North Pole temperature above freezing - December 30, 2015
Rockie
Post by Rockie »
The storm that caused the tornados in the US and whacked Ontario and Quebec earlier in the week has a long reach.
https://www.washingtonpost.com/news/cap ... ve-normal/
HiLo
Re: North Pole temperature above freezing - December 30, 201
Post by HiLo »
But climate change is a hoax....
NunavutPA-12
Post by NunavutPA-12 »
Has this ever happened before? Nobody knows because there is no historic data. I suspect that this is not as unusual as one might think. The north pole sits atop a very large ocean and so it's not uncommon for the temperatures in mid-winter at the pole to be many degrees warmer than a place 2,000 miles south that sits in the middle of a cold land-mass.
And climate change is not a hoax. The nature of climate is that it changes, and has done so since the beginning of time.
Rockie
Post by Rockie »
NunavutPA-12 wrote:Has this ever happened before? Nobody knows because there is no historic data. I suspect that this is not as unusual as one might think. The north pole sits atop a very large ocean and so it's not uncommon for the temperatures in mid-winter at the pole to be many degrees warmer than a place 2,000 miles south that sits in the middle of a cold land-mass.And climate change is not a hoax. The nature of climate is that it changes, and has done so since the beginning of time.
You're absolutely right. Oceans have a huge moderating influence on local climate - except when they're covered in ice as the arctic ocean is supposed to be up in the North Pole. Really, do you guys have to have sea water up to your armpits 364 days of the year to allow that maybe the planet is warming up? You think above freezing temperatures at the North Pole is normal despite what NASA, NOAA, Environment Canada and every other scientific organization - not to mention common sense - is telling you?
Jeez...
Go Juice
Post by Go Juice »
A device is yet to be invented that will measure my indifference to this remark.
B208
Post by B208 »
Hey Rockie,
You do realize that most of Canada had a subtropical to tropical climate in the past, right?
Also, what does this have to do with aviation?
Rockie wrote:Oceans have a huge moderating influence on local climate - except when they're covered in ice as the arctic ocean is supposed to be up in the North Pole.
Interesting choice of words. Supposed to be? Who's doing the supposing?
esp803
Post by esp803 »
Climate change happens, and I'm sure we are contributing to it. That being said, 10,000 years ago NA was covered in Ice during the last ice age...
E
FICU
Post by FICU »
The planet has been warming continuously since the last ice age and will continue to do so with or without our help.
HiLo
Post by HiLo »
From your article:
“The good news is that Antarctica is not currently contributing to sea level rise, but is taking 0.23 millimeters per year away,” Zwally said. “But this is also bad news. If the 0.27 millimeters per year of sea level rise attributed to Antarctica in the IPCC report is not really coming from Antarctica, there must be some other contribution to sea level rise that is not accounted for.”
From the same agency:
http://climate.nasa.gov/evidence/
Emphasis on the "extreme events" section.
Also, this:
http://www.theguardian.com/environment/ ... s-debunked
To any pilots who doubt that climate change is man-made, that it exists or that it will have severe consequences, I say this: the science surrounding climate change is not the discovery of some new scientific principle (like the Theory of Gravitation, or Newton's Laws of Motion), but it is simply the combination of hundreds of years of scientific theory and law. Saying climate change is a hoax, or that it is not man-made, or that it will not have consequences for humans is tantamount to saying that hundreds of years of scientific knowledge is bogus, from the Theory of Gravitation to Termodynamics, Plate Tectonics and Electromagnetism. As a pilot, you should know better.
HiLo
Post by HiLo »
Umm...scientists. And a whole bunch:
http://earthobservatory.nasa.gov/Featur ... ea_ice.php
NunavutPA-12
The fact is that an ocean full of water at -1C, even if covered by ten feet of ice, will have some effect on the air temperature above it. Couple that with the invasion of an "unusual" (not necessarily "un-precedented") warm air mass, and you have a great story for the CBC.
Aviation related? Aren't all pilots interested in this stuff?
Rockie
Post by Rockie »
B208 wrote:You do realize that most of Canada had a subtropical to tropical climate in the past, right?
Earth used to be a molten slag of basic elements. What does that have to do with today?
FICU wrote:The planet has been warming continuously since the last ice age and will continue to do so with or without our help.
That's possible, however human activity has increased it to a rate that puts us at risk and that's what we need to change. If you live in Florida or any other low lying place on the planet you should be very worried about it and pressing government to do something about it. The mass human migration has already started and is causing huge problems, but some people just don't recognize the cause.
B208
Post by B208 »
HiLo,
It's more closely related to black body radiation and quantum physics.
While the theory behind it is sound, (Carbon Dioxide is a double carbonyl, and as everyone knows the C=O double bond absorbs strongly in the IR part of the spectrum), I believe the unscrupulous are using this issue to fleece the unthinking.
Rockie
Post by Rockie »
NunavutPA-12 wrote:The fact is that an ocean full of water at -1C, even if covered by ten feet of ice, will have some effect on the air temperature above it.
I guess you don't know why they call it the "arctic". It's supposed to be the coldest place on the planet.
HiLo
Post by HiLo »
In an ocean, having liquid water below zero is not possible.
Rockie
Post by Rockie »
B208 wrote:I believe the unscrupulous are using this issue to fleece the unthinking.
So, is the entire world wide, multi-disciplinary scientific community the unscrupulous or the unthinking in your opinion?
HiLo
Post by HiLo »
B208 wrote:HiLo,
Care to expand on who the "unscrupulous" are? And how they "fleece" the "unthinking?"
B208
Post by B208 »
Which it will be again, which is exactly the point. The Earth has been warming and cooling in a cyclical nature over its entire history, most likely due to carbon trapping in plant life.
Also, slag is the solid left over after metals have been smelted, (i.e. if it's molten it's not slag)
Rockie
Post by Rockie »
B208 wrote:Which it will be again, which is exactly the point. The Earth has been warming and cooling in a cyclical nature over its entire history, most likely due to carbon trapping in plant life.
Whenever someone claims the worldwide scientific community doesn't know what they're talking about it begs the question - what makes you right and them wrong?
B208
Post by B208 »
As usual, you miss the subtle. The basic science behind the concept is sound, (see my post ref carbonyls and IR etc...), but the political response to the problem is not.
The unscrupulous are the politicos, (esp from the developing world), who look at this as an opportunity to divert more money into their coffers. The unthinking are people, (like you) who swallow what the politicos cook up.
HiLo
Post by HiLo »
Are you saying that the 97% of scientists think that a man-made increase in CO2 levels in the atmosphere is causing significant and devastating climate change are wrong?
Scientists agree that Earth will easily survive any climate change we throw at it, just that we won't.
No, it's not. Antarctica has always been much much colder than the North Pole, and has always held the record for the continent with the coldest place.
The North Pole is covered in ocean, and water - ice is still water - makes a great heat sink keeping the annual temperature variations there quite small and the winters relatively mild. You really don't want to be outdoors in this place (from Wikipedia)
"The lowest natural temperature ever directly recorded at ground level on Earth is −89.2 °C (−128.6 °F; 184.0 K), which was at the Soviet Vostok Station in Antarctica, on July 21, 1983. Analysis of satellite data indicated a probable temperature of around −93.2 °C (−135.8 °F; 180.0 K), also in Antarctica, on August 10, 2010; however, this reading was not confirmed by ground measurements."
HiLo
Post by HiLo »
You are telling me that it is advantageous for developing nations to support climate change? Did you see Modi at the Paris Conference? Nations like India are the reason the accord took so long and lacks real teeth.
NunavutPA-12
Oh really!? We are talking about SALT water, you know.
