Perfect Landings
Johnny5
Perfect Landings
Post by Johnny5 »
I've got a few questions on landings for the high-timers out there. I've read some of the old threads about switching your vision from flare height to the end of the runway and I seem to be doing that OK. But I am wondering about power settings. I have been taught to pull the throttle to idle when I am over the threshold and ready to flare. I can get the aircraft levelled out and lined up on the centreline but it just seems that arresting the sink rate is really tough and results in a bumpy landing. I'm not saying that anybody's hat is falling off of their head during the landing but my instructor isn't able to sip on a coffee when I land either. But that's what I'm aiming for, those nice, gentle even transitions to the ground.
I've been experimenting with power settings and I find that if I leave a little power on until I'm levelled off over the runway and then pull the power to idle it results in a smoother and more controllable landing. I can also hear other guys doing this too when they come in for landing.
So what's the trick? Any tips from you guys would be greatly appreciated.
OW
Post by OW »
With experience you can cut the power anywhere you want and still make a smooth landing, but you might find that it will be smoother in the early stages if you wait till you are raising the nose in the flare before you pull the throttle back to idle.
Pulling the throttle back just prior to the flare (with the natural tendency for the nose to want to drop at that time) leaves you scrambling to control the natural nose drop at a time when you should be thinking of a simple level off.
If you "fly" it into the flare and pull the power after you begin to raise the nose you will have a more stable flare. As I stated above, with experience it won't matter when you pull the power.
The disadvantage of the method above is that you will need a few hundred feet more runway.
By the way, waiting till you are in a level attitude in ground effect will leave you with the same (initially) awkward control problem as pulling the power before the flare.
The result that is intended by using the method described above is to reduce you workload. Flying the attitude and reducing power while raising the nose results in only one pitch adjustment in the flare, not two as with a power reduction and then a flare.
Try it. Let us know if it helpped.
8)
Pilots get higher, SCUBA Divers do it deeper!
Interesting subject.
There are as many ideas on how to land as there are pilots it seems.
For what ever it is worth, when I am type rating any pilot on the PBY I have them close the throttles completly and be stabalized in the approach by 2 hundred feet above the surface, especially during water landing training.
When they are profficient in judging the correct flare height and able to land without the use of power I will then let them use power to land.
The more power you use the longer the airplane will be exposed to attitude and direction excursions.
By the way the PBY is heavier on the controls than a C150 / 172.
OW
Post by OW »
That, Charles is another thing I should have said: Power to idle well before the flare also lightens the workload in the flare.
Received a video clip of a PBY on approach (touch and go) with a couple of fishermen in a boat til just before lift off. Don't know if it was dubbed or for real. Telephoto lens makes it look pretty close. Title is "Fishing Hazard". Don't know how to put it on here.
PBY is White with Red belly and cowlings.
Post by ahramin »
Don't worry OW. Others have figured it out :):
http://www.avcanada.ca/forums2/viewtopic.php?t=941
Post by ahramin »
Johnny5 wrote:switching your vision from flare height to the end of the runway
Que? Can anyone explain this to me please?
OW :
That is a Super Cat and the film was the start of " Always " a movie about firebombing.
I used to fly that same Cat many years ago.
Abramin:
When they look up at the far end of the runway it is proof positive that from that point until contact with the earth they will not have any clue as to how high they are above the runway.
I find it to be the most agravating and most difficult habit to try and correct.
It came into the training group some years ago and monkey see monkey do has ensured that it will be accepted as the way to train....Sadly.
Cat
oldtimer
Post by oldtimer »
All Far 23 turbines and Commuter turbines describe the technique used for certification. Fly @ 1.3 Vso stabilized on a 3 degree slope, (with power). @ 50 ft, power to idle and land with minimum flair.
My rule, flair once and if it doesn't land, fly it on. For safety sake transition from the low altitude, low energy state of the flair to on the ground as quickly as possible. Power on in the flair will allow you to fly it on and maybe get a squeeker but you are at the mercy of everthing. Too much power and you will float for ever. not enough flap and you will touch down too fast. Worst is too much power and not getting it off. Most important. RELAX, SURVEY YOUR SURROUNDINGS. and then make the airplane do what you want it to do. Which is a bone jarring crunch.
SplitS
Post by SplitS »
Love those - they reset my spine everytime. Saves me a bundle on chiro bills....
Keep flying till the noise stops.
permateacher
Landings
Post by permateacher »
Here's my two cents...
I don't think there's any one way to sequence the power reduction and flare for all landings. It depends on the type of aircraft, the weight, the weather conditions and the type of landing you need to do.
For light singles such as the 172 and the 150, they like to float if they're light. With just the student, instructor with half fuel and light wind for a normal landing I'd maintain a power setting that will give you a stabilized approach at the book approach speed all the way to the threashold. In the absence of apporach speed you can use Vso X 1.3. A few seconds before you start your level off 3-5 feet above the runway (flare), bring the power smoothly to idle. Once you level off, pause a few seconds in ground effect, then start to apply gentle back pressure to keep the aircraft off the rnwy but not climb. You can't rush the aircraft into the landing or it'll ballon up again. Keep pulling back ever so smoothly, gently and constantly and you will grease it on. Oh ya, on short final... ailerons for drift, rudder to keep straight, attitude for airspeed and power for height.
With more weight or hotter outside air temperature, fly it on with some power into the flare, because the aircraft will run out of lift at a faster speed... be ready.
For short field, put it where you want it... don't hold it off for a greaser or you'll be in the rhubarb.
With gusty wind, add half the gust factor to the appoach speed, fly it on with some extra pwr, and if you run out of rudder with the crosswind... you should overshoot earlier rather than later.
Hope that helps (beware of free advise, sometimes you get exactly what you pay for :wink: )
Give me a PM with any questions
KAG
Post by KAG »
What seems to work for me is once you flare, transfer your gaze to the end of the runway, and line the top of the dash with it. As you round out, pull back alittle to keep the dash lined with the end of the runway. That will give you a nice nose up attitude, as well as arrest that sink rate you mentioned. I'm assumeing your flying a light single piston, so I wouldn't land with any power unless your doing soft fields (even then, only a bit).
This technique has worked for everything from 172 to the king air.
Chase lifestyle not metal.
I find there is a grey area in judging height above the runway with a large number of pilots.
The grey area being the time period between the flare and the hold off portion prior to touch down, in that area a lot of pilots are depending on maintaining attitude to eventually "arrive" when lift decays to the point that the airplane will no longer fly.
During that period I find that most pilots do not have a clue if the wheels are 6 inches or 6 feet above the runway.
In every case the problem is looking to far ahead to accurately judge the height above the runway.
When wheel landing a comventional gear airplane do you still look at the far end of the runway to judge height?
Cat
KAG
Post by KAG »
LOL, not every case, sometimes I cant see very far ahead, but generally yes.
When judgeing the flare, I pick the point on the runway that im going to land on and keep it in my windscreen at the same point - like judgeing a glide, not moveing up or down, just getting bigger. Once that point is about to go under your wing, flare and transfer your gaze to the end of runway.
When you transfer your gaze to the end of the runway you have lost the ability to accurately judge any change in height above the runway.
Therein lies the problem in re teaching pilots how to accurately judge height after flaring to the level attitude.
Cat
Murdoch86
Post by Murdoch86 »
I do final w/ full flap, pull the power back to idle at some point.
The wheels start turning, then I turn on the "have landed" light for the pax 8)
Ace McCool...
KAG
Post by KAG »
So where do you look?
I can judge pretty acurately how high I am by the visual cues i get from the side view.
Airtids
Post by Airtids »
As you flare, and shift the FOCUS of your vision to the far end to more accurately note sink rate. You are using your PERIPHERAL vision to determine your actual height above ground, as well as control for drift once the far end disappears under the cowling. A student needs to be told this, the experienced folks just do it automatically.
ndb
Post by ndb »
Screw the greaser business. As Navy pilots say about the Air Force, "Flare to land, squat to pee".
Far more importantly, figure out what your final approach speed should be (at the weight, etc) then nail it. Too many pilots (usually low-time with marginal stick and rudder skills) allow the speed to vary all over the place, and when they're 20 fast, boy they're going to float a long way down the runway before touching down. If you can precisely maintain your airspeed on final, you're way ahead of the rest of the pack.
Stay on the runway centerline. Marginal pilots will ignore the crosswind during the flare and get blown over to the downwind side of the runway. I guess they don't mind taking out a row of runway lights, smashing up a wheel pant, etc.
Finally, in a light aircraft, remember that you don't land it. You maneuver the aircraft so that it is 6 inches above the runway with the power off in the landing attitude, and you try to stop it from touching down with aft elevator.
When you master all of the above, then start worrying about greasers. It's a lot easier to get a consistent landing with a consistent approach. It's not necessary (ie with sufficient skill you can be decelerating the entire final) but it's a heckuva lot easier.
Malignantly yours,
Yes , but back to looking at the far end of the runway and the ability to accurately judge height looking that far into the distance.
In a tailwheel airplane can you perform smooth wheel landings looking a mile ahead of the airplane to judge height for a smooth touchdown?
Can you maintain two feet above the runway at say 80 knots for a mile with your vision focused a mile ahead of the airplane?
Johnny5
Post by Johnny5 »
Thanks for all of the info guys, much appreciated. It seems like every pilot here just finds a system that works for him/her and sticks with it.
Cat Driver and Ahrahim: as far as the looking toward the end of the runway is concerned, I wouldn't say that that is the technique I am actually employing. Rather, I am switching my vision from where I feel like the airplane is going to touch down and the time to flare, to about as far ahead as I would look in my car driving the same speed. I am in no way peering toward the end of a 6000' runway.
But I am no 5000 hour pilot either, I am a 40 hour pilot. So what do you guys do as far as vision goes when at the point where you need to start levelling the airplane?
KAG
Post by KAG »
CAT, im not talking about a tailwheel AC, im talking a tricycle gear, and that technique (of looking down the runway) has worked for me from the 172 up to the king air, from 2200' strips to landing in Pearson. I find pilots that don't transfer there gaze down the runway tend to land flat, they "fly" it on.
Now a tailwheel, I've been told is very different, and since I have no experience in one I cant comment, but from just watching them it looks like what would be a flat as hell landing in a tricycle gear is the landing attitude for a tail dragger.
pika
Shifting Focus Answer
Post by pika »
Here it is from The Airline Training Pilot. Stellar book that still costs over $100 but well worth it.
"When established on a constant slope, the distance between the individual runway lights will remain constant. Maintaining this constant picture is an important concept of night approaches, and you should make certain that he recognizes deviations from slope (visible by the distance between lights opening or closing) early is his training. Make a point of showing this to him.
The flare initiation height will be indicated first, when, looking towards the far end of the runway he will notice the light beginning to close up. Shifting his focal point back towards the approach end, he will notice the lights beginning to open up, giving him a feeling of sinking into the runway.
He should now begin to raise the nose of the aircraft towards the landing attitude and simualtaneously begin to smoothly close the throttles. The rate of change will depend upon the sink rate and local condituons.
Now is the time that he should change his focal point to the normal position and make minor adjustments to the aircraft attitude as neccesary. He should resist the tendency to stare into the area illuminated by the landing lights.
Remember, the descent should never be stopped completely, particularily at night. If in doubt as to the height above the runway, he should resist over flaring. Merely flare the aircraft initially and hold that attitude. The touchdown will be within normal limits and far more acceptable than floating down the runway a few feet up. This leads to tail strikes, heavy touchdowns and over runs."
An excellent few paragraphs that has served me well on many types. Somewhat of a challenge to believe it will work and to force yourself to do it properly the first few times but it's a great technique. Hope it helps. :)
Yeh, King Air Guy you probably have found a method of judging height during the last phase of the landing.
What I am trying to point out is that by teaching new pilots to look far ahead like at the far end of the runway they will have difficulty in judging their height above the runway.
Sure you can just hold the landing attitude with a nose wheel airplane and it will arrive on the runway as long as there is not to much power being carried.
What I am trying to explain that to really judge exact height you must look closer than the far end of the runway. A better description of where to look is about five hundred feet down the runway.
Then again maybe I've been looking in the wrong place during my landings.
Do you think you can maintain two feet forever looking a mile ahead? Or would it be better to look about five hundred feet ahead?
Cat
oldtimer
Post by oldtimer »
Actually, there is a real easy method of judging the round out or flair in a two pilot airplane. Just watch the co-pilot. When he stiffens up and squeeks, "Holy Shit". flair.
Seems like every time I land, I have no idea what I'm doing.
I look really far down the runway. Sometimes I forget. Sometimes I bounce all over the place. Sometimes I grease it exactly where I want. Sometimes I feel like I'm falling out of the sky and make sure I'm in the climb attitude. Sometimes I hit some power and yaw like mad.
My questions are: "Do even high time pilots make crap landings?"
"Does . Yeager ever go off the centreline? Even a little?"
Oh here's another: "How many hours do you need before you grease it every time, exactly where you want it?" (That should get some interesting responses!)
-istp :roll:
