kingeddie
Re: Pic from a swamper
Woodland Caribou
- 2008 caribou flights feb 26 115.jpg (26.38 KiB) Viewed 3941 times
kingeddie
Helitorch/NVG Tanker/ On the rocks
- IMG_0074.jpg (77.96 KiB) Viewed 3936 times
- IMG_0055.jpg (34.41 KiB) Viewed 3935 times
- IMG_0037.jpg (25.57 KiB) Viewed 3933 times
kingeddie
A few more from the old CD pile
- DSCN0082.JPG (659.74 KiB) Viewed 3932 times
- DSC00103.JPG (60.37 KiB) Viewed 3910 times
- Before and after OOPPS
- Red66.jpg (253.42 KiB) Viewed 3912 times
kingeddie
Happy New year
- Me in 3.JPG (33.48 KiB) Viewed 3888 times
- scan0024.jpg (650.42 KiB) Viewed 3910 times
- scan0013.jpg (697.86 KiB) Viewed 3912 times
kingeddie
Heli Pics
- P1020104.JPG (547.63 KiB) Viewed 3792 times
- P1020087.JPG (540.44 KiB) Viewed 3792 times
Cree Lake early in 2008
- Cree Lake BNA.jpg (51.2 KiB) Viewed 3741 times
mag check
Cool pics, But I thought that to drop anything out of an aircraft, you need to wear a chute?
I could be wrong, as I'm sure that the MNR would follow all the regs
I believe the reg only states that you cannot drop anything if it poses a threat to persons or property. I don't remember anything about wearing a chute.
No such regulation. Not sure where you dug that up from!! MNR has been dropping stuff from airplanes and helicopters for almost 80 years and don't own any parachutes.
Just from a picture, how do you tell the difference between a 215T and a 415?
mag check
Well, I know that dropping skydivers the pilot needs a chute, and I'm pretty sure that somewhere in the regs it says that any air drop needs one. I'll look into it.CLguy wrote:No such regulation. Not sure where you dug that up from!! MNR has been dropping stuff from airplanes and helicopters for almost 80 years and don't own any parachutes.
mag check
Hmmm, guess I'm wrong, can't find it. All I can find is that you can't create a "hazard" to anyone or thing. Not too sure how to drop something from an aircraft without creating a hazard, but at least you don't need a chutemag check wrote:Well, I know that dropping skydivers the pilot needs a chute, and I'm pretty sure that somewhere in the regs it says that any air drop needs one. I'll look into it.CLguy wrote:No such regulation. Not sure where you dug that up from!! MNR has been dropping stuff from airplanes and helicopters for almost 80 years and don't own any parachutes.
Dropping of Objects
602.23 No person shall create a hazard to persons or property on the surface by dropping an object from an aircraft in flight.
Hmmm, guess I'm wrong, can't find it. All I can find is that you can't create a "hazard" to anyone or thing. Not too sure how to drop something from an aircraft without creating a hazard, but at least you don't need a chutemag check wrote: Well, I know that dropping skydivers the pilot needs a chute, and I'm pretty sure that somewhere in the regs it says that any air drop needs one. I'll look into it.
yeah the skydive pilot i was with didn't wear one. and as long as you aren't aiming at a person or property (building) you aren't posing a hazard. (see amatuer flower bombing competetions)
just curious
- Rank Moderator
Took me a while to figure out what you were talking about, but I'm pretty sure that the pic of the helo with the bag going out the door would have been taken from the boat maybe 6 feet below. A chute isn't going to help.
mag check
Sorry for the minor de-rail, on with the pics
kingeddie
There are regs you are correct .. There are also exemptions in the form of commercial ops specs .. The picture is of fire hose being free dropped to fire crews on the ground that are building line around a fire front, hose lays can be miles long through areas where there are no landing areas and if the crews carried the hose from the landing area the fire would likely have burned over the area we are trying to contain . There also ops specs we use for entering or exiting an aircraft while it is in flight (no parachute) . For fire fighting , preservation of human life and operating under authourity of a police agency there are many exemptions . Water bucketing , water bombing and dropping of supplies are only a few..
Eddie
Eddie
Basic Flying Rules: 'Try to stay in the middle of the air. Do not go near
the edges of it. The edges of the air can be recognized by the appearance
of ground, buildings, sea, trees and interstellar space. It is much more
difficult to fly there.'
Johnny the only way is if the waterdoors are in the picture. The 215T has the old system which is 2 larger drop doors on the bottom of the hull and the 415 has 4 smaller doors. You can also tell if the picture is of the cockpit. The 415 is glass and the 215T has the older style instruments.
- Rank Moderator
On with the pix.
Non-Canadian bush.... But I think it qualifies.
Just another canuck
Not Canadian bush either.... but still good.
So throw off the bowlines.
Explore. Dream. Discover.
- Rudder Bug
Canuck
This looks like and Islander dash, an Islander nose and an Islander airstrip! Where was that???
Just another canuck
That is a Caravan my friend.... and it's in a place called Sinak in West Papua, Indonesia. Runway is at 7000' with a 12% incline. You usually land with close to full power cause of the altitude... and sink you get off that little bump at then end of the runway. Doesn't look like much but it sure has some effect.Rudder Bug wrote:Canuck
Cheers.
JAC
- Rudder Bug
I should have look a little better before posting. BN-2's usually don't have a prop spinning up front!
