective till today.
Interesting to know there is a problem with certain parts of the power unit.
TA/RA
Post by TA/RA »
Way to go Luc! Google images got it right!
Screen Shot 2011-11-01 at 9.24.27 PM.png (342.65 KiB) Viewed 4253 times
HeadingAltitudeSpeed
Post by HeadingAltitudeSpeed »
North Shore wrote: Given that there seems to be some reticence on our (pilots') behalf to call out the trucks, wouldn't it be better to simply add a page to the Control Tower manual, stating that whenever a pan/mayday/mechanical is issued by an aircraft, the trucks will be dispatched prior to landing?
ATC has the ability to declare the emergency for you when you are reluctant. I do it on a routine basis. There is a perception in the community that declaring is a bad thing that involves paperwork and is an inconvenience to everyone if nothing goes wrong. I will echo the words of some of the old timers here. Declare anytime you have a situation that has the potential to get worse. It is far easier for us to assist with a problem that suddenly gets worse when we are already in the picture.
Its What I do wrote:As far as I can see they didnt get a straight in ???why not??
But what do I know
Controllers can call the trucks out without a pilots request as well if there is an indication that there is a potential need for them. Again, if all indications to us is that problems are minor or of a routine nature we won't override. Some operators have been annoyed with trucks at the runway standing by for a minor problem because of the passenger perception of how serious it really was. In my tower days I always called the trucks out. It is much easier for them to assist when they are already out and waiting. I never heard a complaint from them for having to come out early.
Why no straight in? I would guess it is again based on the information relayed to ATC. Returns to airport due to mechanical issues are fairly common. Often as a result of an "indication". Unfortunately with limited information we will generally get you onto finally as quickly as we can while fitting you into the established traffic flows. Unless you give us an indication of something more serious.
Please, never hesitate to declare an emergency. You then have our undivided attention and as much time and space as you need to get yourself safely back to the ground.
greenasgrass
Post by greenasgrass »
The problem with declaring an emergency, is that you not only get the ARFF group underway, but you also just generated a CADOR. There are few worse than being chastised by management for erring on the side of caution. Please don't read into this that I speculate NT Air is this type of operator, they are not. But anyone involved in this industry for any length of time knows of what I speak...
GaG
Post by ahramin »
greenasgrass wrote:Nothing worse than being chastised by management for erring on the side of caution.
Actually, there is far worse than being chastised by management for doing your job properly. For example rolling your plane into a ball. In fact, I can't think of anything that isn't worse. If some idiot in management chastised me for calling out emergency services when it turned out I didn't need it, no big deal. I'd put them in their place, referencing the company's SOPs, OPS Manual, CARs, etc.
cncpc
Post by cncpc »
Anyways, re the AD above, CBC ran a story on radio at 1:00 today with a segment from the general manager at NT and he said the company was aware of the AD, complied with it before the effective date, and did not find any of the referenced parts installed.
