Overdue Cargo Airplane Bound for CYXS
I_Drive_Planes
Post by I_Drive_Planes »
The following was posted on the YXS - Prince George Airport Facebook page this morning:
We were notified around 8:00 this morning that a cargo courier flight was overdue. Prince George Airport Emergency Services are on standby. We will continue to provide updates as they take place.
250 News is reporting it here: http://www.250news.com/2015/04/13/overd ... ht-at-yxs/ Without any real details.
I was doing some poking around on the flight tracking websites and found this http://www.flightradar24.com/data/flights/ca66/#5fe017d and this: https://flightaware.com/live/flight/CA6 ... /CYVR/CYXS Though its status shows "landed" the timing is right and there is only a partial track showing, ending in the North Shore mountains. I also don't see it on any of the Wx Cams at CYXS.
Re: Overdue Cargo Airplane Bound for CYXS
IIRC thats one of Carsons Metros..
Hope it turns out to be a non event.
I_Drive_Planes
Rowdy wrote:IIRC thats one of Carsons Metros..
I had hoped so also, but that's looking less likely now.
http://www.myprincegeorgenow.com/14504/ ... ce-george/
Gear Jerker
Post by Gear Jerker »
Fingers crossed that the crew is safe and sound!
Look, it's f***in Patrick Swayze and Reveen!
Prodriver
Post by Prodriver »
"I need a time machine"
arctic_slim
Post by arctic_slim »
That's brutal. Please if anyone knows who the pilots are on that aircraft can you PM me and let me know if one of the pilots initials? im getting worried now.
PointyEngine
Post by PointyEngine »
Always the worst feeling. Fingers crossed the got it down somewhere and just haven't checked in.
Post by 180 »
Fingers crossed for a positive outcome here...sure hope it's not a repeat of the 2005 NT King Air accident North of Squamish.
floydfrank
Post by floydfrank »
Looks like forecast icing and sw winds aloft on their route with freezing levels down around 3000'.
The search looks like its around Mt Seymore. Should be a great deal of resources in that area being so close to North Van, so lets hope for the best.
https://twitter.com/wilfundal/status/58 ... 72/photo/1
boeingboy
Post by boeingboy »
Always hoping for the best - but Lynn Valley and surrounding area is not a good place to go down. Lots of steep cliffs, deep valleys, and trees - no place to set down if anything bad went down....... :cry:
CpnCrunch
Post by CpnCrunch »
180 wrote:Fingers crossed for a positive outcome here...sure hope it's not a repeat of the 2005 NT King Air accident North of Squamish.
Doesn't look like it from what I can tell...they were well above the nearby terrain and above the MEA on V347. The flightaware track ends just as they intercepted the airway.
From listening to the Live ATC archive, they were cleared to 16,000ft which they acknowledged, and then there are no further transmissions from then. A while later another aircraft is asked to try to contact them on company frequency, and then another aircraft is asked to listen for an ELT signal.
BBQ Chips
Post by BBQ Chips »
I feel sick even thinking of having to ever put down in the terrain around Vancouver. Does anyone know if cargo planes require TAWS? It always blew me away when I began flying out west in the rocks that TAWS was not mandatory. I know things have changed for some operations recently, but the thought of not upgrading your planes because it is not a legal requirement is fucked up.
My thoughts are with all my peers and those affected.
PositiveRate27
Post by PositiveRate27 »
If anyone has info on the pilots I'd appreciate a PM as well.
goldeneagle
Post by goldeneagle »
Dont really see how having TAWS would make any difference. The last radar plot and altitude shows them going thru about 8000 and climbing, speed around 240 knots. They were well above terrain in the immediate area by that time, and at the rate they were climing, another minute and a bit would put them above all terrain between that position and the intended destination.
Highly unlikely this is a case of blindly and unknowingly flying into cumulus granite. Something else happened.
PointyEngine
BBQ Chips wrote:I feel sick even thinking of having to ever put down in the terrain around Vancouver. Does anyone know if cargo planes require TAWS? It always blew me away when I began flying out west in the rocks that TAWS was not mandatory. I know things have changed for some operations recently, but the thought of not upgrading your planes because it is not a legal requirement is fucked up.
No TAWs required.
BBQ Chips
Post by BBQ Chips »
goldeneagle wrote:Dont really see how having TAWS would make any difference. The last radar plot and altitude shows them going thru about 8000 and climbing, speed around 240 knots. They were well above terrain in the immediate area by that time, and at the rate they were climing, another minute and a bit would put them above all terrain between that position and the intended destination.
I never said TAWS would have made a difference, but I am damn sure that having a tool which tells you where the rocks are when you are in a pinch is never a bad thing.
Post by bizjets101 »
"The high-probability zone that we're currently searching is northeast of Vancouver by about 14 kilometres. It's between Grouse Mountain and just south of Cathedral Mountain," Trenholm said. "It's simple math, just looking at the flight plan. This aircraft had a true airspeed of 269 knots, plus the location of where it was lost on radar." from Vancouver Sun
Post by 180 »
Thanks for pointing that out CpnCrunch. Appreciated.
Still hoping for the best...
7ECA
Post by 7ECA »
Pretty lousy day to be out, with moderate to severe turbulence up and down the Coast. And, the moderate to severe icing, from around 3000' - 14,000', again along the Coast.
200hr Wonder
Post by 200hr Wonder »
Just saw on Global News that the North Shore search and rescue have found debris and the smell of Jet A. Does not look good at all.
200hr Wonder
boeingboy
Post by boeingboy »
Should be clarified it's paper in the trees - the aircraft is not yet found. Even so - there is very little doubt as to their fate.....this is not a good day.
Jibbs
Post by Jibbs »
Just curious......
Would the controller have a warning on his screen, or otherwise, if the aircraft was still on radar and was below a certain minimum/vectoring altitude. After listening to the ATC archives it seemed to be business as usual until they started a com search and asked an aircraft to listen for an ELT.
burninggoats
Post by burninggoats »
co-joe wrote:The search looks like its around Mt Seymore. Should be a great deal of resources in that area being so close to North Van, so lets hope for the best.
Yeah right. The people in North Van are probably just upset that a plane made noise near their multi million $$ houses, and appalled at the fact that some jet a might have come in contact with the ground.
I am still holding hope the result is more positive than it looks, but the longer it goes on the harder it is to keep my optimism. My thoughts are with everyone at Carson.
SundayDriver
Post by SundayDriver »
I'm sure no one in North Van thinks that. Grow up
My thoughts go out to all involved
