Turkish Airlines Makes Emergency Landing in Istanbul
CFM Symphony
Re: Turkish Airlines Makes Emergency Landing in Istanbul
https://www.youtube.com/watch?v=Sy-UtJG ... e=youtu.be
Interesting choice to blow the slide on the right hand side. Bad few months for Turkish, especially after their growth plans have been put under the microscope recently due to lack of infrastructure.
The landing gear door are not full closed on the nose gear, it's hard to see on the main wheels. It looks like they might have had problems deploying full gear down, as the plane seems to sit lower then normal. Part of the reason the engine is scraping the runway...hard to say for now.
http://avherald.com/h?article=48546eb6&opt=0
A THY Turkish Airlines Airbus A320-200, registration TC-JPE performing flight TK-1878 from Milan Malpensa (Italy) to Istanbul (Turkey) with 97 passengers, landed on Istanbul Ataturk Airport's runway 05 at 10:22L (07:22Z) but rolled right just before touchdown causing the right engine and wing to contact the runway and a hard touch down. The crew initiated a go-around, then declared emergency due to an engine (V2527) inoperative. The crew subsequently reported an unsafe gear indication. The aircraft positioned for an emergency landing on runway 35L, touched down about 20 minutes after the go around, but with the right main gear collapsed the aircraft skidded on its right engine, with sparks and smoke trailing the engine, and veered right off the runway spinning nearly 180 degrees. The aircraft was evacuated via slides while emergency services started to spray the aircraft. There were no injuries, the aircraft received substantial damage to the right hand main gear, right hand engine and its pylon as well as to leading and trailing edge high lift devices at the right hand wing.
The airline confirmed the aircraft went off the runway during an emergency landing, the 97 passenges have been safely evacuated, there are no injuries.
A passenger reported the aircraft was on its first approach to Ataturk's Airport uneventfully until about 100 feet AGL when the aircraft suddenly rolled heavily to the right and fell down onto the runway, while on the ground the aircraft was still tilted to the right, the engines accelerated and the aircraft became airborne again, the passenger thought the right main gear had collapsed at that point already. While positioning for the second approach another passenger yelled "Fire". Cabin crew instructed the passengers to brace for landing. The second touchdown was smooth, however, there were scraping sounds from the right, the passenger did not notice a gear collapse during roll out, only after the aircraft had slowed significantly the aircraft began to veer to the right. The doors were opened, passengers directed to the left forward and right rear doors for evacuation, when the right hand overwing exits were opened foam from the fire engines entered the cabin. About 5 minutes after landing busses arrived and took the passengers to the terminal.
white_knuckle_flyer
Wasn't there recently a recent thread, lively debated, which discussed the pros and cons of a go-around after initial ground contact ? And here is an actual example. Mind you, that thread was centred around a single engine aircraft and involved a prop strike, but this is still a pretty fitting example.
Should the pilot have kept it on the ground the first time ? Thoughts ?
White knuckle flyer. A 120,000 lbs jet is vastly different than a 2500' 172.
Even more so, the aircraft s fully capable of a go around sans-engine.
The crew, rightfully, assumed a shitty landing, called for a go-around. Ran checklists, and came back for an emergency landing.
I'm willing to bet if there are any injuries, it's solely a result as some idiotic passenger trying to grab their bag with their iPad, in order to grab a selfie.
Semper Fidelis
Semper Fidelis
Meatservo
