Didn't know the Skymaster was certified for aerobatics...
Changes in Latitudes
Re: Didn't know the Skymaster was certified for aerobatics..
Looked like a 1g roll. What certification does that require? Ever see the movie Bat-21?
She's a nimble beastie, love the master.
.... or less, there seemed to be a few items floating around.Looked like a 1g roll
Judging by the weightless salted nuts tin at the :20 mark, there was at least a bit of negative G experienced.
Leaving the registration fully visible at several points in the video was a nice touch.
Posted back in 2009. Doubt anyone's going to be chased down at this point, regardless.
I would hope you would be able to answer that yourself.Changes in Latitudes wrote:Looked like a 1g roll. What certification does that require?
SuperchargedRS
That was my first thought too, well after he needs to pledge his windshieldPilotDAR wrote:.... or less, there seemed to be a few items floating around.Looked like a 1g roll
Frankly though, presuming the pax knew before hand and were cool with it, long as it was the PICs own plane, and since it wasn't over a populated area, whatever
Unless they scrawled that reg on there for fun to avert authorities, that plane was being flown for Discovery at the time....
How much ya wanna bet that guy watched Bat21 the night before?
toelessjoe
Did that registration say FSIW?
Fire patrol training
Was that you mr Joe? Those poor suck and blows.
Nice...
Registered Owner Information
Name: Discovery Air Fire Services Inc.
Address: Box 400
City: Dryden
Address: Box 400
City: Dryden
Ailron roll can be accomplished in just about any aircraft as long as the G load is not surpassed, but that aircraft is not considered to be in the Aerobatic cat. of aircraft , just the Normal cat. Following the manouvre if the aircraft sustained any damage the pilot would be on the hook, The POH information handbook will state which manoeuvre's are authorized and the G limits plus or negative, for the airplane.
Don't let your wife talk you out of buying an airplane,
Hey Redlaser, what's your take on rolling g?
In the Utility Category, an airplane is authorized to (from the airworthiness manual):
(1) Spins (if approved for the particular type of aeroplane); and
(2) Lazy eights, chandelles, and steep turns, or similar manoeuvres, in which the angle of bank is more than 60 degrees but not more than 90 degrees.
I don't see rolls in there.
Going for the deck at corner
So doesn't that invalidate the C of A?
goingnowherefast
Any airplane can be rolled. 707, Concorde, Aero Commander.
Just because it's possible, doesn't mean it's smart, a good idea, or legal. Certainly pretty dumb to film it, and especially to post it on YouTube.
co-joe wrote:So doesn't that invalidate the C of A?
For the time the aircraft is operated in contravention to the POH and its category.
The Skymaster is only certified in the Normal category, so you can't even do spins.
Yeppers. Or banks over 60 degrees.
That being said, if you can keep the loading within spec between 3.8 and -1.52 as per the AFM, isn't the bank angle really just an arbitrary limiting factor? Plane doesn't know which end is up.
It is the definition of normal and utility categories. How they got there is irrelevant at this point. 60 degrees AOB is 2G in level flight. 90 is infinite Gs to maintain level (ie: unless you use other means to generate an aerodynamic force opposite to the weight of the aircraft).
Agreed. Actual legality aside, (I don't think there's a debate there.) A 1g barrel roll is doable (Not that aileron roll in the video!!) and well within the operating envelope of the airplane, so purely as a thought experiment- if it doesn't exceed the aforementioned design parameters, isn't the bank angle a bit arbitrary as a legal limitation?
-Edit, the way the AFM reads, it is "turns in which the angle of bank is not more than 60*." This implied a bit more relationship with wing loading. So partially answering my own musings....
You can't do a barrel roll at 1G.DanWEC wrote: A 1g barrel roll is doable (Not that aileron roll in the video!!)
Think ahead or fall behind!
Why not? Heck didn't Tex Johnson do it in a 707? I'm not an aero pilot, am I naming the wrong type of roll?
How does the pilot of your average airplane measure this?if you can keep the loading within spec between 3.8 and -1.52 as per the AFM
Many posters here already know this well, but it's probably time to refresh the theme...
An element of the certification of an aircraft is operational limitations and approved maneuvers. It is required that they be stated on the limitations placard. Flying the maneuver is one thing, but the tolerance for excursion is another. Sure, you can roll many planes ( I found myself in a roll during flight testing of a Lake Amphibian - beautiful!), but does the aircraft have the capability to let you safely out of a botched maneuver? How would you know until you find yourself there?
All single engined certified planes must demonstrate spin recovery during certification testing, so why are not many spin approved? Because the margin for recovery from excursion or imperfect technique is inadequate. A well executed spin recovery in a forward C of G Caravan will require a 2.5G recovery near Vne to get out. Not much room to get it wrong, and really difficult to execute correctly without a G meter!
So the intrepid 337 pilot knows what many of us know, it'll roll okay. But if the roll were to be botched, is there room to get out without bending or stretching something important? Would he know if he did? Would he report it if he knew?
The pitch up at the beginning means more than 1G, probably 1.5 to 2G's. Then the pitch up again at the end also requires more than 1G. The only way to roll it within the [1G , -1G] envelope is if the plane has sufficient thrust / speed and side area to maintain altitude in knife edge flight with healthy application or rudder as you go around.Why not?
The main danger in any rolling maneuver is insufficient roll rate, or relaxing or pausing the roll after the plane goes past 90 degrees. Most pilots the first time they roll will naturally make several mistakes. The first is not tightening the seat belts enough so their ass lifts off the seat as you go negative. Then when their ass goes off the seat they naturally pull on the control column which pulls you toward the ground causing increased altitude loss and greater speed/G required for recovery. The third error is not maintaining sufficient aileron which slows the roll and means longer time without the wings lifting the way you want and increased recovery speed and altitude. If you are unlucky you can end up with the nose very low during the pull up and a very high speed and over G during the recovery. These are all mistakes that are best made in a plane that can take the abuse when you muck it up. Of course there is no physical reason why most planes could not execute rolls with little risk but in a fragile airplane it requires a lot of skill to do it perfectly every time... remember 1 in 100 botch ups are pretty poor odds.
Also the pre-flight for an aerobatic flight includes a few more items such as loose items checks etc. which likely have never been done in a non aerobatic plane and you risk getting hit in the head by something. I once got a mag-light right in the temple during a low roll and fire extinguishers have been known to come loose.. not fun so careful pre-flight is pretty important. We typically also usually have redundant seat belts because well ... its not pretty when you come loose.
