New hire bids
				hank998899
Re: New hire bids
Are there normally more in a new classroom? What’s the size of your typical new hire GS?
if you are on the ground I guess there is now way but to look up!
				kiaszceski
Re: New hire bids
kiaszceski wrote: ↑Mon Feb 20, 2023 12:49 pm20
Oh ok , thanks! I guess 19 out of 20 seems like a full class.
						Re: New hire bids
They cannot get CA to leave YYC/YVR. Western CA attrition to AC is nominal. So attrition FO spots are filled to balance rosters.
If 10 western CA resigned tomorrow, then there would be less new-hire opportunities out west.
				Malfunction
Re: New hire bids
Lots of yvr cpts leaving. Bottom 1/3 are leaving
Re: New hire bids
YVR is not the problem. When the dust settles, YVR will likely be the only western base.Malfunction wrote: ↑Sat Feb 25, 2023 7:11 am
AC pilot bases - YUL/YYZ/YVR (*YWG 50 pilots due to ACPPA)
Jazz pilot bases - YUL/YYZ/YVR
This is what Bill Bredt (Jazz COO seconded from AC) wanted in 2004.
				hank998899
Re: New hire bids
New bid numbers
CRJ 2xYYC 2xYVR FOs
Q400 6xYYZ CAs OR 4xYYC 2xYVR FOs
E175 2xYUL 6xYYZ FOs
CRJ 2xYYC 2xYVR FOs
				canadian_aviator_4
Re: New hire bids
%100 Agreerudder wrote: ↑Mon Feb 27, 2023 6:32 amYVR is not the problem. When the dust settles, YVR will likely be the only western base.
Re: New hire bids
How do they assign the equipment and base?hank998899 wrote: ↑Mon Mar 13, 2023 3:29 pm New bid numbers
CRJ 2xYYC 2xYVR FOs
Depending who got hired first?
				canadian_aviator_4
Re: New hire bids
What is the experience level of the new hires these days?
				hank998899
Re: New hire bids
New hires that were part of ALPA carriers before get first pick in order of date of hire at their previous carrier, then it’s random seniority draw…capt_Z wrote: ↑Mon Mar 13, 2023 7:23 pmHow do they assign the equipment and base?hank998899 wrote: ↑Mon Mar 13, 2023 3:29 pm New bid numbers
CRJ 2xYYC 2xYVR FOs
Re: New hire bids
I've heard 750 Hrs people getting offers.canadian_aviator_4 wrote: ↑Mon Mar 13, 2023 7:37 pm What is the experience level of the new hires these days?
- RoAF-Mig21
Re: New hire bids
When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
				flyingcanuck
Re: New hire bids
Second day is I remember right. When you do the seniority drawRoAF-Mig21 wrote: ↑Mon Mar 13, 2023 9:17 pm When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
- RoAF-Mig21
Re: New hire bids
Cheers for that! 'ppreciate it!flyingcanuck wrote: ↑Tue Mar 14, 2023 7:13 amSecond day is I remember right. When you do the seniority drawRoAF-Mig21 wrote: ↑Mon Mar 13, 2023 9:17 pm When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
Re: New hire bids
There is no such thing as a "March" seniority list. The seniority list only gets updated once every January. The soonest they'll see their name on anything is in the next bid in April, or once they are assinged an aircraft and base they'll appear on that aircraft's elegibility list on Report Link.RoAF-Mig21 wrote: ↑Mon Mar 13, 2023 9:17 pm When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
Re: New hire bids
Seniority list is updated and issued quarterly.slicktop wrote: ↑Tue Mar 14, 2023 3:44 pmThere is no such thing as a "March" seniority list. The seniority list only gets updated once every January. The soonest they'll see their name on anything is in the next bid in April, or once they are assinged an aircraft and base they'll appear on that aircraft's elegibility list on Report Link.RoAF-Mig21 wrote: ↑Mon Mar 13, 2023 9:17 pm When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
Position list is updated monthly.
Re: New hire bids
Hmm. Sounds like this is in the wrong sub forum.
Re: New hire bids
Yes - that reply was definitely based on the AC system.BTD wrote: ↑Thu Mar 16, 2023 7:59 amslicktop wrote: ↑Tue Mar 14, 2023 3:44 pmThere is no such thing as a "March" seniority list. The seniority list only gets updated once every January. The soonest they'll see their name on anything is in the next bid in April, or once they are assinged an aircraft and base they'll appear on that aircraft's elegibility list on Report Link.RoAF-Mig21 wrote: ↑Mon Mar 13, 2023 9:17 pm When do new hires get posted to the seniority list? Is it as soon as possible, or once they get their line check done? Would someone that got his plane 3 days ago show up on the March seniority list?
				Roundel Randy
Re: New hire bids
If you end up with something you don't want, when is the earliest you can switch? Is it possible to wait until the next bid?hank998899 wrote: ↑Mon Mar 13, 2023 7:37 pmNew hires that were part of ALPA carriers before get first pick in order of date of hire at their previous carrier, then it’s random seniority draw…capt_Z wrote: ↑Mon Mar 13, 2023 7:23 pmHow do they assign the equipment and base?hank998899 wrote: ↑Mon Mar 13, 2023 3:29 pm New bid numbers
CRJ 2xYYC 2xYVR FOs
Re: New hire bids
Depends on what it is you don't want. If it's your base, that is a non-issue because you will more than likely be awarded your base of choice before the end of training.Roundel Randy wrote: ↑Sun Mar 19, 2023 8:51 amIf you end up with something you don't want, when is the earliest you can switch? Is it possible to wait until the next bid?hank998899 wrote: ↑Mon Mar 13, 2023 7:37 pmNew hires that were part of ALPA carriers before get first pick in order of date of hire at their previous carrier, then it’s random seniority draw…
If it is the equipment, you will be subject to an equipment freeze for 48 months,. The only exception is if you get awarded the E75 and want to move to YVR or YYC, in this case you would be released from your freeze after 24 months because there are no E75 based in the west.
The only other way to get released from your freeze is to bid a CA seat on your desired equipment, but beware that there are quite a few that have found making the move to the left seat on a new type somewhat challenging. Many (including me) will recommend to either switch type in same position then upgrade, OR upgrade on your current equipment and THEN switch type.
All that said, there are no "more desirable" equipment at Jazz; all types have something to offer and also have their inconveniences. Best is to make the most of it rather than remain bitter and twisted because you didn't get the type you wanted. That is a sure recipe to be miserable.
58
