av8ts wrote:Two of my favourites are. 1. Hey center you got time for a quick question? If I was center I would answer yes just one and you used it. 2. Tower flight xxx ready in sequence. Why are you saying in sequence. Tower knows your sequence and you'll go when it's your turn.
I understand what you're saying, however, some things to consider:
1. Center may not have time for a question. It's polite to ask. Even when the freq is quiet, the controller may be running several sectors on several frequencies, assisting an emergency aircraft, doing training, etc. etc. So, not bad etiquette to ask, especially if it's not something pertinent to flying.
2. Ready in sequence also lets tower know that you're ready
if and when you become #1. If it's a busy runway and tower thinks you might be able to roll an immediate between other planes, this lets tower know you're spring loaded to launch. It's better than "hey XXX, you on frequency? XXX are you ready? Are you able an immediate?" Otherwise, you may just sit there while the 6 on final land. It's like saying "I'm ready whenever you're ready, happy to fit in the flow if you can."
