Is a Second Officer a "Pilot"
I've always wondered about this.
You're a SO on a 727, and someone comes up to you on the street and ask what you do for a living.
What do you say?
"I'm a pilot"
"I'm a pilot, but I don't really fly the plane."
"I'm a wannabee pilot"
You could always say you're "a Second Officer on a 727", but most non-aviation people have no idea what a second officer is. And then you have to explain everything, which must get tedious.
Just my weird thought of the day...
What do you say?
"I'm a pilot"
flyincanuck
- bizjet_mania
Can you be an SO without being a pilot ? AME's can be a FE but I don't think I've met an SO's that didn't have a commercial pilot licence. I know SO's keep IFR currency provisions while in the seat as well sooo I think I just answered my own question. Thx for coming out
Hungry Mike
Hungry Mike
Mike,
That's the point... an SO is a licensed commercial pilot, but in terms of his job he's not really a pilot. So there's the source of confusion.
I can see a conversation going like this:
Joe Blow: "So what do you do?"
S/O :"I'm a pilot."
Joe Blow: "Wow, it must take a lot of skill to land those big jets."
S/O: "Well, I don't actually land the plane..."
Joe Blow: "But you said you're a pilot????"
S/O :"I'm a pilot."
- DragEraser
Piloto Cargaero
As an SO, you are most definitely a pilot.
For those people who don't understand aviation, I used to say that I did the job of the Flight Engineer, but I'm the "spare pilot" in case anything went wrong. They seemed to understand that. One scenerio we worked on in the sim was a rapid descent drill where the FO didn't get his O2 mask on in time and was considered "dead" by the sim instructor. Although it wasn't in our company SOP's, we were expected to set up our panel, get out of our seat, pull the "dead" FO out and help the Captain land the 727 with the cargo door blown off.
For those who do understand aviation, there is this prevalent opinion out there in pilot circles that 1) it is a waste of time (ie not log-able time) for a pilot to take a position, and 2) that you're not really a pilot. Believe me, it is the hottest seat in the house especially when things go wrong.
My time as an SO was some of the most memorable days flying. You are another set of ears and eyes for things like approach briefings etc... you can also take care of ATC when things get a little hairy up front. There were many occasions where I picked up on errors made by the PF and missed by the PNF (minor things like an error in take off weight by 10,000 lbs). You're not just a "glorified switch-flicker"... hardly.
I had fun as an SO as I said before, I hope you enjoy every minute of it as well.
Speaking from very recent experience the SO is the busiest person on board the aircraft regardless of emergencies, it just increases exponentially when the red lights and bells start coming on. Any past SO can relate to being on the floor with a flash light cranking down the gear while balancing fuel onboard a turbulent aircraft. It's also been proven that the safest cockpit is a 3 man cockpit because that 3rd pair of eyes can catch a lot when the PF and PNF get busy. With a competent Captain and crew delegating duties it's amazing how smoothly emergencies can be handled.
I would do it again in a second if I were given the opportunity although it doesn't beat flying the aircraft it sure is an amazing learning experience that often leads to an eventual FO upgrade. I learned more with my time as an SO than I ever did flying smaller equipment.
As for a title or explanation to a non flying type I simply say I’m a commercial pilot working as a second officer and explain that an SO is the systems operator on older aircraft before automation. They either get confused and don’t ask anymore questions or become really interested and understand totally.
Also don't forget to log the time as "SO Time" as some larger companies will count a percentage if it and put it towards your TT.
therubberjungle
Luscombe,
Howdy, fellow Caper!
SO is a pilot? Well, yeah, by definition. The back seat was intended for flight engineers, consult your Boeing paperwork re terminology if you don't believe me. The US does not recognize SO, only FE. You have to write an exam to sit in the back seat south of the border. In Canada, it's a whole seperate license. Correct me if I'm wrong but Morningstar is the only Canadian company currently producing FEs.
I once had a Flight Engineer (who was a pilot) tell me that if the PF was incapacitated that he would leave his seat and "help" me fly the plane. My response was curt: "No fucking way, son. Stay back there and keep an eye on the systems." Yeah, I'm old enough to have called him "son".
The best help he could offer me was to stay in his seat and monitor the back panel. Any compounding emergencies would have spelled BIG shit if he was sitting up front instead of back there where he belonged. Yes, our company had LOFT profiles where one pilot "died", the surviving pilot was expected to land the plane while using the back-seater, when required, to select radio freqs, talk on the radios, select gear and flaps, when commanded... FROM THE BACK SEAT.
"Glorified switch flicker"...yup. I have sat in the back seat and I can state, without hesitation, that a GOOD flight engineer is worth his weight in gold. A good second officer is just that: a good second officer. I was a good second officer, nothing more.
Here's what I mean: an SO hits a switch and sees (or not) the expected result. An FE hits the switch, sees (or not) the expected result and knows exactly what has happened to give that result. They're AMEs after all, they have worked on the aircraft, so their knowledge far surpasses that of the SO "switch flicker".
SO experience is valuable without question. Don't confuse it with "pilot" time, it's not. It will make you a better pilot, no question, but there's a reason you can't log it in your book: you don't fly the bird from the back seat.
- Panama Jack
Flight Engineer, oh yeah, that's the guy who brings the plunger to work.bizjet_mania wrote:flight engineer sounds like ur a mechanic of designer... both sound better than a pilot
I personally prefer the term Flight Engineer (TC has bastardized the term Second Officer). At some airlines, a Second Officer is a cruise pilot, and definately not to be confused with the flight crew member who routinely slams the car door on his legs after work.
-President Ronald Reagan
Well, isn't a holder of a pilot's license a pilot regardless of what they do for a living? They could be a garbage man and have a PPL and be a "Pilot". Either way, trying to classify your seat should be the least of anybody's worries. In the end, you hold the license, your a pilot, you just happened to be working as a Second "O" or FE, whatever.
therubberjungle
I know as a fact, the "FE or SO" on the 727 at United was an FO who rotated through the right seat through a trip. I'm sure it was the same at other operators across North America.
"Ground 1120 at checkpoint.... 3! ahh sorry we should have got you at 1....." "1120 hold short, hold short where are you going?"
